path: root/common/cmd_nand.c
2014-05-23Add the function 'confirm_yesno' for interactivePierre Aubert
User's confirmation is asked in different commands. This commit adds a function for such confirmation. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2013-08-22cmd_nand: Do not show usage when scrub is abortedMasahiro Yamada
When executing nand scrub, the user gets the prompt: Really scrub this NAND flash? <y/N> We do not want the annoying usage displayed when saying N here. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-08-22cmd_nand: slight optimization of nand_dump functionMasahiro Yamada
If a non-zero value is given to only_oob argument, printing the main area is skipped. With a little modification, we can skip the whole while loop. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-08-22cmd_nand: fix a memory leak in nand_dump functionMasahiro Yamada
If datbuf = memalign(ARCH_DMA_MINALIGN, nand->writesize); succeeds and oobbuf = memalign(ARCH_DMA_MINALIGN, nand->oobsize); fails, nand_dump function should free databuf. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-06-21nand: Don't call adjust_size_for_badblocks for eraseScott Wood
adjust_size_for_badblocks reduces the operation size to account for the block skipping done by the read/write functions when an interval (partition name or whole chip) is specified rather than a data amount. Erase does not do block skipping, except for erase.spread which takes a data amount rather than an interval (and thus already does not call adjust_size_for_badblocks). Calling adjust_size_for_badblocks when block skipping is not done means that if bad blocks are present, the "nand erase.part" and "nand erase.chip" commands will fail to erase blocks at the end of the interval. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Harvey Chapman <hchapman@3gfp.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-05-22nand: adjust erase/read/write partition/chip size for bad blocksHarvey Chapman
Adjust the sizes calculated for whole partition/chip operations by removing the size of bad blocks so we don't try to erase/read/write past a partition/chip boundary. Signed-off-by: Harvey Chapman <hchapman@3gfp.com>
2013-04-10cmd_nand.c: Fix CONFIG_CMD_NAND_YAFFSTom Rini
The flag changed from WITH_INLINE_OOB to WITH_YAFFS_OOB by accident in 418396e. Signed-off-by: Tom Rini <trini@ti.com>
2013-04-10nand: Extend nand_(read|write)_skip_bad with *actual and limit parametersTom Rini
We make these two functions take a size_t pointer to how much space was used on NAND to read or write the buffer (when reads/writes happen) so that bad blocks can be accounted for. We also make them take an loff_t limit on how much data can be read or written. This means that we can now catch the case of when writing to a partition would exceed the partition size due to bad blocks. To do this we also need to make check_skip_len count not just complete blocks used but partial ones as well. All callers of nand_(read|write)_skip_bad are adjusted to call these with the most sensible limits available. The changes were started by Pantelis and finished by Tom. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-02-28common: Use new numeric setenv functionsSimon Glass
Use setenv_ulong(), setenv_hex() and setenv_addr() in common/ Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-22nand: fix nand read.option parsingHarvey Chapman
"nand read.part addr off size" would be treated as "nand read.raw addr off 1" It now fails as intended stating "Unknown nand command suffix '.part'" Signed-off-by: Harvey Chapman <hchapman@3gfp.com>
2012-11-26nand: Add torture featureBenoît Thébaudeau
This patch adds a NAND Flash torture feature, which is useful as a block stress test to determine if a block is still good and reliable (or should be marked as bad), e.g. after a write error. This code is ported from mtd-utils' lib/libmtd.c. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Scott Wood <scottwood@freescale.com> [scottwood@freescale.com: removed unnec. ifdef and unwrapped error strings] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-11-04common/cmd_*.c: sparse fixesKim Phillips
