path: root/common/env_nand.c
2011-12-06env_nand: Remove DEBUG definitionThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de>
2011-11-22env: clean env_nand.c checkpatch and code styleIgor Grinberg
Cleanup the env_nand.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: move extern environment[] to environment.hIgor Grinberg
Extract all extern declarations for environment out of c files into the environment.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: move extern default_environment[] to environment.hIgor Grinberg
Extract all extern declarations for default_environment[] out of c files into the environment.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-11-08env: allow to export only selected variablesWolfgang Denk
New syntax: env export [-t | -b | -c] [-s size] addr [var ...] With this change it is possible to provide a list of variables names that shall be exported. Whenno arguments are given, the whole environment gets exported. NOTE: The new handling of the "size" argument means a change to the user API. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-05-24env_nand: zero-initialize variable nand_erase_optionsDaniel Hobi
Commit 30486322 (nand erase: .spread, .part, .chip subcommands) added a new field to struct nand_erase_options, but forgot to update common/env_nand.c. Depending on the stack state and bad block distribution, saveenv() can thus erase more than CONFIG_ENV_RANGE bytes which may corrupt the following NAND sectors/partitions. Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-02-08NAND: env: remember the flags used in the previous environmentScott Wood
Previously, uninitialized stack space was being referenced. Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-02-02NAND: Fix saving of redundand environmentAlexander Holler
When redundand environments are used the serial needs to get increased, otherwise the old one will still be used. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2010-12-17hashtable: drop all non-reentrant versionsMike Frysinger
The non-reentrant versions of the hashtable functions operate on a single shared hashtable. So if two different people try using these funcs for two different purposes, they'll cause problems for the other. Avoid this by converting all existing hashtable consumers over to the reentrant versions and then punting the non-reentrant ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-12-06env_nand: Use nand_read_skip_bad instead of nand_readSteve Sakoman
The nand-read function returns an error code if correctable errors have occurred. This is not desirable, since the errors have been corrected! This patch switches to the nand_read_skip_bad function which does not return an error code if the errors are correctable. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Acked-by: Scott Wood <scottwood@freescale.com>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-08-13env_nand: return error when no device is foundMike Frysinger
Currently, if there is an error probing the NAND chip and the env is based in NAND, the readenv() function will use a NULL function pointer and thus jump to address 0. Here I just check for a non-zero value of blocksize as that shouldn't be zero when a valid device is found, but perhaps there is a better way for someone familiar with the NAND internals to suggest. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-07-12NAND: formatting cleanups from env.oob supportScott Wood
Change if (ok) { bunch of stuff } else { error } to if (error) { get out } proceed with bunch of stuff Plus a few whitespace cleanups. Signed-off-by: Scott Wood <scottwood@freescale.com>
2010-07-12NAND: environment offset in OOB (CONFIG_ENV_OFFSET_OOB)Ben Gardiner
This is a re-submission of the patch by Harald Welte <laforge@openmoko.org> with minor modifications for rebase and changes as suggested by Scott Wood <scottwood@freescale.com> [1] [2]. This patch enables the environment partition to have a run-time dynamic location (offset) in the NAND flash. The reason for this is simply that all NAND flashes have factory-default bad blocks, and a fixed compile time offset would mean that sometimes the environment partition would live inside factory bad blocks. Since the number of factory default blocks can be quite high (easily 1.3MBytes in current standard components), it is not economic to keep that many spare blocks inside the environment partition. With this patch and CONFIG_ENV_OFFSET_OOB enabled, the location of the environment partition is stored in the out-of-band (OOB) data of the first block in flash. Since the first block is where most systems boot from, the vendors guarantee that the first block is not a factory default block. This patch introduces the 'nand env.oob' command, which can be called from the u-boot command line. 'nand env.oob get' reads the address of the environment partition from the OOB data, 'nand env.oob set {offset,partition-name}' allows the setting of the marker by specifying a numeric offset or a partition name. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/43916 [2] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/79195 Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Harald Welte <laforge@gnumonks.org>
2010-07-04shannon/INFERNO: fix special handling of environment configurationWolfgang Denk
Remove some INFERNO related #ifdef's from common environment code by fixing the board configuration settings (add CONFIG_ENV_SECT_SIZE). While we are at it, fix comment which incorrectly talks about 4 KB environment size, while it's actually 0x4000 = 16 KiB. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Rolf Offermanns <rof@sysgo.de>
2010-01-27env_nand.c: print error message and fail gracefullyWolfgang Denk
