path: root/common/env_dataflash.c
2008-09-10env_dataflash: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_DATAFLASH in CONFIG_ENV_IS_IN_DATAFLASHJean-Christophe PLAGNIOL-VILLARD
2008-02-14AT91CAP9 supportStelian Pop
--------------------------------- read_dataflash() takes a signed char pointer as a parameter. Silence a few warnings dues to incorrect parameter types in env_dataflash.c. Signed-off-by: Stelian Pop <stelian@popies.net>
2005-09-25Remove unneeded #include <malloc.h>Wolfgang Denk
Patch by Ladislav Michl, 22 Feb 2005
2003-12-06* Patch by Nicolas Lacressonnière, 12 Nov 2003:wdenk
update for for Atmel AT91RM9200DK development kit: - support for environment variables in DataFlash - Atmel DataFlash AT45DB1282 support * Patch by Jeff Carr, 11 Nov 2003: add support for new version of 8270 processors * Patches by George G. Davis, 05 Nov 2003: - only pass the ARM linux initrd tag to the kernel when an initrd is actually present - update omap1510inn configuration file
