path: root/common/cmd_pcmcia.c
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-04-18Patches by Pantelis Antoniou, 16 Apr 2004:wdenk
- add support for a new version of an Intracom board and fix various other things on others. - add verify support to the crc32 command (define CONFIG_CRC32_VERIFY to enable it) - fix FEC driver for MPC8xx systems: 1. fix compilation problems for boards that use dynamic allocation of DPRAM 2. shut down FEC after network transfers - HUSH parser fixes: 1. A new test command was added. This is a simplified version of the one in the bourne shell. 2. A new exit command was added which terminates the current executing script. 3. Fixed handing of $? (exit code of last executed command)
2004-04-15* Patch by Stephen Williams, 01 Apr 2004:wdenk
Add support for Picture Elements JSE board * Patch by Christian Pell, 01 Apr 2004: Add CompactFlash support for PXA systems.
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-03-25* Patch by Klaus Heydeck, 13 Mar 2003:wdenk
Add support for KUP4X Board
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2004-02-06* Patch by Wolter Kamphuis, 15 Dec 2003:wdenk
made CONFIG_SILENT_CONSOLE usable on all architectures * Disable date command on TQM866M - there is no RTC on MPC866
2004-01-04* Make BMS2003 use a separate config file to avoid #ifdef mess;wdenk
add I2C support; add support for DS1337 RTC * Add CompactFlash support for BMS2003 board * Add support for status LED on BMS2003 board
2003-12-27* Make CPU clock on ICA-IP board controllable by a "cpuclk"wdenk
environment variable which can set to "100", "133", or "150". The CPU clock will be configured accordingly upon next reboot. Other values are ignored. In case of an invalid or undefined "cpuclk" value, the compile-time default CPU clock speed will be used. * Enable Quad-UART on BMS2003 board (initialize the PCMCIA memory window that is used to access the UART registers by the Linux driver) * Patch by Reinhard Meyer, 20 Dec 2003: Fix clock calculation for the MPC5200 for higher clock frequencies (above 2**32 / 10 = 429.5 MHz).
2003-12-07* Patch by Yuli Barcohen, 3 Dec 2003:wdenk
"revive" U-Boot support for old Motorola MPC860ADS board * Patch by Cam(ilo?), 03 Dec 2003: make examples build even with broken Montavista objcopy * Patch by Pavel Bartusek, 27 Nov 2003: fix conversion problem with "bootretry" evironment variable
2003-10-19Add CompactFlash support for NSCUdzu
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2003-05-18Add support for CompactFlash on ATC boardwdenk
(includes support for Intel 82365 and compatible PC Card controllers, and Yenta-compatible PCI-to-CardBus controllers)
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2003-01-11* Restrict baudrate settings on LWMON to higher speedsLABEL_2003_01_11_1050wdenk
when watchdog is on * Update baudrate in bd_info when it gets changed * Add watchdog trigger points while waiting for serial port (so far only 8xx -- needed on LWMON with 100ms watchdog) * Improve command line tool to access the U-Boot's environment (figuration of the utility, using a config file)
2002-12-04Add LED indication for IDE activity on KUP4K boardwdenk
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
2002-11-05* Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735wdenk
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board
