There are a lot of unrelated files in common, including all of the commands.
Moving them into their own directory makes them easier to find and is more
logical.
Some commands include non-command code, such as cmd_scsi.c. This should be
sorted out at some point so that the function can be enabled with or without
the associated command.
Unfortunately, with m68k I get this error:
m68k: + M5329AFEE
+arch/m68k/cpu/mcf532x/start.o: In function `_start':
+arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o
I hope someone can shed some light on what this means. I hope it isn't
depending on the position of code in the image.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
The console includes a global variable and several functions that are only
used by a small subset of U-Boot files. Before adding more functions, move
the definitions into their own header file.
User's confirmation is asked in different commands. This commit adds a
function for such confirmation.
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
With d6a320d we moved some clock externs out of blackfin_local.h and
into clock.h but now need to include <asm/clock.h> in more drivers to
avoid warnings.
Cc: Sonic Zhang <sonic.zhang@analog.com>
Change all files in common/ to use CMD_RET_USAGE instead of calling
cmd_usage() directly. I'm not completely sure about this patch since
the code since impact is small (100 byte or so on ARM) and it might
need splitting into smaller patches. But for now here it is.
The OTP code does a little shuffling of arguments that aren't really
necessary, so use a local variable instead to fix build errors now
that the args[] parameter is const.
Most of the files have U_BOOT_CMD on a separate line,
but a few didn't and had the first line on the same line
as U_BOOT_CMD.
This changes these files by adding a line break and a tab
Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Looks like I accidentally added a newline to the OTP help when merging and
older change.
Now that real documentation has been released for the OTP interface and
the on-chip ROM wrt writing/timings, implement support for reading/writing
as well as dumping/locking.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
