path: root/common/env_onenand.c
2011-11-22env: clean env_onenand.c checkpatch and code styleIgor Grinberg
Cleanup the env_onenand.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: move extern environment[] to environment.hIgor Grinberg
Extract all extern declarations for environment out of c files into the environment.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: move extern default_environment[] to environment.hIgor Grinberg
Extract all extern declarations for default_environment[] out of c files into the environment.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-11-08env: allow to export only selected variablesWolfgang Denk
New syntax: env export [-t | -b | -c] [-s size] addr [var ...] With this change it is possible to provide a list of variables names that shall be exported. Whenno arguments are given, the whole environment gets exported. NOTE: The new handling of the "size" argument means a change to the user API. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-12-17hashtable: drop all non-reentrant versionsMike Frysinger
The non-reentrant versions of the hashtable functions operate on a single shared hashtable. So if two different people try using these funcs for two different purposes, they'll cause problems for the other. Avoid this by converting all existing hashtable consumers over to the reentrant versions and then punting the non-reentrant ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-01-06onenand: Fix compile errors due to FlexOneNANDSanjeev Premi
This patch fixes the compile error while trying to compile for omap3evm. env_onenand.c: In function 'env_relocate_spec': env_onenand.c:70: error: 'CONFIG_ENV_ADDR_FLEX' undeclared (first use in this function) env_onenand.c:70: error: (Each undeclared identifier is re ported only once env_onenand.c:70: error: for each function it appears in.) env_onenand.c: In function 'saveenv': env_onenand.c:106: error: 'CONFIG_ENV_ADDR_FLEX' undeclare d (first use in this function) env_onenand.c:107: error: 'CONFIG_ENV_SIZE_FLEX' undeclare d (first use in this function) Signed-off-by: Sanjeev Premi <premi@ti.com> Acked-by: Tom Rix <Tom.Rix@windriver.com>
2009-11-13ENV Variable support for Flex-OneNANDAmul Kumar Saha
Define and use CONFIG_ENV_ADDR_FLEX and CONFIG_ENV_SIZE_FLEX for storing environment variables. Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com> Signed-off-by: Amul Kumar Saha <amul.saha@samsung.com>
2009-07-27Fix compiler warnings after loff_t changeKyungmin Park
Now 'env_addr' type is loff_t so use correct field type. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-07-16MTD: OneNAND: Increase the environment size to 4KiBKyungmin Park
Also use mtd operation instead of onenand functions Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07env_onenand: change env_address type from unsigned long to loff_tHeungJun Kim
If use the onenand boot, the env_relocate_spec() calls mtd->read(), and the type of the argument #2 of mtd->read() was changed to loff_t. But, the "env_addr" type is still unsigned long, thus this patch change the type from unsigned long to loff_t. Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-06-12mtd: Update MTD infrastructure to support 64bit device sizeStefan Roese
This patch brings the U-Boot MTD infrastructure in sync with the current Linux MTD version (2.6.30-rc3). Biggest change is the 64bit device size support and a resync of the mtdpart.c file which has seen multiple fixes meanwhile. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Kyungmin Park <kmpark@infradead.org>
2008-12-02OneNAND: Add missing mtd info struct before calling onenand_erase()Stefan Roese
Without this patch "saveenv" crashes when MTD partitions are enabled (e.g. for use in UBI) via CONFIG_MTD_PARTITIONS. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-09-10env_onenand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_ONENAND in CONFIG_ENV_IS_IN_ONENANDJean-Christophe PLAGNIOL-VILLARD
2008-08-13Fix OneNAND build breakKyungmin Park
Since page size field is changed from oobblock to writesize. But OneNAND is not updated. - fix bufferram management at erase operation This patch includes the NAND/OneNAND state filed too. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-10OneNAND: Remove base address offset usagedirk.behme@googlemail.com
While locally preparing some U-Boot patches for ARM based OMAP3 boards, some using OneNAND and some using NAND, we found some differences in OneNAND and NAND command address handling. As this might confuse users (it already confused us), we like to align OneNAND and NAND address handling. The issue is that cmd_onenand.c subtracts the onenand base address from the addresses you type into the u-boot command line so, unlike nand, you can't use addresses relative to the start of the onenand part e.g. this won't work: onenand read 82000000 280000 400000 you have to use: onenand read 82000000 20280000 400000 Looking at recent git, the only board currently using OneNAND is Apollon, and for this the OneNAND base address is 0 (apollon.h) #define CFG_ONENAND_BASE 0x00000000 so patch below won't break any existing boards and will align OneNAND and NAND handling on boards where OneNAND base address is != 0. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Manikandan Pillai <mani.pillai@ti.com> Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-04-13Fix OneNAND erase commandKyungmin Park
It mis-calculates the block address. Also fix DECLARE_GLOBAL_DATA_PTR in env_onenand. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2007-11-15Remove warnings re CONFIG_EXTRA_ENV_SETTINGSPeter Pearse
Remove warnings re onenand_read() & write()
2007-09-17OneNAND support (take #2)Kyungmin Park
[PATCH 3/3] OneNAND support (take #2) OneNAND support at U-Boot Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
