This adds the tftpput command to U-Boot.
(cherry picked from commit 2d46cf291eae29a42bb5ca3d280d2b136339686b)
Change-Id: I7d0dc1fd78d9269ed932899cb1c301771ee24fbf
Reviewed-on: https://gerrit.chromium.org/gerrit/11802
Commit-Ready: Simon Glass <sjg@chromium.org>
This is a better name for this protocol. Also remove the typedef to keep
checkpatch happy, and move zeroing of NetBootFileXferSize a little
earlier since TFTPPUT will need to change this.
(cherry-picked from e4bf0c5)
Change-Id: I90d03045de0231553a693f7119bdcc67a908e3c9
Reviewed-on: https://gerrit.chromium.org/gerrit/11796
This defines the basics of a new boot time measurement feature. This allows
logging of very accurate time measurements as the boot proceeds, by using
an available microsecond counter.
To enable the feature, define CONFIG_BOOTSTAGE in your board config file.
Also available is CONFIG_BOOTSTAGE_REPORT which will cause a report to be
printed just before handing off to the OS.
BUG=chromium-os:13875
TEST=build and boot, check that progress is reported before running Linux:
Timer summary in microseconds:
Mark Elapsed Stage
0 0 awake
2,181,078 2,181,078 usb_start
11,861,817 9,680,739 bootp_start
11,884,610 22,793 bootp_stop
11,884,689 79 tftp start
15,271,536 3,386,847 tftp done
15,271,568 32 bootm_start
15,406,551 134,983 start_kernel
Change-Id: I71b89c8402dc5dec75e68333bd24a6bab7500a1b
Reviewed-on: http://gerrit.chromium.org/gerrit/197
When we use the ntpserverip environment variable argv[1] may not be set.
Printing the error message using the NetNtpServerIP variable ensures the
correct output in both cases.
Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz>
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Ben Warren <biggerbadderben@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
This reverts commit 5a442c0addc69d0c4b58e98e5aec1cf07576debb.
This commit changed the behaviour of getenv_yesno() (both the default
behaviour and the documented behaviour for abbreviated arguments)
which resulted in problems in several areas.
Commit 722b061 "autocomplete: remove runtime handler install" caused
some boards (like NETTA2_V2) to break with errors like these:
cmd_net.c:296: error: expected expression before ',' token
Fix this.
Cc: Mike Frysinger <vapier@gentoo.org>
Use the new helper func to clean up duplicate logic handling of the
autostart env var.
The duplication of the do_bootm prototype has gotten out of hand,
and they're pretty much all outdated (wrt constness). Unify them
all in command.h.
This commit causes build errors like this:
cmd_net.c:301:1: error: macro "U_BOOT_CMD" requires 6 arguments, but only 5 given
cmd_net.c:298: warning: data definition has no type or storage class
cmd_net.c:298: warning: type defaults to 'int' in declaration of 'U_BOOT_CMD'
This reverts commit 8f4cb77ef7183ce1bb3f767604a0677c6f6d84a7.
Building for boards that have CONFIG_CMD_CDP enabled fail with:
cmd_net.c:301: error: expected expression before ',' token
Most people don't use the 'rarpboot' command, so only enable it when
CONFIG_CMD_RARP is defined.
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
The more standard 'source' command provides identical functionality to
the autoscr command.
Environment variable names/values on the MVBC_P, MVBML7, kmeter1,
mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'.
The 'autoscript' and 'autoscript_uname' environment variables are
also removed.
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Heiko Schocher <hs@denx.de>
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot.
http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html
> DNS can be enabled by setting CFG_CMD_DNS. After performing a query,
> the serverip environment var is updated.
> Probably there are some cosmetic issues with the patch. Unfortunatly I
> do not have the time to correct these. So if anybody else likes DNS
> support in U-Boot and has the time, feel free to patch it in the main tree.
Here it is again - slightly modified & smaller:
- update to 2009-06 (Pieter's patch was for U-Boot 1.2.0)
- README.dns is added
- syntax is changed (now takes a third option, the env var to store
the result in)
- add a random port() function in net.c
- sort Makefile in ./net/Makefile
- dns just returns unless a env var is given
- run through checkpatch, and clean up style issues
- remove packet from stack
- cleaned up some comments
- failure returns much faster (if server responds, don't wait for
timeout)
- use built in functions (memcpy) rather than byte copy.
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl>
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
When CONFIG_SYS_HUSH_PARSER is defined network download
commands with 1 argument in the format 'tftp "/path/file"'
do not work as expected. The hush command parser strips
the quotes from "/path/file" which causes the network
commands to interpret "/path/file" as an address
instead of the intended filename.
The previous check for a leading quote in netboot_common()
was replaced with a check which ensures only valid
numbers are treated as addresses.
cmd_net.c command descriptions were updated to describe the optional
hostIPaddr argument. The dhcp command help message was also updated
to more closely reflect the other commands in cmd_net.c
autoscript() routine is updated to accept second argument, which
is only used for FIT images and provides a FIT subimage unit name.
autoscript() routine callers must now pass two arguments. For
non-interactive use (like in cmd_load.c, cmd_net.c), new environment
variable 'autoscript_uname' is introduced and used as a FIT
subimage unit name source.
autoscript command accepts extended syntax of the addr argument:
addr:<subimg_uname>
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
allow to use a different server as set in serverip
add CONFIG_TFTP_FILE_NAME_MAX_LEN to configure the file name length
if not defined the max length will be at 128
Modify common/Makefile to conditionally compile the cmd_*.c files based
on the board config.
CHANGELOG
fs/fat/fat.c
include/configs/MPC8560ADS.h
include/configs/pcs440ep.h
net/eth.c
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
All of the choices for CONFIG_BOOTP_ are now documented in
the README file. You must now individually select exactly
the set that you want using a series of
#define CONFIG_BOOTP_<x>
statements in the board port config files now.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
enable SNTP support in some boards.
add SNTP support and expand time server and time offset fields of
DHCP support. See doc/README.SNTP
* Patch by Steven Scholz, 13 Dec 2004:
Fix bug in at91rm920 ethernet driver
- flash.h: more flash types added
- immap_8260.h: some bits added (useful for RMII)
- cmd_coninfo.c: typo corrected, printf -> puts
- reduced size by replacing spaces with tab
* Patch by Rune Torgersen, 16 Apr 2004:
LBA48 fixes
* Patches by Pantelis Antoniou, 16 Apr 2004:
- Fix some compile problems;
add "once" functionality for the netretry variable
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
Add support for NFS for file download
* Minor code cleanup
- add I2C support for s3c2400 systems (trab board)
- (re-) add "ping" to command table
* Fix handling of "slow" POST routines
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Add support for TQM862L at 100/50 MHz
* Patch by Pantelis Antoniou, 02 Jun 2003:
major reconstruction of networking code;
add "ping" support (outgoing only!)