cmd_boot.c:40:5: warning: symbol 'do_go' was not declared. Should it be static? cmd_bootm.c:164:6: warning: symbol '__arch_preboot_os' was not declared. Should it be static? cmd_bootm.c:477:5: warning: symbol 'do_bootm_subcommand' was not declared. Should it be static? cmd_bootm.c:1022:1: error: directive in argument list cmd_bootm.c:1028:1: error: directive in argument list cmd_bootm.c:1029:1: error: directive in argument list cmd_bootm.c:1036:1: error: directive in argument list cmd_bootm.c:1042:1: error: directive in argument list cmd_bootm.c:1044:1: error: directive in argument list cmd_bootm.c:1045:1: error: directive in argument list cmd_bootm.c:1047:1: error: directive in argument list cmd_bootm.c:1089:5: warning: symbol 'do_iminfo' was not declared. Should it be static? cmd_bootm.c:1176:5: warning: symbol 'do_imls' was not declared. Should it be static? cmd_bootm.c:1654:1: error: directive in argument list cmd_bootm.c:1660:1: error: directive in argument list cmd_console.c:32:5: warning: symbol 'do_coninfo' was not declared. Should it be s cmd_date.c:46:5: warning: symbol 'do_date' was not declared. Should it be static? cmd_echo.c:27:5: warning: symbol 'do_echo' was not declared. Should it be static? cmd_exit.c:27:5: warning: symbol 'do_exit' was not declared. Should it be static? cmd_fat.c:97:5: warning: symbol 'do_fat_ls' was not declared. Should it be static? cmd_fat.c:136:5: warning: symbol 'do_fat_fsinfo' was not declared. Should it be s cmd_fdt.c:66:5: warning: symbol 'do_fdt' was not declared. Should it be static? cmd_fdt.c:542:43: warning: incorrect type in assignment (different base types) cmd_fdt.c:542:43: expected unsigned int [unsigned] [usertype] <noident> cmd_fdt.c:542:43: got restricted __be32 [usertype] <noident> cmd_fdt.c:679:42: warning: cast to restricted __be32 cmd_fdt.c:820:1: error: directive in argument list cmd_fdt.c:822:1: error: directive in argument list cmd_flash.c:292:5: warning: symbol 'do_flinfo' was not declared. Should it be static? cmd_flash.c:324:5: warning: symbol 'do_flerase' was not declared. Should it be static? cmd_flash.c:457:5: warning: symbol 'do_protect' was not declared. Should it be st cmd_help.c:27:5: warning: symbol 'do_help' was not declared. Should it be static? cmd_i2c.c:136:6: warning: symbol '__def_i2c_init_board' was not declared. Should it be static? cmd_i2c.c:144:14: warning: symbol '__def_i2c_get_bus_speed' was not declared. Should it be static? cmd_i2c.c:151:5: warning: symbol '__def_i2c_set_bus_speed' was not declared. Should it be static? cmd_i2c.c:1322:1: error: directive in argument list cmd_i2c.c:1324:1: error: directive in argument list cmd_i2c.c:1326:1: error: directive in argument list cmd_i2c.c:1328:1: error: directive in argument list cmd_i2c.c:1337:1: error: directive in argument list cmd_i2c.c:1339:1: error: directive in argument list cmd_irq.c:27:5: warning: symbol 'do_interrupts' was not declared. Should it be static? cmd_itest.c:133:5: warning: symbol 'binary_test' was not declared. Should it be static? cmd_itest.c:158:5: warning: symbol 'do_itest' was not declared. Should it be stat cmd_load.c:54:5: warning: symbol 'do_load_serial' was not declared. Should it be static? cmd_load.c:431:6: warning: symbol 'his_eol' was not declared. Should it be static? cmd_load.c:432:6: warning: symbol 'his_pad_count' was not declared. Should it be static? cmd_load.c:433:6: warning: symbol 'his_pad_char' was not declared. Should it be static? cmd_load.c:434:6: warning: symbol 'his_quote' was not declared. Should it be static? cmd_load.c:436:5: warning: symbol 'do_load_serial_bin' was not declared. Should it be static? cmd_load.c:549:6: warning: symbol 'send_pad' was not declared. Should it be static? cmd_load.c:558:6: warning: symbol 'ktrans' was not declared. Should it be static? cmd_load.c:568:5: warning: symbol 'chk1' was not declared. Should it be static? cmd_load.c:578:6: warning: symbol 's1_sendpacket' was not declared. Should it be static? cmd_load.c:587:6: warning: symbol 'send_ack' was not declared. Should it be static? cmd_load.c:600:6: warning: symbol 'send_nack' was not declared. Should it be static? cmd_load.c:614:6: warning: symbol 'os_data_init' was not