path: root/common/dfu.c
2018-12-07usb: gadget: Do not call board_usb_xxx() directly in USB gadget driversJean-Jacques Hiblot
Add 2 functions to wrap the calls to board_usb_init() and board_usb_cleanup(). This is a preparatory work for DM support for UDC drivers (DM_USB_GADGET). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-12common: dfu: ignore reset for spl-dfuB, Ravi
The SPL-DFU feature enable to load and execute u-boot from RAM over usb from PC using dfu-util. Hence dfu-reset should not be issued when dfu-util -R switch is issued. Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-11-03cmd: dfu: Add error handling for board_usb_initMichal Simek
board_usb_init() can failed and error should be handled properly. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-27cmd: dfu: Add error handling for failed registrationSanchayan Maity
Without this, if g_dnl_register() fails, DFU code continues on blindly and crashes. This fix makes it simply print an error message instead. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> [l.majewski@samsung.com - some manual tweaks needed]
2016-09-27common: dfu: saperate the dfu common functionalityB, Ravi
The cmd_dfu functionality is been used by both SPL and u-boot, saperating the core dfu functionality moving it to common/dfu.c. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
