One of my monitors have only 4k@60 timing in base EDID block which is
out of range for devices with HDMI 1.4. It turns out that it has
additional detailed timings in CTA-861 Extension Block and two of them
are appropriate for HDMI 1.4.
Add additional search for valid detailed timing in extension block.
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Acked-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Code which searches for valid detailed timing entry will be used in more
places. Extract it.
No functional change is made. However, descriptors are casted to
edid_detailed_timing instead of edid_monitor_descriptor. Descriptor can
be of either type, but since we're interested only in DTD, it is more
fitting to cast to edid_detailed_timing.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
When searching for detailed timing in EDID, check for digital display
earlier. There is no point parsing other parameters if this flag is not
present.
Move this header out of the common header.
Add a condition to the break in the modes lookup, without this
when the first mode is not valid, then edid_get_timing_validate()
return an error instead of checking the next modes.
Fixes: 1c1ed441b0d1 ("edid: add edid_get_timing_validate() variant to filter out edid modes")
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
The original edid_get_timing() function returns the first valid timing,
but on some plaforms, we could only supports a subset of the listed
monitot's navite timing.
Let's introduce a edid_get_timing_validate() adding a mode_valid callback
including a private cookie pointer.
If the callback returns false, the current timing is discared and the next
one is checked. If no valid & supported timings are found, the function
would return an error.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We should not use an open-coded value here. Use sizeof() instead.
Reported-by: Coverity (CID: 163252)
Fixes: 43c6bdd0 (edid: Add HDMI flag to timing info)
This commit fixes the warning produced by gcc 7.1.
Some DVI monitors don't show anything in HDMI mode since audio stream
confuses them. To solve this situation, this commit adds HDMI flag in
timing data and sets it accordingly during edid parsing.
First existence of extension block is checked. If it exists and it is
CEA861 extension, then data blocks are checked for presence of HDMI
vendor specific data block. If it is present, HDMI flag is set.
Timing flags are never set, so they may contain garbage. Since some
drivers check them, video output may be broken on those drivers.
Initialize them to 0 and check for few common flags.
For digital displays (such as EDP LCDs) we would like to read the EDID
information and use that to set display timings. Provide a function to do
this.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add a helper function to check the checksum of an EDID data block.
Acked-by: Anatolij Gustschin <agust@denx.de>
[trini: Fixup common/cmd_io.c]
This implements a library for accessing EDID data from an LCD panel.
This is used to obtain information about the panel such as its
resolution and type.
This is a tidied-up version of the original code pulled from
https://github.com/ynezz/u-boot-edid.
The changes we made are:
- removed bit fields in the struct;
- removed endianness cases in the struct;
- fixed some wrong definitions;
- fixed to fit 80 columns;
- fixed some code styles.
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
