Signed-off-by: William Juul <william.juul@tandberg.com>
Changes requested by maintainer Stefan Roese after
posting patch to U-boot mailing list.
- Fixing leading white spaces
- Fixing indentation where 4 spaces are used instead of tab
- Removing C++ comments (//), wherever I introduced them
A lot changed in the Linux MTD code, since it was last ported from
Linux to U-Boot. This patch takes U-Boot NAND support to the level
of Linux 2.6.22.1 and will enable support for very large NAND devices
(4KB pages) and ease the compatibility between U-Boot and Linux
filesystems.
This patch is tested on two custom boards with PPC and ARM
processors running YAFFS in U-Boot and Linux using gcc-4.1.2
cross compilers.
MAKEALL ppc/arm has some issues:
* DOC/OneNand/nand_spl is not building (I have not tried porting
these parts, and since I do not have any HW and I am not familiar
with this code/HW I think its best left to someone else.)
Except for the issues mentioned above, I have ported all drivers
necessary to run MAKEALL ppc/arm without errors and warnings. Many
drivers were trivial to port, but some were not so trivial. The
following drivers must be examined carefully and maybe rewritten to
some degree:
cpu/ppc4xx/ndfc.c
cpu/arm926ejs/davinci/nand.c
board/delta/nand.c
board/zylonite/nand.c
Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
This patch fixes NAND related printf format warning. Those warnings are
now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd
[Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is
really helpful.
Global FIT image operations like format check cannot be performed on
a first sector data, defer them to the point when whole FIT image was
uploaded to a system RAM.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Partial ('cmd_nand' case) Acked-by: Grant Erickson <gerickson@nuovations.com>
NAND and DOC bits Acked-by: Scott Wood <scottwood@freescale.com>
The nand_info array is declared as extern in several .c files.
Those days, nand.h contains a reference to the array, so there is
no need to declare it elsewhere.
Signed-off-by: Stelian Pop <stelian@popies.net>
This patch allocates a set of show_boot_progress() IDs for new uImage format
and adds show_boot_progress() calls in new uImage format handling code.
Updated commands:
docboot - cmd_doc.c
fdcboot - cmd_fdc.c
diskboot - cmd_ide.c
nboot - cmd_nand.c
scsiboot - cmd_scsi.c
usbboot - cmd_usb.c
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
that used to exist with the legacy NAND code
Signed-off-by: Harald Welte <laforge@openmoko.org>
Fix usage of do_div() in nand erase|read|write process output.
The last patch to nand_util.c introduced do_div() instead of libgcc's
implementation. But do_div() returns the quotient in its first
macro parameter and not as result.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This config option sets the default for the progress information
output behavior that can also be configured through the 'quiet'
environment variable.
The legacy NAND code does not print the current progress info
on the console. So this option is for backward compatibility for
units that are in the field and where setting the quiet variable
is not an option. With CFG_NAND_QUIET set to '1' the console
progress info is turned off. This can still be overwritten
through the environment variable.
CHANGELOG
fs/fat/fat.c
include/configs/MPC8560ADS.h
include/configs/pcs440ep.h
net/eth.c
The old implementation of command nboot does not support reading the image from
NAND flash with skipping of bad blocks. The patch implements a new version of
the nboot command: by calling nboot.jffs2 from the u-boot command line the
command will load the image from NAND flash with respect to bad blocks (by using
nand_read_opts()). This is similar to e.g. the NAND read command: "nand
read.jffs2 ...".
Signed-off-by: Thomas Knobloch <knobloch@siemens.com>
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
chpart, nboot and NAND subsystem related commands now accept also partition
name to specify offset.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Based on idea and implementation from Jeff Mann
Patch by Stefan Roese, 20 Oct 2006
Patch by Guido Classen, 10 Oct 2006
- JFFS2 related commands implemented in mtd-utils style
- Support for bad blocks
- Bad block testing commands
- NAND lock commands
Please take a look at doc/README.nand for more details
Patch by Steven Scholz, 10 Jun 2005
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and
BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for
NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is
implemented for these boards.
Patch by Ladislav Michl, 13 Sep 2005
Patch by Ladislav Michl, 29 Jun 2005
Patch by Matthias Fuchs, 4 May 2005
* Add support for MPC8247 based "IDS8247" board.
Added missing variable declaration in cmd_nand.c
Modified CFG_PCI_PTM1MS in configs/PLU405.h to map 128MB ram
- Add support for MicroSys CPU87 board
- Add support for MicroSys PM854 board
(CFG_NAND_SKIP_BAD_DOT_I)
Add support for WindRiver's SBC8560 board
* Patch by Nicolas Lacressonniere, 24 Jun 2004
Small Bugs fixes for "at91rm9200dk" board:
- Timing modifications for SPI DataFlash access
- Fix NAND flash detection bug
* Patch by Nicolas Lacressonniere, 24 Jun 2004:
Add Support for Flash AT49BV6416 for AT91RM9200DK board
