This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Add 'imgextract' command: extract one part of a multi file image.