declared. Should it be static? cmd_load.c:615:6: warning: symbol 'os_data_char' was not declared. Should it be static? cmd_load.c:657:6: warning: symbol 'k_data_init' was not declared. Should it be static? cmd_load.c:663:6: warning: symbol 'k_data_save' was not declared. Should it be static? cmd_load.c:669:6: warning: symbol 'k_data_restore' was not declared. Should it be static? cmd_load.c:675:6: warning: symbol 'k_data_char' was not declared. Should it be static? cmd_load.c:693:6: warning: symbol 'send_parms' was not declared. Should it be static? cmd_load.c:694:6: warning: symbol 'send_ptr' was not declared. Should it be static? cmd_load.c:698:6: warning: symbol 'handle_send_packet' was not declared. Should i cmd_mdio.c:60:5: warning: symbol 'mdio_write_ranges' was not declared. Should it be static? cmd_mdio.c:82:5: warning: symbol 'mdio_read_ranges' was not declared. Should it be static? cmd_mdio.c:115:5: warning: symbol 'extract_reg_range' was not declared. Should it be static? cmd_mdio.c:144:5: warning: symbol 'extract_phy_range' was not declared. Should it cmd_mem.c:54:5: warning: symbol 'do_mem_md' was not declared. Should it be static? cmd_mem.c:150:5: warning: symbol 'do_mem_mm' was not declared. Should it be static? cmd_mem.c:154:5: warning: symbol 'do_mem_nm' was not declared. Should it be static? cmd_mem.c:159:5: warning: symbol 'do_mem_mw' was not declared. Should it be static? cmd_mem.c:256:5: warning: symbol 'do_mem_cmp' was not declared. Should it be static? cmd_mem.c:326:5: warning: symbol 'do_mem_cp' was not declared. Should it be static? cmd_mem.c:436:5: warning: symbol 'do_mem_base' was not declared. Should it be static? cmd_mem.c:449:5: warning: symbol 'do_mem_loop' was not declared. Should it be static? cmd_mem.c:595:5: warning: symbol 'do_mem_mtest' was not declared. Should it be static? cmd_mem.c:618:26: warning: Using plain integer as NULL pointer cmd_mem.c:1057:5: warning: symbol 'do_mem_crc' was not declared. Should it be static? cmd_misc.c:30:5: warning: symbol 'do_sleep' was not declared. Should it be static cmd_mmc.c:118:5: warning: symbol 'do_mmcinfo' was not declared. Should it be static? cmd_mmc.c:272:32: warning: Using plain integer as NULL pointer cmd_mmc.c:150:5: warning: symbol 'do_mmcops' was not declared. Should it be stati cmd_mp.c:27:1: warning: symbol 'cpu_cmd' was not declared. Should it be static? cmd_mp.c:85:1: error: directive in argument list cmd_mp.c:88:1: error: directive in argument list cmd_mtdparts.c:150:18: warning: symbol 'mtdids' was not declared. Should it be static? cmd_mtdparts.c:153:18: warning: symbol 'devices' was not declared. Should it be static? cmd_mtdparts.c:713:5: warning: symbol 'mtd_device_validate' was not declared. Should it be static? cmd_mtdparts.c:1887:5: warning: symbol 'do_chpart' was not declared. Should it be static? cmd_mtdparts.c:1925:5: warning: symbol 'do_mtdparts' was not declared. Should it be static? cmd_mtdparts.c:2060:1: error: directive in argument list cmd_mtdparts.c:2063:1: error: directive in argument list cmd_mtdparts.c:2066:1: error: directive in argument list cmd_mtdparts.c:2071:1: error: directive in argument list cmd_mtdparts.c:2073:1: error: directive in argument list cmd_nand.c:377:18: error: bad constant expression cmd_nand.c:431:5: warning: symbol 'do_nand' was not declared. Should it be static? cmd_nand.c:796:1: error: directive in argument list cmd_nand.c:801:1: error: directive in argument list cmd_nand.c:802:1: error: directive in argument list cmd_nand.c:806:1: error: directive in argument list cmd_nand.c:819:1: error: directive in argument list cmd_nand.c:824:1: error: directive in argument list cmd_nand.c:825:1: error: directive in argument list cmd_nand.c:831:1: error: directive in argument list cmd_nand.c:918:5: warning: symbol 'do_nandboot' was not declared. Should it be static? cmd_net.c:33:5: warning: symbol 'do_bootp' was not declared. Should it be static? cmd_net.c:107:5: warning: symbol 'do_dhcp' was not declared. Should it be static? cmd_net.c:120:5: warning: symbol 'do_nfs' was not declared. Should it be static? cmd_nvedit.c:138:5: warning: symbol 'do_env_print' was not declared. Should it be