About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
This header includes things that are needed to make driver build. Adjust
existing users to include that always, even if other dm/ includes are
present
simpler to read
Signed-off-by: Andreas Fenkart <afenkart@gmail.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Tested-by: Jagan Teki <jagan@openedev.com>
this makes it easier comparable to the double-buffered version
setup_flash_device selects one of two code paths depending on the driver
model being used (=CONFIG_DM_SPI_FLASH). env_relocate_spec only used
the non driver-model code path. I'm unsure why, either none of the
platforms that need relocation use the driver model, or - worse - the
driver model is not yet usable when relocating.
copy&paste code found in single/double buffered code path
CONFIG_ENV_SPI_xxx
The default values for the configuration defines CONFIG_ENV_SPI_xxx are
arbitrary values. It makes more sense to set them to the values used by
the sf command.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
In case of DT boot, don't read default speed and mode for SPI from
CONFIG_*, instead read from DT node. This will make sure that boards
with multiple SPI/QSPI controllers can be probed at different
bus frequencies and SPI modes.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Add exclamation mark to the errmsg, when error and set_default_env.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Cc: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
Cc: Vignesh R <vigneshr@ti.com>
Cc: Jagan Teki <jteki@openedev.com>
Cc: Ravi Babu <ravibabu@ti.com>
Cc: York Sun <york.sun@nxp.com>
It might be missed when converting spi_flash_probe() in cmd_sf.c.
This patch refers to commit fbb099183e3a ("dm: Convert
spi_flash_probe() and 'sf probe' to use driver model").
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Use memalign() with ARCH_DMA_MINALIGN to allocate read buffers.
This is required because, flash drivers may use DMA for read operations
and may have to invalidate the buffer before read.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
Tested-by: Jagan Teki <jteki@openedev.com>
The u-boot environment is redundantly stored in a NOR flash on our boards.
Redundant means that there are two places to store the environment. But only
one of the two is active. I discovered that on one board the u-boot (env_sf)
uses the environment from the second place and the Kernel (fw_printenv) uses
the environment from the first place.
To decide which is the active environment there is a byte inside the
environment. 1 means active and 0 means obsolete. But on that board both
environments had have a 1. This can happen if a power loss or reset occurs
during writing the environment. In this situation the u-boot (env_sf)
implementation uses the second environment as default. But the Kernel
(fw_printenv) implementation uses the first environment as default.
This commit corrects the default in the u-boot env_sf implementation when a
problem was detected. Now the recovery default is the same like in all other
environment implementations. E.g. fw_printenv and env_flash. This ensures that
u-boot and Kernel use the same environment.
Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
Some files are using SPI functions but not explitly including the SPI
header file. Fix this, since driver model needs it.
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Implement env_export() wrapper, so that all implementers of saveenv() don't
have to call hexport_r(), crc32() etc. sequence . This trims down a bit of
code duplication.
There was no enough stack in SPL, so the buffer needed in SPL is to malloc
from memory pool and to repalce the temporary variable.
Signed-off-by: Ying Zhang <b40530@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
- line over 80 characters
- add tabs
- CHECK: Alignment should match open parenthesis
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
[trini: Fixup common/cmd_io.c]
Wolfgang requested this be reverted and Rob agreed after further
discussion. This was a symptom of a larger problem we need to deal
with.
This reverts commit 60d7d5a63189c9f77a190c9965861dc15482c2d0.
Most of the various environment functions create CONFIG_ENV_SIZE buffers on
the stack. At least on ARM and PPC which have 4KB stacks, this can overflow
the stack if we have large environment sizes. So move all the buffers off
the stack to static buffers.
When printing all variables with env print, don't print variables that
begin with '.'. If env print is called with a '-a' switch, then
include variables that begin with '.' (just like the ls command).
Variables printed explicitly will be printed even without the -a.
env_get_char_spec() function is duplicated across multiple environment
files.
Remove the duplication by providing a default implementation.
Add "weak" declaration, so the default implementation can be overridden.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cleanup the env_sf.c checkpatch warnings, errors and coding style.
