path: root/common/console.c
2010-11-28stdio: constify "name" arg in public apiMike Frysinger
2010-07-04Make *printf() return "int" instead of "void"Wolfgang Denk
Change the return type of the *printf() functions to the standard "int"; no changes are needed but returning the already available length count. This will save a few additional strlen() calls later... Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-23Remove AmigaOneG3SE boardWolfgang Denk
The AmigaOneG3SE board has been orphaned or a very long time, and broken for more than 12 releases resp. more than 3 years. As nobody seems to be interested any more in this stuff we may as well ged rid of it, especially as it clutters many areas of the code so it is a continuous pain for all kinds of ongoing work. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-21console.c: fix problem with splashimageAnatolij Gustschin
If a board uses cfb_console driver and splash image and also defines CONFIG_SILENT_CONSOLE, the user is locked out even if "silent" is not set. It is not possible to get any output, neither on vga console device nor on serial console after redirecting the output to the serial console, since the GD_FLG_SILENT flag remains set. Fix the problem by redirecting the output from frame buffer to serial console if splashimage is used. Only suppress the output if "silent" environment variable was set and don't set the GD_FLG_SILENT flag arbitrarily. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-08-30bugfix CONFIG_SYS_CONSOLE_INFO_QUIETDavid Brownell
The "console: unify printing current devices" patch goofed: CONFIG_SYS_CONSOLE_INFO_QUIET is supposed to *REMOVE* boot time noise, not add it. Said patch changed the #ifndefs to #ifdef; this one restores them to the proper sense. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-07-19console: unify printing current devicesJean-Christophe PLAGNIOL-VILLARD
Create stdio_print_current_devices() for this purpose Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-18common/console: avoid ifdef CONFIG_CONSOLE_MUX when it's possibleJean-Christophe PLAGNIOL-VILLARD
2009-02-18common/console: coding style cleanupJean-Christophe PLAGNIOL-VILLARD
2008-12-07IOMUX: Add console multiplexing support.Gary Jennejohn
Modifications to support console multiplexing. This is controlled using CONFIG_SYS_CONSOLE_MUX in the board configuration file. This allows a user to specify multiple console devices in the environment with a command like this: setenv stdin serial,nc. As a result, the user can enter text on both the serial and netconsole interfaces. All devices - stdin, stdout and stderr - can be set in this manner. 1) common/iomux.c and include/iomux.h contain the environment setting implementation. 2) doc/README.iomux contains a somewhat more detailed description. 3) The implementation in (1) is called from common/cmd_nvedit.c to handle setenv and from common/console.c to handle initialization of input/output devices at boot time. 4) common/console.c also contains the code needed to poll multiple console devices for input and send output to all devices registered for output. 5) include/common.h includes iomux.h and common/Makefile generates iomux.o when CONFIG_SYS_CONSOLE_MUX is set. Signed-off-by: Gary Jennejohn <garyj@denx.de>
2008-09-06Allow console input to be disabledMark Jackson
Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE. When CONFIG_DISABLE_CONSOLE is defined, setting GD_FLG_DISABLE_CONSOLE disables all console input and output. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
2008-08-31devices: merge to list_headJean-Christophe PLAGNIOL-VILLARD
2007-05-05[PATCH] simplify silent consoleLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Stefan Roese <sr@denx.de>
2005-03-31* Patch by Detlev Zundel, 31 Mar 2005:wdenk
Cleanup duplicate definition of overwrite_console() * Update TQM5200 configuration; prepare for Rev. 200 starter kit boards
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2004-02-06* Patch by Wolter Kamphuis, 15 Dec 2003:wdenk
made CONFIG_SILENT_CONSOLE usable on all architectures * Disable date command on TQM866M - there is no RTC on MPC866
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-09-29Suppress all output with splashscreen configured only if "splashimage"dzu
is set
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2003-04-20* Make sure Block Lock Bits get cleared in R360MPI flash driverwdenk
* MPC823 LCD driver: Fill color map backwards, to allow for steady display when Linux takes over * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS (this time for real). * Add support for "bmp info" and "bmp display" commands to load bitmap images; this can be used (for example in a "preboot" command) to display a splash screen very quickly after poweron. * Add support for 133 MHz clock on INCA-IP board
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
