path: root/common/cmd_vfd.c
2008-09-10cmd_vfd: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[p-x]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-09-11* Patch by Martin Krause, 11 Sep 2003:LABEL_2003_09_12_0110wdenk
add burn-in tests for TRAB board * Enable instruction cache on MPC5200 board
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-05-21Add support for arbitrary bitmaps for TRAB's VFD command;LABEL_2003_05_22_2230wdenk
allow to pass boot bitmap addresses in environment variables; allow for zero boot delay
2003-05-20* Add support for arbitrary bitmaps for TRAB's VFD commandLABEL_2003_05_20_2250wdenk
* Patch by Christian Geißinger, 19 May 2002: On TRAB: wait until the dummy byte has been completely sent
2002-11-04Patch by Guillaume Alexandre,, 04 Nov 2002:wdenk
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code
2002-11-01Initial revisionwdenk
