path: root/common/cmd_net.c
2004-06-09Patch by Thomas Viehweger, 14 May 2004:wdenk
- flash.h: more flash types added - immap_8260.h: some bits added (useful for RMII) - cmd_coninfo.c: typo corrected, printf -> puts - reduced size by replacing spaces with tab
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2003-08-28- Added CONFIG_BOOTP_DNS2 and CONFIG_BOOTP_SEND_HOSTNAME to CONFIG_BOOTP_MASK.stroese
2003-07-15* Patches by Martin Krause, 14 Jul 2003:wdenk
- add I2C support for s3c2400 systems (trab board) - (re-) add "ping" to command table * Fix handling of "slow" POST routines
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-06-28help text cleanupLABEL_2003_06_29_0145wdenk
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2002-11-11* Patch by Andreas Oberritter, 09 Nov 2002:wdenk
Change behaviour of NetLoop(): return -1 for errors, filesize otherwise; return code 0 is valid an means no file loaded - in this case the environment still gets updated! * Patches by Jon Diekema, 9 Nov 2002: - improve ADC/DAC clocking on the SACSng board to align the failing edges of LRCLK and SCLK - sbc8260 configuration tweaks - add status LED support for 82xx systems - wire sspi/sspo commands into command handler; improved error handlering - add timestamp support and alternate memory test to the SACSng configuration
2002-08-27Initial revisionwdenk
