path: root/common/cmd_usb.c
2008-11-28Remove obsolete command (apply afte USB style patch, 80 chars strict)Michael Trimarchi
Remove USB obsolete commmand Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2008-11-28USB style patch, 80 chars strictMichael Trimarchi
USB Code style patch Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-10Fix "usb part" commandChristian Eggers
Only print partition for selected device if user supplied the <dev> arg with the "usb part [dev]" command. Signed-off-by: Christian Eggers <ceggers@gmx.de> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-06-30Delay FIT format check on sector based devicesMarian Balakowicz
Global FIT image operations like format check cannot be performed on a first sector data, defer them to the point when whole FIT image was uploaded to a system RAM. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Partial ('cmd_nand' case) Acked-by: Grant Erickson <gerickson@nuovations.com> NAND and DOC bits Acked-by: Scott Wood <scottwood@freescale.com>
2008-03-26Merge branch 'master_merge_new-image' of /home/tur/git/u-bootWolfgang Denk
2008-03-26USB Storage, add meaningful return valueAras Vaichas
This patch changes the "usb storage" command to return success if it finds a USB storage device, otherwise it returns error. Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-03-12[new uImage] Add new uImage format handling to other bootm related commandsMarian Balakowicz
Updated commands: docboot - cmd_doc.c fdcboot - cmd_fdc.c diskboot - cmd_ide.c nboot - cmd_nand.c scsiboot - cmd_scsi.c usbboot - cmd_usb.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-21[new uImage] Fix erroneous use of image_get_magic() in fdc/usb cmdsMarian Balakowicz
2008-02-21[new uImage] Rename and move print_image_hdr() routineMarian Balakowicz
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-08common/cmd_[p-x]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-08-03Prevent USB commands from working when USB is stopped.Bartlomiej Sieka
2006-08-02Add rudimentary handling of alternate settings of USB interfaces - to fixBartlomiej Sieka
problems with some USB storage devices. Some code readability improvements.
2005-08-02Coding style cleanupWolfgang Denk
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2005-06-27* Fix baudrate calculation problem on MPC5200 systemswdenk
* Add MPC8220 boards to MAKEALL script * Add EEPROM and RTC support for HMI1001 board * Patch by Detlev Zundel, 20 Jun 2005: Fix initialization of low active GPIO pins on inka4x0 board
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2005-02-24Cleanup USB and partition defineswdenk
2005-02-04Fix for incomplete byteorder fix in cmd_scsi.c and cmd_usb.cwdenk
2005-02-04Fix byteorder problem in usbboot and scsiboot commands.wdenk
2005-02-03* Removed '--no-warn-mismatch' option from Makefile. This optionwdenk
makes 'ld' to overlook binary objects compatibility. * Moved $(PLATFORM_LIBS) from the library group (--start-group ... --end-group) outside of the group. This will make 'ld' to do _multiple_ search in the library group when resolving symbol references and do only a _single_ seach in libgcc.a after the group search. * Fix stability problems on CPC45 board again. * Make image detection for diskboot / usbboot / scsiboot more robust (also check header checksum)
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2003-12-07* Patches by David Müller, 14 Nov 2003:wdenk
- board/mpl/common/common_util.c * implement support for BZIP2 compressed images * various cleanups (printf -> puts, ...) - board/mpl/common/flash.c * report correct errors to upper layers * check the erase fail and VPP low bits in status reg - board/mpl/vcma9/cmd_vcma9.c - board/mpl/vcma9/flash.c * various cleanups (printf -> puts, ...) - common/cmd_usb.c * fix typo in comment - cpu/arm920t/usb_ohci.c * support for S3C2410 is missing in #if line - drivers/cs8900.c * reinit some registers in case of error (cable missing, ...) - fs/fat/fat.c * support for USB/MMC devices is missing in #if line - include/configs/MIP405.h - include/configs/PIP405.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support - include/configs/VCMA9.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support * enable USB support - lib_arm/armlinux.c * change calling convention of ARM Linux kernel as described on http://www.arm.linux.org.uk/developer/booting.php * Patch by Thomas Lange, 14 Nov 2003: Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to support all these AMD boards. * Patch by Thomas Lange, 14 Nov 2003: Workaround for mips au1x00 physical memory accesses (the au1x00 uses a 36 bit bus internally and cannot access physical memory directly. Use the uncached SDRAM address instead of the physical one.)
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-04-27* LWMON extensions:wdenk
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU
2002-08-27Initial revisionwdenk
