path: root/common/fdt_support.c
2015-05-05fdt: Correct warning in fdt_setup_simplefb_node()Simon Glass
Adjust the printf() string to avoid a warning on sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-22fdt: add new fdt_fixup_display function to configure displayTim Harvey
Add 'fdt_fixup_display' function to fixup device-tree native-mode property of display-timings node to select timings for a specific display. This is useful if a device-tree has configurations for multiple display timings for undetectable displays. see kernel Documentation/devicetree/bindings/video/display-timing.txt Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-04Merge branch 'sandbox' of git://git.denx.de/u-boot-x86Tom Rini
2014-12-01fdt: Fix regression in fdt_pack_reg()Hans de Goede
After commit 933cdbb479: "fdt: Try to use fdt_address_cells()/fdt_size_cells()" I noticed that allwinner boards would no longer boot. Switching to fdt_address_cells / fdt_size_cells changes the result from bytes to 32 bit words, so when we increment pointers into the blob, we must do so by 32 bit words now. This commit makes allwinner boards boot again. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Vince Hsu <vinceh@nvidia.com>
2014-11-26sandbox: Fix warnings due to 64-bit printf() stringsSimon Glass
Now that we have inttypes.h, use it in a few more places to avoid compiler warnings on sandbox when building on 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-26Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2014-11-26Merge git://git.denx.de/u-boot-fdtTom Rini
2014-11-25fdt_support: Add a fdt_setup_simplefb_node helper functionHans de Goede
Add a generic helper to fill and enable simplefb nodes. The first user of this will be the sunxi display code. lcd_dt_simplefb_configure_node is also a good candidate to be converted to use this, but that requires someone to run some tests first, as lcd_dt_simplefb_configure_node does not honor #address-cells and #size-cells, but simply assumes 1 and 1 for both. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Try to use fdt_address_cells()/fdt_size_cells()Simon Glass
Use these new functions where possible. They default to a value of 2 so we cannot use them in some places where we need a default value of 1. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Change fdt_pack_reg() to static and fix typesSimon Glass
This function is only called within this file so make it static. Also fix its argument types to be consistent with its caller. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Export the fdt_find_or_add_subnode() functionSimon Glass
This function is useful for ensuring that a node exists. Export it so it can be used more widely. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-09-25fdt_support: Make of_bus_default_count_cells non staticArnab Basu
of_bus_default_count_cells can be used to get the #address-cells and #size-cells defined by the current node's parent node. This is required when using of_read_number to read from FDT nodes that can be 32 or 64 bytes depending on values defined by the parent. Signed-off-by: Arnab Basu <arnab.basu@freescale.com> CC: Scott Wood <scottwood@freescale.com>
2014-09-25fdt_support: Move of_read_number to fdt_support.hArnab Basu
This is being done so that it can be used outside 'fdt_support.c'. Making life more convenient when reading device node properties that can be 32 or 64 bits long. Signed-off-by: Arnab Basu <arnab.basu@freescale.com> Cc: Scott Wood <scottwood@freescale.com>
2014-08-09fdt: Rename fdt_resize() to fdt_shrink_to_minimum()Simon Glass
Since libfdt now has an fdt_resize() function, we need to rename the U-Boot one. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: correct the return condition of fdt_initrd()Masahiro Yamada
Before this commit, fdt_initrd() just returned if initrd start address is zero. But it is possible if the RAM is located at address 0. This commit makes the return condition more reasonable: Just return if the size of initrd is zero. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: fix an endian bug of fdt_initrd()Masahiro Yamada
Data written to DTB must be converted to big endian order. It is usually done by using cpu_to_fdt32(), cpu_to_fdt64(), etc. fdt_initrd() invoked write_cell(), which always swaps byte order. It means the function only worked on little endian architectures. (On big endian architectures, the byte order should be kept as it is) This commit uses cpu_to_fdt32() and cpu_to_fdt64() and deletes write_cell(). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: fix an endian bug of fdt_fixup_memory_banksMasahiro Yamada
Data written to DTB must be converted to big endian order. It is usually done by using cpu_to_fdt32(), cpu_to_fdt64(), etc. fdt_fixup_memory_banks() invoked write_cell(), which always swaps byte order. It means the function only worked on little endian architectures. This commit adds and uses a new helper function, fdt_pack_reg(), which works on both big endian and little endian architrectures. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: add 'const' qualifier for unchanged argumentMasahiro Yamada
