path: root/common/cmd_regulator.c
2015-08-05dm: pmic: Display the regulator limits on errorSimon Glass
When a regulator command cannot honour the requested voltage, display the limits to try to be helpful. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-05-14common: cmd regulator: command cleanupPrzemyslaw Marczak
This commit cleanups the regulator command. The first change, is adjusting "regulator dev" command to use "regulator-name" constraint, for setting the operating device. Thanks to this, the regulator_get() function is removed. This also updates do_list() function, with loop over uclass_find_* function calls, to prevent probe of all listed regulators. This also cleanups the printing in command. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested on sandbox: Tested-by: Simon Glass <sjg@chromium.org>
2015-05-14dm: regulator: add regulator commandPrzemyslaw Marczak
This command is based on driver model regulator's API. The user interface provides: - list UCLASS regulator devices - show or [set] operating regulator device - print constraints info - print operating status - print/[set] voltage value [uV] (force) - print/[set] current value [uA] - print/[set] operating mode id - enable the regulator output - disable the regulator output The 'force' option can be used for setting the value which exceeds the constraints min/max limits. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
