path: root/common/cmd_trace.c
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-26Add a trace commandSimon Glass
Add a trace command with sub-commands to start/stop tracing, print out statistics and dump trace information to memory for later upload to a host. Signed-off-by: Simon Glass <sjg@chromium.org>