Extract all extern declarations for default_environment[] out of c files
into the environment.h header.
Cc: Stefan Roese <sr@denx.de>
New syntax:
env export [-t | -b | -c] [-s size] addr [var ...]
With this change it is possible to provide a list of variables names
that shall be exported. Whenno arguments are given, the whole
environment gets exported.
NOTE: The new handling of the "size" argument means a change to the
user API.
This patch fixes problems in the handling of redundant environment in env_sf.c
The major problem are double calls of free() on the allocated buffers,
which damages the internal data of malloc and crashes on next call.
In addition, the selection of the active environment had errors and compiler
warnings, which are corrected by this patch.
Signed-off-by: Thomas Langer <thomas.langer@lantiq.com>
The non-reentrant versions of the hashtable functions operate on a single
shared hashtable. So if two different people try using these funcs for
two different purposes, they'll cause problems for the other.
Avoid this by converting all existing hashtable consumers over to the
reentrant versions and then punting the non-reentrant ones.
Functions to store/retrieve the environment from a SPI flash was not updated
to the new environment code. The non-redundant case was
not working correctly, reporting ""Environment SPI flash not initialized"
and the code was not compiled clean in the redundant case.
The patch fixes these issue and makes the code more coherent
with other environment storage (nand, flash).
Motivation:
* Old environment code used a pessimizing implementation:
- variable lookup used linear search => slow
- changed/added variables were added at the end, i. e. most
frequently used variables had the slowest access times => slow
- each setenv() would calculate the CRC32 checksum over the whole
environment block => slow
* "redundant" envrionment was locked down to two copies
* No easy way to implement features like "reset to factory defaults",
or to select one out of several pre-defined (previously saved) sets
of environment settings ("profiles")
* No easy way to import or export environment settings
API Changes:
- Variable names starting with '#' are no longer allowed
I didn't find any such variable names being used; it is highly
recommended to follow standard conventions and start variable names
with an alphanumeric character
- "printenv" will now print a backslash at the end of all but the last
lines of a multi-line variable value.
Multi-line variables have never been formally defined, allthough
there is no reason not to use them. Now we define rules how to deal
with them, allowing for import and export.
- Function forceenv() and the related code in saveenv() was removed.
At the moment this is causing build problems for the only user of
this code (schmoogie - which has no entry in MAINTAINERS); may be
fixed later by implementing the "env set -f" feature.
Inconsistencies:
- "printenv" will '\\'-escape the '\n' in multi-line variables, while
"printenv var" will not do that.
Advantages:
- "printenv" output much better readable (sorted)
- faster!
- extendable (additional variable properties can be added)
- new, powerful features like "factory reset" or easy switching
between several different environment settings ("profiles")
Disadvantages:
- Image size grows by typically 5...7 KiB (might shrink a bit again on
systems with redundant environment with a following patch series)
Implemented:
- env command with subcommands:
- env print [arg ...]
same as "printenv": print environment
- env set [-f] name [arg ...]
same as "setenv": set (and delete) environment variables
["-f" - force setting even for read-only variables - not
implemented yet.]
- end delete [-f] name
not implemented yet
["-f" - force delete even for read-only variables]
- env save
same as "saveenv": save environment
- env export [-t | -b | -c] addr [size]
export internal representation (hash table) in formats usable for
persistent storage or processing:
-t: export as text format; if size is given, data will be
padded with '\0' bytes; if not, one terminating '\0'
will be added (which is included in the "filesize"
setting so you can for exmple copy this to flash and
keep the termination).
-b: export as binary format (name=value pairs separated by
'\0', list end marked by double "\0\0")
-c: export as checksum protected environment format as
used for example by "saveenv" command
addr: memory address where environment gets stored
size: size of output buffer
With "-c" and size is NOT given, then the export command will
format the data as currently used for the persistent storage,
i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and
prepend a valid CRC32 checksum and, in case of resundant
environment, a "current" redundancy flag. If size is given, this
value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32
checksum and redundancy flag will be inserted.