static? cmd_nvedit.c:323:5: warning: symbol '_do_env_set' was not declared. Should it be static? cmd_nvedit.c:435:5: warning: symbol 'do_env_set' was not declared. Should it be static? cmd_nvedit.c:514:5: warning: symbol 'do_env_edit' was not declared. Should it be static? cmd_nvedit.c:620:5: warning: symbol 'do_env_save' was not declared. Should it be static? cmd_nvedit.c:1016:1: error: directive in argument list cmd_nvedit.c:1018:1: error: directive in argument list cmd_nvedit.c:1021:1: error: directive in argument list cmd_nvedit.c:1023:1: error: directive in argument list cmd_nvedit.c:1024:1: error: directive in argument list cmd_nvedit.c:1026:1: error: directive in argument list cmd_nvedit.c:1027:1: error: directive in argument list cmd_nvedit.c:1029:1: error: directive in argument list cmd_nvedit.c:1030:1: error: directive in argument list cmd_nvedit.c:1032:1: error: directive in argument list cmd_nvedit.c:1034:1: error: directive in argument list cmd_nvedit.c:1036:1: error: directive in argument list cmd_nvedit.c:1037:1: error: directive in argument list cmd_nvedit.c:1039:1: error: directive in argument list cmd_pci.c:38:17: warning: symbol 'ShortPCIListing' was not declared. Should it be static? cmd_pci.c:38:22: warning: 'ShortPCIListing' defined but not used [-Wunused-variable] cmd_pci.c:411:5: warning: symbol 'do_pci' was not declared. Should it be static? cmd_pci.c:494:1: error: directive in argument list cmd_pci.c:497:1: error: directive in argument list cmd_reginfo.c:40:5: warning: symbol 'do_reginfo' was not declared. Should it be static? cmd_sata.c:31:5: warning: symbol 'sata_curr_device' was not declared. Should it be static? note -> ata_piix.c doesn't seem to use 'sata_curr_device'; deleted. cmd_sata.c:32:18: warning: symbol 'sata_dev_desc' was not declared. Should it be static? cmd_sata.c:70:5: warning: symbol 'do_sata' was not declared. Should it be static? cmd_setexpr.c:53:5: warning: symbol 'do_setexpr' was not declared. Should it be static? cmd_source.c:186:1: error: directive in argument list cmd_source.c:190:1: error: directive in argument list cmd_test.c:27:5: warning: symbol 'do_test' was not declared. Should it be static? cmd_test.c:153:5: warning: symbol 'do_false' was not declared. Should it be static? cmd_test.c:164:5: warning: symbol 'do_true' was not declared. Should it be static cmd_usb.c:43:6: warning: symbol 'usb_get_class_desc' was not declared. Should it be static? cmd_usb.c:69:6: warning: symbol 'usb_display_class_sub' was not declared. Should it be static? cmd_usb.c:151:6: warning: symbol 'usb_display_string' was not declared. Should it be static? cmd_usb.c:161:6: warning: symbol 'usb_display_desc' was not declared. Should it be static? cmd_usb.c:195:6: warning: symbol 'usb_display_conf_desc' was not declared. Should it be static? cmd_usb.c:210:6: warning: symbol 'usb_display_if_desc' was not declared. Should it be static? cmd_usb.c:227:6: warning: symbol 'usb_display_ep_desc' was not declared. Should it be static? cmd_usb.c:252:6: warning: symbol 'usb_display_config' was not declared. Should it be static? cmd_usb.c:283:6: warning: symbol 'usb_show_tree_graph' was not declared. Should it be static? cmd_usb.c:343:6: warning: symbol 'usb_show_tree' was not declared. Should it be static? cmd_usb.c:356:5: warning: symbol 'do_usbboot' was not declared. Should it be static? cmd_usb.c:366:5: warning: symbol 'do_usb' was not declared. Should it be static? cmd_version.c:31:5: warning: symbol 'do_version' was not declared. Should it be s cmd_ximg.c:46:1: warning: symbol 'do_imgextract' was not declared. Should it be static? cmd_ximg.c:272:1: error: directive in argument list cmd_ximg.c:276:1: error: directive in argument list Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-09-21Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-09-17nand: Make NAND lock status compatible with MicronJoe Hershberger
Micron NAND flash (e.g. MT29F4G08ABADAH4) BLOCK LOCK READ STATUS is not the same as others. Instead of bit 1 being lock, it is #lock_tight. To make the driver support either format, ignore bit 1 and use only bit 0 and bit 2. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-17nand: Add support for unlock.invertJoe Hershberger