In the next commit, I will add a new function, fdt_pack_reg() which uses get_cells_len(). Beforehand, this commit adds 'const' qualifier to get_cells_len(). Otherwise, a warning message will appear: warning: passing argument 1 of 'get_cells_len' discards 'const' qualifier from pointer target type [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: refactor fdt_fixup_stdout() functionMasahiro Yamada
- Do not use a deep indentation. We have only 80-character on each line and 1 indentation consumes 8 spaces. Before the code moves far to the right, you should consider to fix your code. See Linux Documentation/CodingStyle. - Add CONFIG_OF_STDOUT_VIA_ALIAS and OF_STDOUT_PATH macros only to their definition. Do not add them to both callee and caller. This is a tip to avoid using #ifdef everywhere. - OF_STDOUT_PATH and CONFIG_OF_STDOUT_VIA_ALIAS are exclusive. If both are defined, the former takes precedence. Do not try to fix-up "linux,stdout-path" property twice. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: delete force argument of fdt_chosen()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_chosen() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: delete force argument of fdt_initrd()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_initrd() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: refactor with fdt_find_or_add_subnode helper funcMasahiro Yamada
Some functions in fdt_support.c do the same routine: search a node with a given name ("chosen", "memory", etc.) or newly create it if it does not exist. So this commit makes that routine to a helper function. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: delete unnecessary DECLARE_GLOBAL_DATA_PTRMasahiro Yamada
gd->bd is not used in fdt_support.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19ARM: fdt support: Add usbethaddr as an acceptable MACDan Murphy
A board that has a USB ethernet device only may set the usbetheraddr and not the ethaddr. ethaddr will be the default MAC address that is chosen and if that is not populated then the usbethaddr is looked at. If neither are set then then device tree blob is not modified. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2014-04-22fdt_support: Add helper function to read "ranges" propertyAlexander Graf
This patch adds a helper function that can be used to interpret most "ranges" properties in the device tree. It reads the n'th range out of a "ranges" array and returns the node's virtual address of the range, the physical address that range starts at and the size of the range. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22fdt_support: split fdt_getprop_u32_defaultAlexander Graf
We already have a nice helper to give us a property cell value with default fall back from a path. Split that into two helpers - one for the old path based lookup and one to give us a value based on a node offset. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-20fdt_support.c: Correct linux,initrd-start/end settingTom Rini
The change to add 64bit initrd support broke 32bit initrd support as it always set 64bits worth of data into the properties, even on 32bit systems. The fix is to use addr_cell_len (which already says how much data is in 'tmp') to set the property, rather than always setting 8. Thanks to Stephen Warren for pointing out the fix here. Reported-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Tom Rini <trini@ti.com>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-09fdt_support: 64bit initrd start address supportDavid Feng
Signed-off-by: David Feng <fenghua@phytium.com.cn>
2013-12-16common/fdt_support.c: avoid unintended return from fdt_fixup_memory_banks()Miao Yan
fdt_fixup_memory_banks() will add and update /memory node in device tree blob. In the case that /memory node doesn't exist, after adding a new one, this function returns error. The correct behavior should be continuing to update its properties. Signed-off-by: Miao Yan <miao.yan@windriver.com>
2013-10-15mtd: fix warnings due to 64-bit partition supportScott Wood
commit 39ac34473f3c96e77cbe03a49141771ed1639486 ("cmd_mtdparts: use 64 bits for flash size, partition size & offset") introduced warnings in a couple places due to printf formats or pointer casting. This patch fixes the warnings pointed out here: http://lists.denx.de/pipermail/u-boot/2013-October/164981.html Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Tom Rini <trini@ti.com>
2013-06-07fdt: remove unaligned access in fdt_fixup_ethernet()Stephen Warren
Some ARM compilers may emit code that makes unaligned accesses when faced with constructs such as: char mac[16] = "ethaddr"; Replace this with a strcpy() call instead to avoid this. strcpy() is used here, rather than replacing all usage of the mac variable with the string itself, since the loop itself sprintf()s to the variable each iteration, so strcpy() is doing basically the same thing. Reported-by: Florian Meier Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2013-05-17fdt_support: Use CONFIG_NR_DRAM_BANKS if definedDoug Anderson
