path: root/common/cmd_net.c
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-22Remove deprecated 'autoscr' command/variablesPeter Tyser
The more standard 'source' command provides identical functionality to the autoscr command. Environment variable names/values on the MVBC_P, MVBML7, kmeter1, mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'. The 'autoscript' and 'autoscript_uname' environment variables are also removed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-22Add DNS supportRobin Getz
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot. http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html > > DNS can be enabled by setting CFG_CMD_DNS. After performing a query, > the serverip environment var is updated. > > Probably there are some cosmetic issues with the patch. Unfortunatly I > do not have the time to correct these. So if anybody else likes DNS > support in U-Boot and has the time, feel free to patch it in the main tree. Here it is again - slightly modified & smaller: - update to 2009-06 (Pieter's patch was for U-Boot 1.2.0) - README.dns is added - syntax is changed (now takes a third option, the env var to store the result in) - add a random port() function in net.c - sort Makefile in ./net/Makefile - dns just returns unless a env var is given - run through checkpatch, and clean up style issues - remove packet from stack - cleaned up some comments - failure returns much faster (if server responds, don't wait for timeout) - use built in functions (memcpy) rather than byte copy. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-04Fix quoting bug introduced by commit 74de7aefWolfgang Denk
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-12-04net: Fix download command parsingPeter Tyser
When CONFIG_SYS_HUSH_PARSER is defined network download commands with 1 argument in the format 'tftp "/path/file"' do not work as expected. The hush command parser strips the quotes from "/path/file" which causes the network commands to interpret "/path/file" as an address instead of the intended filename. The previous check for a leading quote in netboot_common() was replaced with a check which ensures only valid numbers are treated as addresses. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Standardize bootp, tftpboot, rarpboot, dhcp, and nfs command descriptionsPeter Tyser
cmd_net.c command descriptions were updated to describe the optional hostIPaddr argument. The dhcp command help message was also updated to more closely reflect the other commands in cmd_net.c Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-12[new uImage] Add new uImage format support to autoscript routineMarian Balakowicz
autoscript() routine is updated to accept second argument, which is only used for FIT images and provides a FIT subimage unit name. autoscript() routine callers must now pass two arguments. For non-interactive use (like in cmd_load.c, cmd_net.c), new environment variable 'autoscript_uname' is introduced and used as a FIT subimage unit name source. autoscript command accepts extended syntax of the addr argument: addr:<subimg_uname> Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-05TFTP: add host ip addr supportJean-Christophe PLAGNIOL-VILLARD
allow to use a different server as set in serverip add CONFIG_TFTP_FILE_NAME_MAX_LEN to configure the file name length if not defined the max length will be at 128 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-16Fix nfs command help to reflect that the serverip is optionalJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09Finally retire cmd_confdefs.h and CONFIG_BOOTP_MASK!Jon Loeliger
All of the choices for CONFIG_BOOTP_ are now documented in the README file. You must now individually select exactly the set that you want using a series of #define CONFIG_BOOTP_<x> statements in the board port config files now. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-08common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2005-04-01* Patch by Masami Komiya, 30 Mar 2005:wdenk
add SNTP support and expand time server and time offset fields of DHCP support. See doc/README.SNTP * Patch by Steven Scholz, 13 Dec 2004: Fix bug in at91rm920 ethernet driver
2004-06-09Patch by Thomas Viehweger, 14 May 2004:wdenk
- flash.h: more flash types added - immap_8260.h: some bits added (useful for RMII) - cmd_coninfo.c: typo corrected, printf -> puts - reduced size by replacing spaces with tab
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2003-08-28- Added CONFIG_BOOTP_DNS2 and CONFIG_BOOTP_SEND_HOSTNAME to CONFIG_BOOTP_MASK.stroese
2003-07-15* Patches by Martin Krause, 14 Jul 2003:wdenk
- add I2C support for s3c2400 systems (trab board) - (re-) add "ping" to command table * Fix handling of "slow" POST routines
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-06-28help text cleanupLABEL_2003_06_29_0145wdenk
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2002-11-11* Patch by Andreas Oberritter, 09 Nov 2002:wdenk
Change behaviour of NetLoop(): return -1 for errors, filesize otherwise; return code 0 is valid an means no file loaded - in this case the environment still gets updated! * Patches by Jon Diekema, 9 Nov 2002: - improve ADC/DAC clocking on the SACSng board to align the failing edges of LRCLK and SCLK - sbc8260 configuration tweaks - add status LED support for 82xx systems - wire sspi/sspo commands into command handler; improved error handlering - add timestamp support and alternate memory test to the SACSng configuration
2002-08-27Initial revisionwdenk
