path: root/common/cmd_onenand.c
2008-08-13common: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-12OneNAND: Fill in MTD function pointers for OneNAND.Fathi BOUDRA
onenand_print_device_info(): - Now returns a string to be placed in mtd->name, rather than calling printf. - Remove verbose parameter as it becomes useless. Signed-off-by: Fathi Boudra <fabo@debian.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-10OneNAND: Remove base address offset usagedirk.behme@googlemail.com
While locally preparing some U-Boot patches for ARM based OMAP3 boards, some using OneNAND and some using NAND, we found some differences in OneNAND and NAND command address handling. As this might confuse users (it already confused us), we like to align OneNAND and NAND address handling. The issue is that cmd_onenand.c subtracts the onenand base address from the addresses you type into the u-boot command line so, unlike nand, you can't use addresses relative to the start of the onenand part e.g. this won't work: onenand read 82000000 280000 400000 you have to use: onenand read 82000000 20280000 400000 Looking at recent git, the only board currently using OneNAND is Apollon, and for this the OneNAND base address is 0 (apollon.h) #define CFG_ONENAND_BASE 0x00000000 so patch below won't break any existing boards and will align OneNAND and NAND handling on boards where OneNAND base address is != 0. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Manikandan Pillai <mani.pillai@ti.com> Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-04-13Fix OneNAND erase commandKyungmin Park
It mis-calculates the block address. Also fix DECLARE_GLOBAL_DATA_PTR in env_onenand. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2007-09-17OneNAND support (take #2)Kyungmin Park
[PATCH 3/3] OneNAND support (take #2) OneNAND support at U-Boot Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