It appears that there are some cases where we have more than 4 banks of memory. Use CONFIG_NR_DRAM_BANKS if it's defined to handle this. This will take up a little extra stack space (64 bytes extra if we go up to 8 banks), but that seems OK. Signed-off-by: Doug Anderson <dianders@chromium.org>
2013-02-07common/fdt_support.c: sparse fixesKim Phillips
trivial: fdt_support.c:89:64: warning: Using plain integer as NULL pointer fdt_support.c:325:65: warning: Using plain integer as NULL pointer fdt_support.c:352:65: warning: Using plain integer as NULL pointer For the following bad constant expression, We hardcode the max. number of memory banks to four for the foreseeable future, and add an error with instructions on what to do once it's exceeded: fdt_support.c:397:22: error: bad constant expression For the rest below, sparse found a couple of wrong endian conversions in of_bus_default_translate() and fdt_get_base_address(), but otherwise the rest is mostly annotation fixes: fdt_support.c:64:24: warning: cast to restricted __be32 fdt_support.c:192:21: warning: incorrect type in assignment (different base types) fdt_support.c:192:21: expected unsigned int [unsigned] [usertype] tmp fdt_support.c:192:21: got restricted __be32 [usertype] <noident> fdt_support.c:201:21: warning: incorrect type in assignment (different base types) fdt_support.c:201:21: expected unsigned int [unsigned] [addressable] [usertype] tmp fdt_support.c:201:21: got restricted __be32 [usertype] <noident> fdt_support.c:304:13: warning: incorrect type in assignment (different base types) fdt_support.c:304:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:304:13: got restricted __be32 [usertype] <noident> fdt_support.c:333:13: warning: incorrect type in assignment (different base types) fdt_support.c:333:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:333:13: got restricted __be32 [usertype] <noident> fdt_support.c:359:13: warning: incorrect type in assignment (different base types) fdt_support.c:359:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:359:13: got restricted __be32 [usertype] <noident> fdt_support.c:373:21: warning: cast to restricted __be32 fdt_support.c:963:48: warning: incorrect type in argument 1 (different base types) fdt_support.c:963:48: expected restricted __be32 const [usertype] *p fdt_support.c:963:48: got unsigned int [usertype] *<noident> fdt_support.c:971:48: warning: incorrect type in argument 1 (different base types) fdt_support.c:971:48: expected restricted __be32 const [usertype] *p fdt_support.c:971:48: got unsigned int [usertype] *<noident> fdt_support.c:984:29: warning: incorrect type in argument 1 (different base types) fdt_support.c:984:29: expected restricted __be32 const [usertype] *cell fdt_support.c:984:29: got unsigned int [usertype] *addr fdt_support.c:996:32: warning: incorrect type in argument 1 (different base types) fdt_support.c:996:32: expected restricted __be32 const [usertype] *cell fdt_support.c:996:32: got unsigned int [usertype] *addr fdt_support.c:1041:41: warning: incorrect type in argument 1 (different base types) fdt_support.c:1041:41: expected restricted __be32 const [usertype] *cell fdt_support.c:1041:41: got unsigned int [usertype] *addr fdt_support.c:1053:41: warning: incorrect type in argument 2 (different base types) fdt_support.c:1053:41: expected restricted __be32 const [usertype] *range fdt_support.c:1053:41: got unsigned int const [usertype] *[assigned] ranges fdt_support.c:1064:53: warning: incorrect type in argument 2 (different base types) fdt_support.c:1064:53: expected restricted __be32 const [usertype] *addr fdt_support.c:1064:53: got unsigned int [usertype] *addr fdt_support.c:1110:50: warning: incorrect type in argument 2 (different base types) fdt_support.c:1110:50: expected restricted __be32 const [usertype] *addr fdt_support.c:1110:50: got unsigned int *<noident> fdt_support.c:1121:49: warning: incorrect type in argument 1 (different base types) fdt_support.c:1121:49: expected restricted __be32 const [usertype] *cell fdt_support.c:1121:49: got unsigned int *<noident> fdt_support.c:1147:60: warning: incorrect type in argument 2 (different base types) fdt_support.c:1147:60: expected restricted __be32 const [usertype] *addr fdt_support.c:1147:60: got unsigned int *<noident> fdt_support.c:1081:5: warning: symbol '__of_translate_address' was not declared. Should it be static? fdt_support.c:1154:5: error: symbol 'fdt_translate_address' redeclared with different type (originally declared at include/fdt_support.h:95) - incompatible argument 3 (different base types) fdt_support.c: In function 'fdt_node_offset_by_compat_reg': fdt_support.c:1173:17: warning: initialization discards 'const' qualifier from pointer target type [enabled by default] See also linux kernel commit 0131d897 "of/address: use proper endianess in get_flags". Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07treewide: include libfdt_env.h before fdt.hKim Phillips
