Reinitialize DFU USB gadget after flashing the 'SCRIPT' entity to ensure
that the potential changes to the 'dfu_alt_info' environment variable are
applied.
[lukma - I've moved the bool retry to avoid build (CI) errors]
Move this header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
When the `dfu` command is called from the U-Boot environment,
it now accepts an optional parameter that specifies a timeout (in seconds).
If a DFU connection is not made within that time the `dfu` command exits
(as it would if Ctrl+C was pressed). If the timeout is left empty or being
zero the `dfu` command behaves as it does now.
This is useful for allowing U-Boot to check to see if anything wants to
upload new firmware before continuing to boot.
The patch is based on the commit
https://github.com/01org/edison-u-boot/commit/5e966ccc3c65c18c9783741fa04e0c45e021780c
by Sebastien Colleur, which has been heavily reworked due to U-Boot changes
in the past.
Signed-off-by: Brad Campbell <bradjc5@gmail.com>
Add 2 functions to wrap the calls to board_usb_init() and
board_usb_cleanup().
This is a preparatory work for DM support for UDC drivers (DM_USB_GADGET).
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
U-Boot widely uses error() as a bit noisier variant of printf().
This macro causes name conflict with the following line in
include/linux/compiler-gcc.h:
# define __compiletime_error(message) __attribute__((error(message)))
This prevents us from using __compiletime_error(), and makes it
difficult to fully sync BUILD_BUG macros with Linux. (Notice
Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().)
Let's convert error() into now treewide-available pr_err().
Done with the help of Coccinelle, excluing tools/ directory.
The semantic patch I used is as follows:
// <smpl>
-error
+pr_err
// </smpl>
[trini: Re-run Coccinelle]
The SPL-DFU feature enable to load and
execute u-boot from RAM over usb from
PC using dfu-util.
Hence dfu-reset should not be issued
when dfu-util -R switch is issued.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
board_usb_init() can failed and error should be handled properly.
Without this, if g_dnl_register() fails, DFU code continues on
blindly and crashes. This fix makes it simply print an error
message instead.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
[l.majewski@samsung.com - some manual tweaks needed]
The cmd_dfu functionality is been used by both SPL and
u-boot, saperating the core dfu functionality moving
it to common/dfu.c.
