path: root/common/fb_nand.c
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11common: use get_nand_dev_by_index()Grygorii Strashko
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2016-06-27fastboot: sparse: implement reserve()Steve Rae
In order to process the CHUNK_TYPE_DONT_CARE properly, there is a requirement to be able to 'reserve' a specified number of blocks in the storage media. Because of the special handling of "bad blocks" in NAND devices, this is implemented in a storage abstraction function. Signed-off-by: Steve Rae <srae@broadcom.com> Reviewed-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-06-27fastboot: sparse: resync common/image-sparse.c (part 2)Steve Rae
- update fastboot_okay() and fastboot_fail() This file originally came from upstream code. While retaining the storage abstraction feature, this is the second set of the changes required to resync with the cmd_flash_mmc_sparse_img() in the file aboot.c from https://us.codeaurora.org/cgit/quic/la/kernel/lk/plain/app/aboot/aboot.c?h=LE.BR.1.2.1 Signed-off-by: Steve Rae <srae@broadcom.com>
2016-06-27fastboot: sparse: resync common/image-sparse.c (part 1)Steve Rae
This file originally came from upstream code. While retaining the storage abstraction feature, this is the first set of the changes required to resync with the cmd_flash_mmc_sparse_img() in the file aboot.c from https://us.codeaurora.org/cgit/quic/la/kernel/lk/plain/app/aboot/aboot.c?h=LE.BR.1.2.1 Signed-off-by: Steve Rae <srae@broadcom.com>
2016-06-27fastboot: sparse: remove session-id logicSteve Rae
This "session-id" alogrithm is not required, and currently corrupts the stored image whenever more the one "session" is required. Signed-off-by: Steve Rae <srae@broadcom.com>
2016-06-19common: fb_nand: won't compileSergey Kubushyn
Somehow this got overlooked when getting rid of nand_info. Small patch, won't affect anything else, no reason to wait for the next cycle. Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-03mtd: nand: Remove nand_info_t typedefScott Wood
This typedef serves no purpose other than causing confusion with struct nand_chip. Signed-off-by: Scott Wood <oss@buserror.net>
2015-11-12sparse: Rename the file and headerMaxime Ripard
The Android sparse image format is currently supported through a file called aboot, which isn't really such a great name, since the sparse image format is only used for transferring data with fastboot. Rename the file and header to a file called "sparse", which also makes it consistent with the header defining the image structures. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-12fastboot: nand: Add pre erase and write hooksMaxime Ripard
Some devices might need to do some per-partition initialization (ECC/Randomizer settings change for example) before actually accessing it. Add some hooks before the write and erase operations to let the boards define what they need to do if needed. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-12fastboot: Implement NAND backendMaxime Ripard
So far the fastboot code was only supporting MMC-backed devices for its flashing operations (flash and erase). Add a storage backend for NAND-backed devices. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
