path: root/common/cmd_sf.c
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-06-03SPI Flash: Add "sf" commandHaavard Skinnemoen
This adds a new command, "sf" which can be used to manipulate SPI flash. Currently, initialization, reading, writing and erasing is supported. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
