path: root/common/cmd_usb_mass_storage.c
2014-01-13usb: ums: wait for usb cable connection before enter ums modePrzemyslaw Marczak
Before this change ums mode can not be entered when device was using the same usb port for usb/uart communication. Switching USB cable from UART to USB always causes ums exit. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
2013-11-08usb: ums: add ums exit feature by ctrl+c or by detach usb cablePrzemyslaw Marczak
This patch allows exiting from UMS mode to u-boot prompt by detaching usb cable or by pressing ctrl+c. Add new config: CONFIG_USB_CABLE_CHECK. If defined then board file should provide function: usb_cable_connected() (include/usb.h) that return 1 if cable is connected and 0 otherwise. Changes v2: - add a note to the README Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-11-08usb: ums: allows using every mmc device with ums.Przemyslaw Marczak
Before this change ums command only allowed use of mmc 0. Now this argument can be set. Changes: - remove mmc device number checking because it is always positive number - remove printing "no such device" - it is done by find_mmc_device() Change-Id: I767e45151ad515c7bef19e6c13087374f5e23c11 Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-11-08usb: ums: code refactoring to improve reusability on other boards.Przemyslaw Marczak
This patch introduces some cleanups to ums code. Changes: ums common: - introduce UMS_START_SECTOR and UMS_NUM_SECTORS as defined in usb_mass_storage.h both default values as 0 if board config doesn't define them common cleanup changes: - change name of struct "ums_board_info" to "ums" - "ums_device" fields are moved to struct ums and "dev_num" is removed - change function name: board_ums_init to ums_init - remove "extern" prefixes from usb_mass_storage.h cmd_usb_mass_storage: - change error() to printf() if need to print info message - change return values to command_ret_t type at ums command code - add command usage string Changes v2: ums common: - always returns number of read/write sectors - coding style clean-up ums gadget: - calculate amount of read/write from device returned value. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-09-24usb:gadget:Remove redundant #includes for USB composite gadget and its functionsLukasz Majewski
Only the <linux/usb/gadget.h> requires error.h include. Hence, several includes of error.h at USB gadget functions are not needed. Moreover unnecessary malloc.h includes were also removed. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-03-18usb:gadget: USB Mass Storage Gadget supportLukasz Majewski
This patch adds the USB Mass Storage Gadget to u-boot New command called "ums" is implemented to provide access to on-device embedded persistent memory. USB Mass Storage is supposed to work on top of the USB Gadget framework Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Marek Vasut <marek.vasut@gmail.com>
