path: root/common/env_mmc.c
2011-04-04env_mmc: Allow board code to override the environment addressMingkai Hu
On some boards the environment may not be located at a fixed address in the MMC/SDHC card. This allows those boards to implement their own means to report what address the environment is located at. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Zhao Chenhui <b35336@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-12-17hashtable: drop all non-reentrant versionsMike Frysinger
The non-reentrant versions of the hashtable functions operate on a single shared hashtable. So if two different people try using these funcs for two different purposes, they'll cause problems for the other. Avoid this by converting all existing hashtable consumers over to the reentrant versions and then punting the non-reentrant ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-14env_mmc: fix compile warningLei Wen
hexport would complain implicit declaration, if we don't add the include file. env_mmc.c: In function 'saveenv': env_mmc.c:109: warning: implicit declaration of function 'hexport' Signed-off-by: Lei Wen <leiwen@marvell.com>
2010-10-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-13env_mmc: fix cannot save env issueLei Wen
The env change its implementation after this log, while env mmc didn't change it immediately, which cause issue. Follow to the new style to fix it. commit ea882baf9c17cd142c99e3ff640d3ab01daa5cec Author: Wolfgang Denk <wd@denx.de> Date: Sun Jun 20 23:33:59 2010 +0200 New implementation for internal handling of environment variables. Signed-off-by: Lei Wen <leiwen@marvell.com>
2010-10-13env_mmc: Fix crashing bug encountered after enabling ARM relocationSteve Sakoman
The crash was occuring in env_relocate because it was being called prior to mmc_initialize. This patch moves the MMC initialization earlier in the init process. This patch also cleans up the env_relocate_spec code in env_mmc.c Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Acked-by: Stefano Babic <sbabic@denx.de>
2010-10-06env_mmc: Fix broken build due to set_default_env() changeSteve Sakoman
Previously the function was set_default_env(void), it is now set_default_env(const char *s). This patch adds the required parameter. This fixes a broken build on OMAP4430 SDP. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org>
2010-09-19Save environment data to mmc.Terry Lv
This patch is to save environment data to mmc card. It uses interfaces defined in generic mmc. Signed-off-by: Terry Lv <r65388@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
