path: root/common/cmd_setexpr.c
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-23Prepare v2010.06-rc3v2010.06-rc3Wolfgang Denk
2010-03-21cmd_setexpr: allow memory addresses in expressionsFrans Meulenbroeks
This patch add functionality to use memory addresses in expressions. This increases the power of expressions substantially It adheres to the standard convemtions: memory addresses can be given in the format *address (e.g. *1000) Rationale for this change is that it allows masking off bits from a byte that is obtained by reading data from e.g. i2c. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Fix warning: control reaches end of non-void function Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-03-25Add setexpr commandKumar Gala
Add a simple expr style command that will set an env variable as the result of the command. This allows us to do simple math in shell. The following operations are supported: &, |, ^, +, -, *, /. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