NAND unlock command allows an invert bit to be set to unlock all but the selected page range. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> [scottwood@freescale.com: updated docs and added comment about invert bit] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-07cmd_nand: dump: Align data and OOB buffersThierry Reding
In order for cache invalidation and flushing to work properly, the data and OOB buffers must be aligned to full cache lines. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-06-08cmd_nand: fix crashing bug in nand read/writeSteve Sakoman
Commit 418396e212b59bf907dbccad997ff50f7eb61b16 introduced a bug that causes nand read and nand write to crash in strcmp due to a null pointer. Root cause is that strchr(cmd, '.') returns a null pointer when the input string does not contain a '.' The strcmp function does not check for null pointers, resulting in a crash. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Scott Wood <scott@tyr.buserror.net>
2012-05-22common/cmd_nand.c: Fix GCC 4.6 warningAnatolij Gustschin
cmd_nand.c: In function 'raw_access': cmd_nand.c:397:9: warning: variable 'rwsize' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Scott Wood <scottwood@freescale.com>
2012-05-18nand: extend .raw accesses to work on multiple pagesScott Wood
A use for this is to read, modify, erase, and write an entire block as a single unit, as a replacement for the biterr command. This way gives more flexibility in that you can also test multiple bit errors, errors in the ECC, etc. Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-04-29GCC47: Fix warning in cmd_nand.cMarek Vasut
cmd_nand.c: In function ‘arg_off_size’: cmd_nand.c:216:5: warning: ‘maxsize’ may be used uninitialized in this function [-Wmaybe-uninitialized] Signed-off-by: Marek Vasut <marex@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Wolfgang Denk <wd@denx.de>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Convert NAND progress numbers to enumsSimon Glass
This changes over the NAND progress numbers to use enums from bootstage.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Use show_boot_error() for -ve progress numbersSimon Glass
Rather than the caller negating our progress numbers to indicate an error has occurred, which seems hacky, add a function to indicate this. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-02-28cmd_nand.c: Fix 'nand dump' after latest MTD resyncTom Rini
With 2a8e0fc nand_do_read_ops changed in behavior slightly (keeping in sync with the kernel which did this change in b64d39d8) such that the OOB data is always copied into oobbuf and never appended to datbuf. Within U-Boot only the nand_dump function (for the dump nand subcommand) was expecting the OOB data to only be appended to datbuf. So we now change nand_dump to not malloc extra space, correct the comment about datbuf and OOB data and switch the pointer to oobbuf before printing. Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Make page, erase, oob size available via cmd_nandMarek Vasut
The "nand info" and "nand device" now set shell/environment variables: nand_writesize ... nand page size nand_oobsize ..... nand oob area size nand_erasesize ... nand erase block size Also, the "nand info" command now displays this info. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: removed unnecessary memsets] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Add -y option to nand scrub commandMarek Vasut
This allows the scrub command to scrub without asking the user if he really wants to scrub the area. Useful in scripts. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Add nand read.raw and write.raw commandsMarek Vasut
These commands should work around various "hardware" ECC and BCH methods. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: s/write the page/access the page/] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-01GCC4,6: Squash warning in cmd_nand.cMarek Vasut
cmd_nand.c: In function ‘do_nand’: cmd_nand.c:490:7: warning: variable ‘chip’ set but not used [-Wunused-but-set-variable] cmd_nand.c:489:7: warning: variable ‘part’ set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-25autostart: unify duplicated logic into the bootm codeMike Frysinger
