path: root/common/env_common.c
2008-07-10Remove code duplication for setting the default environmentHarald Welte
common/env_common.c (default_env): new function that resets the environment to the default value common/env_common.c (env_relocate): use default_env instead of own copy common/env_nand.c (env_relocate_spec): use default_env instead of own copy include/environment.h: added default_env prototype Signed-off-by: Werner Almesberger <werner@openmoko.org> Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-07-09Change env_get_char from a global function ptr to a functionJoakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-06-03Add support for environment in SPI flashHaavard Skinnemoen
This is pretty incomplete...it doesn't handle reading the environment before relocation, it doesn't support redundant environment, and it doesn't support embedded environment. But apart from that, it does seem to work. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-12Revert "Change env_get_char from a global function ptr to a function."Wolfgang Denk
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93 which is known to break booting from dataflash and NAND.
2008-04-17Change env_get_char from a global function ptr to a function.Joakim Tjernlund
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2004-06-09Patch by Jian Zhang, 20 May 2004:wdenk
add support for environment in NAND flash
2004-05-29Fix CONFIG_ETH*ADDR for Ocotea board.LABEL_2004_05_29_1850wdenk
Sort Makefile. Update docs.
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-12-07* Patch by Hans-Joerg Frieden, 06 Dec 2002LABEL_2002_12_07_0120wdenk
Fix misc problems with AmigaOne support * Patch by Chris Hallinan, 3 Dec 2002: minor cleanup to the MPC8245 EPIC driver * Patch by Pierre Aubert , 28 Nov 2002 Add support for external (SIU) interrupts on MPC8xx * Patch by Pierre Aubert , 28 Nov 2002 Fix nested syscalls bug in standalone applications * Patch by David Müller, 27 Nov 2002: fix output of "pciinfo" command for CardBus bridge devices. * Fix bug in TQM8260 board detection - boards got stuck when board ID was not readable
2002-09-28Initial revisionwdenk
