path: root/common/console.c
2023-01-12console: Add option to keep it silent until env is loadedHarald Seiler
Add a config-option which forces the console to stay silent until the proper environment is loaded from flash. This is important when the default environment does not silence the console but no output must be printed when 'silent' is set in the flash environment. After the environment from flash is loaded, the console will be silenced/unsilenced depending on it. If PRE_CONSOLE_BUFFER is also used, the buffer will now be flushed if the console should not be silenced. Signed-off-by: Harald Seiler <hws@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-12-02console: file should always be non-negativeHeinrich Schuchardt
We use the parameter file in console functions to choose from an array after checking against MAX_FILES but we never check if the value of file is negative. Running ./u-boot -T -l and issuing the poweroff command has resulted in crashes because os_exit() results in std::ostream::flush() calling U-Boot's fflush with file being a pointer which when converted to int may be represented by a negative number. This shows that checking against MAX_FILES is not enough. We have to ensure that the file argument is always positive. Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-09-24serial: Implement serial_flush() function for console flush() fallbackPali Rohár
Like in all other console functions, implement also serial_flush() function as a fallback int console flush() function. Flush support is available only when config option CONSOLE_FLUSH_SUPPORT is enabled. So when it is disabled then provides just empty static inline function serial_flush(). Signed-off-by: Pali Rohár <pali@kernel.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-09-24console: Implement flush() functionPali Rohár
On certain places it is required to flush output print buffers to ensure that text strings were sent to console or serial devices. For example when printing message that U-Boot is going to boot kernel or when U-Boot is going to change baudrate of terminal device. Therefore introduce a new flush() and fflush() functions into console code. These functions will call .flush callback of associated stdio_dev device. As this function may increase U-Boot side, allow to compile U-Boot without this function. For this purpose there is a new config CONSOLE_FLUSH_SUPPORT which is enabled by default and can be disabled. It is a good idea to have this option enabled for all boards which have enough space for it. When option is disabled when U-Boot defines just empty static inline function fflush() to avoid ifdefs in other code. Signed-off-by: Pali Rohár <pali@kernel.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-09-19Merge branch 'master' into nextTom Rini
2022-09-18cyclic: Use schedule() instead of WATCHDOG_RESET()Stefan Roese
Globally replace all occurances of WATCHDOG_RESET() with schedule(), which handles the HW_WATCHDOG functionality and the cyclic infrastructure. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Tom Rini <trini@konsulko.com> [am335x_evm, mx6cuboxi, rpi_3,dra7xx_evm, pine64_plus, am65x_evm, j721e_evm]
2022-08-31common/console.c: prevent pre-console buffer contents from being added to itselfRasmus Villemoes
I do not have any non-serial output devices, so a print_pre_console_buffer(PRE_CONSOLE_FLUSHPOINT2_EVERYTHING_BUT_SERIAL) does nothing for me. However, I was manually inspected the pre-console buffer using md.b, and I noticed that the early part of it was repeated. The reason is that the first call of print_pre_console_buffer(), from console_init_f(), ends up invoking puts() with the contents of the buffer at that point, and puts() at that point ends up in the else branch of if (gd->flags & GD_FLG_DEVINIT) { /* Send to the standard output */ fputs(stdout, s); } else { /* Send directly to the handler */ pre_console_puts(s); serial_puts(s); } so indeed the contents is added again. That can be somewhat confusing (both when reading the buffer manually, but also if it did actually come out on some device). So disable all use of the pre-console buffer while print_pre_console_buffer() is emitting it. Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-08-10common: Drop display_options.h from common headerSimon Glass
Move this out of the common header and include it only where needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2022-05-11common/console.c: use CONFIG_VAL() with PRE_CON_BUF_* variablesRasmus Villemoes
There is currently no support for PRE_CONSOLE_BUFFER in SPL, but if and when that gets implemented, one would almost certainly want to use a different address and/or size for the buffer (e.g., U-Boot proper might specify an address in DRAM and a generous buffer, while SPL would be much more constrained). So a prerequisite for adding SPL_PRE_CONSOLE_BUFFER is to make the code use SPL_-specific values. No functional change. Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
2022-01-19doc: replace @return by Return:Heinrich Schuchardt
Sphinx expects Return: and not @return to indicate a return value. find . -name '*.c' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; find . -name '*.h' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2021-12-26console: Avoid serial output before the console is runningSimon Glass
The video driver uses this for debugging, but if used before relocation it crashes at present. Avoid trying to output debugging before the console is ready. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-11-28common: Allow a smaller console-recording pre-relocSimon Glass
Before relocation there is generally not as much available memory and not that much console output. At present the console-output buffer is the same side before and after relocation. Add a separate Kconfig option to remove this limitation. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-07-23test: add first autoboot unit testsSteffen Jaeckel
