This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
- update README (SHOW_BOOT_PROGRESS values for cmd_nand.c and
env_common.c)
- sbc8260 tweaks
- adjust "help" output
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Change behaviour of NetLoop(): return -1 for errors, filesize
otherwise; return code 0 is valid an means no file loaded - in this
case the environment still gets updated!
* Patches by Jon Diekema, 9 Nov 2002:
- improve ADC/DAC clocking on the SACSng board to align
the failing edges of LRCLK and SCLK
- sbc8260 configuration tweaks
- add status LED support for 82xx systems
- wire sspi/sspo commands into command handler; improved error
handlering
- add timestamp support and alternate memory test to the
SACSng configuration
