path: root/common/common_fit.c
2018-11-09common: Compile error with CONFIG_MULTI_DTB_FIT and not SPLLars Povlsen
common/common_fit.c is including <spl.h>, but not actually using it. The inclusion will cuase compile error on platforms using CONFIG_OF_SEPARATE and not SPL. Signed-off-by: Lars Povlsen <lars.povlsen@microsemi.com> Reviewed-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-11-09fit: Add missing CR in debug output in fit_find_config_node()Stefan Roese
Testing has shown that a line-break is missing in one debug line in fit_find_config_node(). Signed-off-by: Stefan Roese <sr@denx.de>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-05fit: If no matching config is found in fit_find_config_node(), use the ↵Jean-Jacques Hiblot
default one If board_fit_config_name_match() doesn't match any configuration node, then use the default one (if provided). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-10spl: fit: Break out some functions into a common fileCooper Jr., Franklin
Some of the functions within spl_fit will be used for non spl purposes. Instead of duplicating functions simply break the functions to be reused into its own file. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Only add the new define to image.h, otherwise we see breakage due to massive include leakage into host tools in some cases] Signed-off-by: Tom Rini <trini@konsulko.com>
