path: root/common/env_nvram.c
2008-09-10env_nvram: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-05-14environment: cleanup prototype declarations of env functions.Wolfgang Denk
2008-05-12Revert "Change env_get_char from a global function ptr to a function."Wolfgang Denk
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93 which is known to break booting from dataflash and NAND.
2008-04-17Change env_get_char from a global function ptr to a function.Joakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2005-09-25Remove unneeded #include <malloc.h>Wolfgang Denk
Patch by Ladislav Michl, 22 Feb 2005
2002-12-07* Patch by Hans-Joerg Frieden, 06 Dec 2002LABEL_2002_12_07_0120wdenk
Fix misc problems with AmigaOne support * Patch by Chris Hallinan, 3 Dec 2002: minor cleanup to the MPC8245 EPIC driver * Patch by Pierre Aubert , 28 Nov 2002 Add support for external (SIU) interrupts on MPC8xx * Patch by Pierre Aubert , 28 Nov 2002 Fix nested syscalls bug in standalone applications * Patch by David Müller, 27 Nov 2002: fix output of "pciinfo" command for CardBus bridge devices. * Fix bug in TQM8260 board detection - boards got stuck when board ID was not readable