Rather than having a bunch of random commands handle autostart behavior, unify the logic in a single place. This also fixes building of these different commands when bootm is disabled. Acked-by: Matthew McClintock <msm@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-01cmd_nand: add nand write.trimffs commandBen Gardiner
Add another nand write. variant, trimffs. This command will request of nand_write_skip_bad() that all trailing all-0xff pages will be dropped from eraseblocks when they are written to flash as-per the reccommended behaviour of the UBI FAQ [1]. The function that implements this timming is the drop_ffs() function by Artem Bityutskiy, ported from the mtd-utils tree. [1] http://www.linux-mtd.infradead.org/doc/ubi.html#L_flasher_algo Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> CC: Artem Bityutskiy <dedekind1@gmail.com> CC: Detlev Zundel <dzu@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-07-01nand_util: convert nand_write_skip_bad() to flagsBen Gardiner
In a future commit the behaviour of nand_write_skip_bad() will be further extended. Convert the only flag currently passed to the nand_write_ skip_bad() function to a bitfield of only one allocated member. This should avoid an explosion of int's at the end of the parameter list or the ambiguous calls like nand_write_skip_bad(info, offset, len, buf, 0, 1, 1); nand_write_skip_bad(info, offset, len, buf, 0, 1, 0); Instead there will be: nand_write_skip_bad(info, offset, len, buf, WITH_YAFFS_OOB | WITH_OTHER); Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-05-24cmd_nand: fix help of nand erase subcommandDaniel Hobi
Since commit 30486322 (nand erase: .spread, .part, .chip subcommands) the arguments off and size are no longer optional. Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-01-12NAND: add the ability to directly write yaffs imageLei Wen
This patch add addition suffix to nand write to give the uboot the power to directly burn the yaffs image to nand. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-01-11Revert "boot cmds: convert to getenv_yesno() with autostart"Wolfgang Denk
This reverts commit 5a442c0addc69d0c4b58e98e5aec1cf07576debb. This commit changed the behaviour of getenv_yesno() (both the default behaviour and the documented behaviour for abbreviated arguments) which resulted in problems in several areas. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-28boot cmds: convert to getenv_yesno() with autostartMike Frysinger
Use the new helper func to clean up duplicate logic handling of the autostart env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_bootm: unify duplicate prototypesMike Frysinger
The duplication of the do_bootm prototype has gotten out of hand, and they're pretty much all outdated (wrt constness). Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-18Fix warning in nand unlock commandScott Wood
Commit ea533c260a801c4e51f92f75165cebe6d7b01e35 changed arg_off_size to take a pointer to a device index, rather than to the device itself. When updating callers, the nand unlock code was missed. Signed-off-by: Scott Wood <scottwood@freescale.com>
2010-10-11nand commands: make only "dump" repeatable.Scott Wood
The dump command is made to increment its address on repeat, as md does. Other commands do not make sense to issue repeatedly, and can be irritating when it happens accidentally, so don't. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-10-11nand erase: .spread, .part, .chip subcommandsScott Wood