With "-b" and "-t", always only the real data (including a
terminating '\0' byte) will be written; here the optional size
argument will be used to make sure not to overflow the user
provided buffer; the command will abort if the size is not
sufficient. Any remainign space will be '\0' padded.
On successful return, the variable "filesize" will be set.
Note that filesize includes the trailing/terminating '\0'
byte(s).
Usage szenario: create a text snapshot/backup of the current
settings:
=> env export -t 100000
=> era ${backup_addr} +${filesize}
=> cp.b 100000 ${backup_addr} ${filesize}
Re-import this snapshot, deleting all other settings:
=> env import -d -t ${backup_addr}
- env import [-d] [-t | -b | -c] addr [size]
import external format (text or binary) into hash table,
optionally deleting existing values:
-d: delete existing environment before importing;
otherwise overwrite / append to existion definitions
-t: assume text format; either "size" must be given or the
text data must be '\0' terminated
-b: assume binary format ('\0' separated, "\0\0" terminated)
-c: assume checksum protected environment format
addr: memory address to read from
size: length of input data; if missing, proper '\0'
termination is mandatory
- env default -f
reset default environment: drop all environment settings and load
default environment
- env ask name [message] [size]
same as "askenv": ask for environment variable
- env edit name
same as "editenv": edit environment variable
- env run
same as "run": run commands in an environment variable
TODO:
- drop default env as implemented now; provide a text file based
initialization instead (eventually using several text files to
incrementally build it from common blocks) and a tool to convert it
into a binary blob / object file.
- It would be nice if we could add wildcard support for environment
variables; this is needed for variable name auto-completion,
but it would also be nice to be able to say "printenv ip*" or
"printenv *addr*"
- Some boards don't link any more due to the grown code size:
DU405, canyonlands, sequoia, socrates.
=> cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>,
Stefan Roese <sr@denx.de>,
Heiko Schocher <hs@denx.de>
- Dropping forceenv() causes build problems on schmoogie
=> cc: Sergey Kubushyn <ksi@koi8.net>
- Build tested on PPC and ARM only; runtime tested with NOR and NAND
flash only => needs testing!!
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>,
Cc: Stefan Roese <sr@denx.de>,
Cc: Sergey Kubushyn <ksi@koi8.net>
This patch adds redundant environment for environment in SPI flash.
I took env_flash.c as an example and slightly modified it. Apart
from adapting things to SF, I also slightly changed the decision
logic to use area 2 as a default in case the flags are wrong because
not having a default path worried me.
I did not add a section for CONFIG_ENV_IS_IN_SPI_FLASH in environment.h
because I did not understand if this is desired and/or needed.
So to use the feature, one has to set CONFIG_ENV_OFFSET_REDUND _and_
CONFIG_SYS_REDUNDAND_ENVIRONMENT.
I checked it by powering off my board several times during flash
erase or write, because I do not know if there are other stress
test scenarios.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
The only environment type that uses this variable is spi flash, and that is
only because it is reimplementing the common set_default_env() function.
So fix the spi flash code and kill off the default_environment_size in the
process.
If both CONFIG_ENV_SECT_SIZE and CONFIG_ENV_SIZE are defined, and the sect
size is larger than the env size, then it means the env is embedded in a
block. So we have to save/restore the part of the sector which is not the
environment. Previously, saving the environment in SPI flash in this
setup would probably brick the board as the rest of the sector tends to
contain actual U-Boot data/code.
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
The CFG_ENV_SIZE is not suitable used for SPI flash erase
sector size if CFG_ENV_SIZE is less than CFG_ENV_SECT_SIZE.
Add condition check if CFG_ENV_SIZE is larger than
CFG_ENV_SECT_SIZE, calculate the right number of sectors for
erasing.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
This is pretty incomplete...it doesn't handle reading the environment
before relocation, it doesn't support redundant environment, and it
doesn't support embedded environment. But apart from that, it does
seem to work.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