This adds tests for the crypt-based and plain SHA256-based password hashing algorithms in the autoboot flow. Signed-off-by: Steffen Jaeckel <jaeckel-floss@eyet-services.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-06-08console: Report an error when output buffer is exhaustedSimon Glass
If the console output buffer is exhausted, characters are silently dropped from the end. Detect this condition and report an error when reading back the characters. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-02-16IOMUX: Split out for_each_console_dev() helper macroAndy Shevchenko
It is not only less lines of code, but also better readability when new macro is being in use. Introduce for_each_console_dev() helper macro and convert current users to it. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2021-02-16IOMUX: Split out iomux_match_device() helperAndy Shevchenko
Deduplicate the code used in a few places by splitting out a common helper. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2021-02-16console: Set file and devices at one goAndy Shevchenko
Logical continuation of the change that brought console_devices_set() is to unify console_setfile() with it and replace in the callers. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2021-02-16console: Set console device counter in console_devices_set()Andy Shevchenko
console_devices_set() missed the console device counter to be set correctly. Fixes: 45375adc9799 ("console: add function console_devices_set") Cc: Patrick Delaunay <patrick.delaunay@foss.st.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2021-02-16console: Switch to use stdio_file_to_flags()Andy Shevchenko
Deduplicate code by replacing with stdio_file_to_flags() helper. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-01-16console: cosmetics: remove #if 0Patrick Delaunay
Remove the #if 0 present since the first version of console.c Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-15console: rename search_device() to console_search_dev()Andy Shevchenko
Rename search_device() to console_search_dev() since it's in console.h. Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-15console: Keep ->start() and ->stop() balancedAndy Shevchenko
There is no need to call ->start() for already started device. All the same, there is no need to call ->stop() for devices still in use. For now enforce this only for IOMUX case. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-15console: Introduce console_start() and console_stop()Andy Shevchenko
In the future we would like to stop unused consoles and also add a reference counting to avoid imbalanced calls to ->start() and ->stop() in some cases. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-15console: add console_has_tstc helper function for CONSOLE_MUXPatrick Delaunay
Add the helper function console_has_tstc() and replace the test #if CONFIG_IS_ENABLED(CONSOLE_MUX) to a simple 'if' test to respect the U-Boot coding rule. No functional change. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-15console: remove #ifdef CONFIG_CONSOLE_RECORDPatrick Delaunay
Add helper functions to access to gd->console_out and gd->console_in with membuff API and replace the #ifdef CONFIG_CONSOLE_RECORD test by if (IS_ENABLED(CONFIG_CONSOLE_RECORD)) to respect the U-Boot coding rule. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-15console: add function console_devices_setPatrick Delaunay
Add a new function to access to console_devices only defined if CONFIG_IS_ENABLED(CONSOLE_MUX). This path allows to remove #if CONFIG_IS_ENABLED(CONSOLE_MUX) in console_getc function. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
2021-01-15console: remove #ifdef CONFIG when it is possiblePatrick Delaunay
Remove #ifdef or #ifndef for CONFIG when it is possible to simplify the console.c code and respect the U-Boot coding rules. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-15console: allow to record console output before readyPatrick Delaunay
Allow to record the console output before before U-Boot has a console ready. This patch allows to test the console output in sandbox test based on console record. It is possible because GD_FLG_RECORD and GD_FLG_SERIAL_READY are 2 independent flags. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-15console: remove duplicated test on gd valuePatrick Delaunay
Reorder test on gd value and remove the duplicated test (!gd) in putc and puts function. This patch is a preliminary step for rework of this function. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-10-22common: rename getc() to getchar()Heinrich Schuchardt
The sandbox is built with the SDL2 library with invokes the X11 library which in turn calls getc(). But getc() in glibc is defined as int getc(FILE *) This does not match our definition. int getc(void) The sandbox crashes when called with parameter -l. Rename our library symbol getc() to getchar(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-07console: Always define the console-recording functionsSimon Glass
On boards without console recording these function are currently missing. It is more convenient for them to be present but to return dummy values. That way if we know that a test needs recording, we can check if it is available, and skip the test if not, while avoiding #ifdefs. Update the header file according and adjust console_record_reset_enable() to return an error if recording is not available. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-07-09console: Add a way to output to serial onlySimon Glass
In the video drivers it is useful to print errors while debugging but doing so risks an infinite loop as the debugging info itself may go through the video drivers. Add a new console function that prints information only to the serial device, thus making it safe for use in debugging. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-07-06video: restore CONFIG_VIDCONSOLE_AS_LCD as booleanPatrick Delaunay