A while back, in http://lists.denx.de/pipermail/u-boot/2009-June/054428.html, Michele De Candia posted a patch to not count bad blocks toward the requested size to be erased. This is desireable when you're passing in something like $filesize, but not when you're trying to erase a partition. Thus, a .spread subcommand (named for consistency with http://lists.denx.de/pipermail/u-boot/2010-August/075163.html) is introduced to make explicit the user's desire to erase for a given amount of data, rather than to erase a specific region of the chip. While passing $filesize to "nand erase" is useful, accidentally passing something like $fliesize currently produces quite unpleasant results, as the variable evaluates to nothing and U-Boot assumes that you want to erase the entire rest of the chip/partition. To improve the safety of the erase command, require the user to make explicit their intentions by using a .part or .chip subcommand. This is an incompatible user interface change, but keeping compatibility would eliminate the safety gain, and IMHO it's worth it. While touching nand_erase_opts(), make it accept 64-bit offsets and sizes, fix the percentage display when erase length is rounded up, eliminate an inconsistent warning about rounding up the erase length which only happened when the length was less than one block (rounding up for $filesize is normal operation), and add a diagnostic if there's an attempt to erase beginning at a non-block boundary. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-10-11cmd_nand: some infrastructure fixes and refactoringScott Wood
- If the current device is overridden by a named partition, - update the caller's pointer/index, rather than copy over the nand_info struct, and - be sure to call board_nand_select_device even when the device is overridden by a named partition. - Support 64-bit offsets/sizes in a few more places. - Refactor arg_off_size for added readability and flexibility, and some added checks such as partition size. - Remove redundant check for bad subcommands -- if there's no match it'll print usage when it gets to the end anyway. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-08-09various cmd_* files: fixed layout a little bitFrans Meulenbroeks
Most of the files have U_BOOT_CMD on a separate line, but a few didn't and had the first line on the same line as U_BOOT_CMD. This changes these files by adding a line break and a tab Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-07-12NAND: formatting cleanups from env.oob supportScott Wood
Change if (ok) { bunch of stuff } else { error } to if (error) { get out } proceed with bunch of stuff Plus a few whitespace cleanups. Signed-off-by: Scott Wood <scottwood@freescale.com>
2010-07-12NAND: environment offset in OOB (CONFIG_ENV_OFFSET_OOB)Ben Gardiner
This is a re-submission of the patch by Harald Welte <laforge@openmoko.org> with minor modifications for rebase and changes as suggested by Scott Wood <scottwood@freescale.com> [1] [2]. This patch enables the environment partition to have a run-time dynamic location (offset) in the NAND flash. The reason for this is simply that all NAND flashes have factory-default bad blocks, and a fixed compile time offset would mean that sometimes the environment partition would live inside factory bad blocks. Since the number of factory default blocks can be quite high (easily 1.3MBytes in current standard components), it is not economic to keep that many spare blocks inside the environment partition. With this patch and CONFIG_ENV_OFFSET_OOB enabled, the location of the environment partition is stored in the out-of-band (OOB) data of the first block in flash. Since the first block is where most systems boot from, the vendors guarantee that the first block is not a factory default block. This patch introduces the 'nand env.oob' command, which can be called from the u-boot command line. 'nand env.oob get' reads the address of the environment partition from the OOB data, 'nand env.oob set {offset,partition-name}' allows the setting of the marker by specifying a numeric offset or a partition name. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/43916 [2] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/79195 Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Harald Welte <laforge@gnumonks.org>
2010-05-21Fix "par[t]ition" typo.Wolfgang Denk
2010-03-23cmd_nand: show nand scrub confirmation characterFlorian Fainelli
When issuing a nand scrub command, the entered character is not displayed this may be confusing. This patch makes the input character being displayed if it is a 'y' so that an user knows he is about to scrub his nand. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2009-11-13cmd_nand: Move conditional compilation to MakefilePeter Tyser
