From Logic BSP-2.0-5-01
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
To use YAFFS2 define CONFIG_YAFFS2
Signed-off-by: William Juul <william.juul@tandberg.com>
