Signed-off-by: Karl Beldan <karl.beldan@gmail.com>
When malloc() was called before it was properly initialized
(as would happen if when used before relocation to RAM) it returned
random, non-NULL values, which called all kinds of difficult to debug
subsequent errors.
Make sure to return NULL when initialization was not done yet.
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Add #ifdefs where necessary to not perform relocation fixups. This
allows boards/architectures which support relocation to trim a decent
chunk of code.
Note that this patch doesn't add #ifdefs to architecture-specific code
which does not support relocation.
If common.h isn't first we can get CONFIG_ options defined in the
board config file ignored. This can cause an issue if any of those
config options impact the size of types of data structures
(eg CONFIG_PHYS_64BIT).
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
