path: root/common/cmd_sandbox.c
2014-01-08sandbox: block driver using host file/device as backing storeHenrik Nordström
Provide a way to use any host file or device as a block device in U-Boot. This can be used to provide filesystem access within U-Boot to an ext2 image file on the host, for example. The support is plumbed into the filesystem and partition interfaces. We don't want to print a message in the driver every time we find a missing device. Pass the information back to the caller where a message can be printed if desired. Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net> Signed-off-by: Simon Glass <sjg@chromium.org> - Removed change to part.c get_device_and_partition() Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-10-14cmd_sandbox.c: Update for do_(load|save) not taking a number baseTom Rini
2013-05-01sandbox: fs: Add support for saving files to host filesystemSimon Glass
This allows write of files from the host filesystem in sandbox. There is currently no concept of overwriting the file and removing its existing contents - all writing is done on top of what is there. This means that writing 10 bytes to the start of a 1KB file will only update those 10 bytes, not truncate the file to 10 byte slong. If the file does not exist it is created. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-04sandbox: Add 'sb' command to access filesystem featuresSimon Glass
The new 'sb' command is intended to deal with sandbox-specific features that have no parallel in other archs. This commit adds two sub-commands to list a directory and read a file from the host filesystem. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