and, if including libfdt.h which includes libfdt_env.h in the correct order, don't include fdt.h before libfdt.h. this is needed to get the fdt type definitions set from the project environment before fdt.h uses them. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2012-12-11fdt: edid: Enable fdt_add_edid() function when CONFIG_LCD definedTom Wai-Hong Tam
This function can be used for LCDs as well as monitors. Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2011-11-13Fix constness of the fdt void pointer in fdt_getprop_u32_defaultGabe Black
The function fdt_getprop_u32_default doesn't modify the fdt, so it can use a const void * for its fdt argument. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-11-13Add some missing endian conversions in fdt_support.cGabe Black
Some functions in fdt_support.c use fdt_getprop to read 32 bit values out of the device tree, but then use them directly without doing any endian conversion. Because they check for a value that doesn't actually appear in practice, the functions continued to work even though they're incorrect. This change adds the missing conversions. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-10-18fdt: Add new fdt_set_node_status & fdt_set_status_by_alias helpersShengzhou Liu
Add common function fdt_set_node_status() to assist in various locations that we set a nodes status. This function utilizes the status values that are part of the EPAPR spec (on power.org). fdt_set_status_by_alias() is based on fdt_set_node_status() but uses an alias string to identify the node to update. We also add some shortcut functions to help the common cases of setting "okay" and "disabled": fdt_status_okay() fdt_status_disabled() fdt_status_okay_by_alias() fdt_status_disabled_by_alias() Finally, we fixup the corenet_ds ethernet code which previously had a function by the same name that can be replaced with the new helpers. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2011-10-17sandbox: Use uintptr_t for 32/64-bit compatibilitySimon Glass
This fixes a problems when building on some 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-15fdt: update fdt_alloc_phandle to use fdt_get_phandleTimur Tabi
The device tree compiler, dtc, can use "phandle" and/or "linux,phandle" properties to specify the phandle for any node. By default, it uses both, but "linux,phandle" is deprecated. One day, we'd like to stop using "linux,phandle", but U-boot needs to support both properties equally first. fdt_alloc_phandle() generates a unique phandle, but it was only checking the "linux,phandle" properties. Instead, we use fdt_get_phandle(), which checks both properties automatically. This ensures that we support dtbs that only use "phandle". The side-effect is that fdt_alloc_phandle() now takes twice as long, since it has to check for two properties instead of one in each node that it searches. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-10-15fdt: check for fdt errors in fdt_create_phandleTimur Tabi
fdt_create_phandle() was ignoring errors from fdt_set_phandle(). If an error occurs, print an error message and return 0, which is an invalid phandle. We also need to change the return type for fdt_create_phandle() to indicate that it cannot return an error code. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-09-29fdt: Add new fdt_create_phandle helperKumar Gala
Add a helper function that will return a phandle value for the given node. If the node doesn't have a phandle already one will be created. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2011-09-29fdt: Rename fdt_create_phandle to fdt_set_phandleKumar Gala
The old fdt_create_phandle didn't actually create a phandle it just set one. We'll introduce a new helper that actually does creation. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2011-07-14fdt: introduce fdt_create_phandle()Gerald Van Baren
The ePAPR specification says that phandle properties should be called "phandle", and not "linux,phandle". To facilitate the migration from "linux,phandle" to "phandle", introduce function fdt_create_phandle(), which creates a phandle in a given node. For now, we create both the "phandle" and "linux,phandle" properties. A later version of this function will remove support for "linux,phandle". Signed-off-by: Timur Tabi <timur@freescale.com>
2011-07-14fdt: introduce fdt_verify_alias_address() and fdt_get_base_address()Timur Tabi
Introduce two functions, fdt_verify_alias_address() and fdt_get_base_address(), which can be used to verify the physical address of a device in a device tree. fdt_get_base_address() returns the base address of an SOC or PCI node. fdt_verify_alias_address() prints a message if the address of a node specified by an alias does not match the given physical address. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-04-25Fix off-by-one error in passing initrd end address via device treeGrant Likely
The initrd_end variable contains the address immediately *after* the initrd blob, not the last address containing data. This patch fixes an inadvertent off-by-one when setting up the initrd reserved map. Signed-off-by: Grant Likely <grant.likely@linaro.org>