env_nand.c would crash silently if a malloc() for the environment buffers failed; make it print an error message and fail gracefully, i. e. use the default environment then. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: John Rigby <jcrigby@gmail.com>
2009-08-09env: kill off default_environment_sizeMike Frysinger
The only environment type that uses this variable is spi flash, and that is only because it is reimplementing the common set_default_env() function. So fix the spi flash code and kill off the default_environment_size in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-16Remove legacy NAND and disk on chip code.Scott Wood
Legacy NAND had been scheduled for removal. Any boards that use this were already not building in the previous release due to an #error. The disk on chip code in common/cmd_doc.c relies on legacy NAND, and it has also been removed. There is newer disk on chip code in drivers/mtd/nand; someone with access to hardware and sufficient time and motivation can try to get that working, but for now disk on chip is not supported. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07nand_spl: read environment early, when booting from NAND using nand_splGuennadi Liakhovetski
Currently, when booting from NAND using nand_spl, in the beginning the default environment is used until later in boot process the dynamic environment is read out. This way environment variables that must be interpreted early, like the baudrate or "silent", cannot be modified dynamically and remain at their default values. Fix this problem by reading out main and redundand (if used) copies of the environment in the nand_spl code. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07env_nand: remove unused variable.Guennadi Liakhovetski
Remove an unused "total" variable in multiple functions. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-06env_nand: fix env memory releasederek@siconix.com
This fixes a bug that tmp environment memory not being released. Signed-off-by: Derek Ou <dou@siconix.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-09-10env_nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-08-12NAND: Do not write or read a whole block if it is larger than the environmentGuennadi Liakhovetski
Environment can be smaller than NAND block size, do not need to read a whole block and minimum for writing is one page. Also remove an unused variable. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-10Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2008-07-10Remove code duplication for setting the default environmentHarald Welte
common/env_common.c (default_env): new function that resets the environment to the default value common/env_common.c (env_relocate): use default_env instead of own copy common/env_nand.c (env_relocate_spec): use default_env instead of own copy include/environment.h: added default_env prototype Signed-off-by: Werner Almesberger <werner@openmoko.org> Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-07-09NAND: Fix warning due to missing env_ptr casts to u_char * in env_nand.c.Marcel Ziswiler
The writeenv() and readenv() calls introduced by the recently added bad block management for environment variables were missing casts therefore producing compile time warnings. While at it fixing some typo in a comment and indentation. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-06-28Coding Style CleanupWolfgang Denk
2008-06-16NAND: Add missing declaration to non-redundant saveenv().Philip Balister
2008-06-06env_nand.c: Added bad block management for environment variablesStuart Wood
Modified to check for bad blocks and to skipping over them when CFG_ENV_RANGE has been defined. CFG_ENV_RANGE must be larger than CFG_ENV_SIZE and aligned to the NAND flash block size. Signed-off-by: Stuart Wood <stuart.wood@labxtechnologies.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-05-28Cleanup nand_info[] declaration.Stelian Pop
The nand_info array is declared as extern in several .c files. Those days, nand.h contains a reference to the array, so there is no need to declare it elsewhere. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-04-30Fix warning in env_nand.c if compiled for DaVinci Schmoogiedirk.behme@googlemail.com
Fix warnings nv_nand.c: In function 'saveenv': env_nand.c:200: warning: passing argument 3 of 'nand_write' from incompatible pointer type env_nand.c: In function 'env_relocate_spec': env_nand.c:275: warning: passing argument 3 of 'nand_read' from incompatible pointer type if compiled for davinci_schmoogie_config. Signed-off-by: Dirk Behme <dirk.behme@gmail.com> Ack by: Sergey Kubushyn <ksi@koi8.net>
2008-04-29common/env_nand.c: fix one more incompatible pointer type issueWolfgang Denk
2008-04-28NAND: fix some strict-aliasing compiler warningsWolfgang Denk
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-09-12Add NAND environment support for PPC440EPx Sequoia NAND boot configStefan Roese
Patch by Stefan Roese, 12 Sep 2006
2006-03-24Merge with http://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2006-03-20Support for redundant environment in NAND Flash.Markus Klotzbuecher
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-08Some minor fixes to environment in NAND code.Markus Klotzbuecher
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-09-25Remove unneeded #include <malloc.h>Wolfgang Denk
Patch by Ladislav Michl, 22 Feb 2005
2004-06-19Patch by Josef Wagner, 04 Jun 2004:wdenk
- DDR Ram support for PM520 (MPC5200) - support for different flash types (PM520) - USB / IDE / CF-Card / DiskOnChip support for PM520 - 8 bit boot rom support for PM520/CE520 - Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245) - I2C and RTC support for CPC45 - support of new flash type (28F160C3T) for CPC45
