Adjust the SCSI command to use driver model for its PCI interface.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Commit 2b42c9317db ("ahci: support LBA48 data reads for 2+TB drives")
introduced conditional code which triggers a warning when compiled
with DEBUG enabled:
In file included from common/cmd_scsi.c:12:0:
common/cmd_scsi.c: In function 'scsi_read':
include/common.h:109:4: warning: 'smallblks' may be used uninitialized in this function [-Wmaybe-uninitialized]
Since this is for debug only, take the easy way and initialize the
variable explicitly on declaration to avoid the warning.
(Fix a nearby whitespace error on the way.)
Signed-off-by: Andre Przywara <osp@andrep.de>
Enable full 48-bit LBA48 data reads by passing the upper word of the
LBA block pointer in bytes 9 and 10 of the FIS.
This allows uboot to load data from any arbitrary sector on a drive
with 2 or more TB of available data connected to an AHCI controller.
Signed-off-by: Mark Langsdorf <mark.langsdorf@gmail.com>
[trini: Make use of CONFIG_SYS_64BIT_LBA in a few places to drop
warnings on platforms that don't enable that feature ]
Current driver assumes the AHCI is connected to PCI, this is not
true on some SoCs, e.g. LS1021A, which has PCI but the AHCI is
in SoC. This patch will enable embedded AHCI devices on platforms
with PCI.
PCI AHCI devices still can be used by commenting CONFIG_SCSI_AHCI_PLAT
option in head file.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
On some hardware this time can be significant. Add bootstage support for
measuring this. The result can be obtained using 'bootstage report' or
passed on to the Linux via the device tree.
Use the inttypes header file to provide this.
Add spl_sata to read a fat partition from a bootable SATA
drive.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Reviewed-by: Roger Quadros <rogerq@ti.com>
[trini: Fixup common/cmd_io.c]
The block device expects to see lbaint_t for the blknr parameter. Change
the SCSI read/write functions to suit.
This fixes the following build warnings for coreboot:
cmd_scsi.c: In function ‘scsi_scan’:
cmd_scsi.c:119:30: error: assignment from incompatible pointer type [-Werror]
cmd_scsi.c:120:32: error: assignment from incompatible pointer type [-Werror]
log2 of the device block size serves as the shift value used to calculate
the block number to read in file systems when implementing avaiable block
sizes.
It is needed quite often in file systems thus it is pre-calculated and
stored in the block device descriptor.
Signed-off-by: Egbert Eich <eich@suse.com>
'bool' is defined in random places. This patch consolidates them into a
single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with
true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true.
Skip *.py, *.php, lib/* files.
Signed-off-by: York Sun <yorksun@freescale.com>
Capacity needs to allow for a 64-bit value.
Signed-off-by: Gabe Black <gabeblack@google.com>
Add a new function to find out the number of available SCSI disks. Also
set the 'scsidevs' environment variable after each scan.
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
Implement write functionality in the scsi layer. A ''scsi write'
command is also added to console for testing.
Signed-off-by: Hung-Te Lin <hungte@chromium.org>
Many AHCI controllers are identical, the main (and often the
only) difference being the PCI Vendor ID/Device ID combination
reported by the device.
This change allows the config file to define a list of PCI vendor
ID/device ID pairs. The driver would scan the list and initialize
the first device it finds.
No actual multiple device list is introduced yet, this change
just add the framework.
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Signed-off-by: Taylor Hutt <thutt@chromium.org>
All the raw block load commands duplicate the same code. Starting with
the ide version as it has progress updates convert ide, usb, and scsi boot
commands to all use a common version.
Change all files in common/ to use CMD_RET_USAGE instead of calling
cmd_usage() directly. I'm not completely sure about this patch since
the code since impact is small (100 byte or so on ARM) and it might
need splitting into smaller patches. But for now here it is.
If we don't want to build support for any partition types we can now
add #undef CONFIG_PARTITIONS in a board config file to keep this from
being compiled in. Otherwise boards assume this is compiled in by
default
Signed-off-by: Matthew McClintock <msm@freescale.com>
Add support for AHCI controllers that are not PCI based.
Rather than having a bunch of random commands handle autostart behavior,
unify the logic in a single place. This also fixes building of these
different commands when bootm is disabled.
Acked-by: Matthew McClintock <msm@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
This reverts commit 5a442c0addc69d0c4b58e98e5aec1cf07576debb.
This commit changed the behaviour of getenv_yesno() (both the default
behaviour and the documented behaviour for abbreviated arguments)
which resulted in problems in several areas.
Use the new helper func to clean up duplicate logic handling of the
autostart env var.
The duplication of the do_bootm prototype has gotten out of hand,
and they're pretty much all outdated (wrt constness). Unify them
all in command.h.
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Global FIT image operations like format check cannot be performed on
a first sector data, defer them to the point when whole FIT image was
uploaded to a system RAM.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Partial ('cmd_nand' case) Acked-by: Grant Erickson <gerickson@nuovations.com>
NAND and DOC bits Acked-by: Scott Wood <scottwood@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Updated commands:
docboot - cmd_doc.c
fdcboot - cmd_fdc.c
diskboot - cmd_ide.c
nboot - cmd_nand.c
scsiboot - cmd_scsi.c
usbboot - cmd_usb.c
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
Modify common/Makefile to conditionally compile the cmd_*.c files based
on the board config.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Fix bug introduced by "Fix get_partition_info() parameter error in all
other calls" from 2005-03-04 in cmd_ide.c and cmd_scsi.c, which prevented
to use diskboot or scsiboot form another device than 0.
Signed-off-by: Denis Peter <d.peter@mpl.ch>
buffer pointers
Block device read/write is anonymous data; there is no need to use a
typed pointer. void * is fine. Also add a hook for block_read functions
Each of the filesystem drivers duplicate the get_dev routine. This change
merges them into a single function in part.c
Add AHCI support in u-boot, enable the sata disk controllers which
following the AHCI protocol.
Signed-off-by:Jason Jin<jason.jin@freescale.com>
Patch by Denis Peter, 06 Dec 2004
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c).
* Enable USB and IDE support for INKA4x0 board
* Patch by Andrew Dyer, 28 February 2005:
fix ext2load passing an incorrect pointer to get_partition_info()
resulting in load failure for devices other than 0
