path: root/common/cmd_strings.c
2010-08-09various cmd_* files: fixed layout a little bitFrans Meulenbroeks
Most of the files have U_BOOT_CMD on a separate line, but a few didn't and had the first line on the same line as U_BOOT_CMD. This changes these files by adding a line break and a tab Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-12-07strings: use puts() rather than printf()Mike Frysinger
When running `strings` on really long strings, the stack tends to get smashed due to printf(). Switch to puts() instead since we're only passing the data through. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-14strings cmd: drop old CONFIG_CFG_STRINGS defineMike Frysinger
We don't need CONFIG_CFG_STRINGS anymore now that we have the define CONFIG_CMD_STRINGS and Makefile control. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04new command for displaying strings at specified memory locationsMike Frysinger