This patch restores CONFIG_VIDCONSOLE_AS_LCD as boolean and introduce a separate sting as CONFIG_VIDCONSOLE_AS_NAME to search this string in stdout used as videoconsole. This patch avoid issue with board defconfig or code expecting CONFIG_VIDCONSOLE_AS_LCD as boolean. Fixes: 22b897a12323 ("video: extend stdout video console work-around for 'vga'") Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-06-18video: extend stdout video console work-around for 'vga'Anatolij Gustschin
cfb_console driver uses 'vga' console name and we still have board environments defining this name. Re-use existing DM_VIDEO work- around for console name to support 'vga' name in stdout environment. Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Soeren Moch <smoch@web.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-13common/console.c: discard volatileHeinrich Schuchardt
Avoid errors of like common/console.c: In function ‘console_record_reset’: common/console.c:615:16: error: passing argument 1 of ‘membuff_purge’ discards ‘volatile’ qualifier from pointer target type [-Werror=discarded-qualifiers] 615 | membuff_purge(&gd->console_out); | ^~~~~~~~~~~~~~~~ by casting to non-volatile. The volatile property stems from declarations like arch/arm/include/asm/global_data.h:114: But there is no need to treat gd->console_out and gd->console_in as volatile in the context of common/console.c. Fixes: b612312816ff ("console: Add a function to read a line of the output / eof") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-02-05console: Add a function to read a line of the output / eofSimon Glass
When recording the console output for testing it is useful to be able to read the output a line at a time to check that the output is correct. Also we need to check that we get to the end of the output. Add a console function to return the next line and another to see how must data is left. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-11-06common/console.c: Fix unused warning with console_doenv()Tom Rini
Newer versions of LLVM-7 will provide an unused function warning over console_doenv() in the case of SYS_CONSOLE_IS_IN_ENV not being enabled as can be the case in SPL. Add guards around this function. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-07console: execute flush on uart when silent is removedPatrick Delaunay
Avoid to flush buffer when silent console is activated as the console can be reactivate later, after relocation, when the env will be updated with the saved one. Solve issue (missing beginning of U-Boot trace) when: - CONFIG_SILENT_CONSOLE is activated - silent=1 is defined in default environment (CONFIG_EXTRA_ENV_SETTINGS) - silent is removed in saved environment with: > env delete silent; env save Only functional when PRE_CONSOLE_BUFFER is activated. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-08-07console: update silent tag after env loadPatrick Delaunay
Update the "silent" property with the variable "silent" get from saved environment, it solves the issue when: - CONFIG_SILENT_CONSOLE and CONFIG_SYS_CONSOLE_IS_IN_ENV are activated - silent is not defined in default environment - silent is requested in saved environment with: > env set silent 1; env save On next reboot the console is not disabled as expected after relocation and the environment load from flash (the callback is not called when the INSERT is requested in the created hash table) Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-11-26sandbox: Allow puts() output before global_data is set upSimon Glass
We support putc() in this case but not puts(), but this is more useful since it is what printf() uses. This particularly affects debugging early in SPL, where currently printf() statements result in no output. Fix this by adding a special case into puts() for sandbox, just like putc(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-09-10console: unify fgetc function when console MUX is deactivatedPatrick Delaunay
Unify the fgetc function when MUX is activated or not: - always call tstc() : it is the normal behavior expected by serial uclass (call tstc then getc) and that avoids issue when SERIAL_RX_BUFFER is activated - reload WATCHDOG in the char waiting loop This patch allow to have the same behavior when CONSOLE_MUX is activated or not and avoid regression when this feature is deactivated. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-26sandbox: Don't disable ctrlc() on sandbox if in raw modeJoe Hershberger
In raw mode, handle ctrl-c as normal. This allows normal ctrl-c behavior such as aborting a command that is timing out without completely terminating the sandbox executable. In [1], Simon disabled this. His reason for it was that it interferes with piping test scripts. Piping should be done in cooked mode, so this change should still not interfere. [1] commit 8969ea3e9f2db04a6b3675 ("sandbox: Disable Ctrl-C") Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-26console: Remember if ctrlc is disabled in console_tstc()Joe Hershberger
We don't necessarily want to re-enable ctrl-c if it was already disabled when calling tstc(). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-18console: Fix handling of NULL global_dataSimon Glass
Both putc() and puts() can be called before global_data is set up. Some of the code paths don't handle this correctly. Add an explicit test before any member is accessed. Reported-by: Coverity (CID: 169030) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-05-06stdio_names: Ensure MAX_NAMES is defined before use, don't use 3 directlyTom Rini
With tighter build flags the fact that <stdio_dev.h> doesn't have a reference back to MAX_NAMES causes an error. Include <stdio.h> here and then in common/console.c use MAX_NAMES rather than 3 when working with stdio_names. Reported-by: Peter Robinson <pbrobinson@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Peter Robinson <pbrobinson@gmail.com>
