path: root/common/cmd_mmc.c
2009-04-04cmd_mmc: add support for device command for selecting mmc deviceMinkyu Kang
This patch improves device command for selecting mmc device Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-04-04more command usage cleanupMike Frysinger
Fix up a few dangling commands like in "Command usage cleanup" commit. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-19MMC: Don't use new framework code if not enabledDirk Behme
Don't use code of new MMC framework in cmd_mmc if CONFIG_GENERIC_MMC isn't enabled. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-19Coding style cleanup, update CHANGELOGWolfgang Denk
2009-02-16Add MMC FrameworkAndy Fleming
Here's a new framework (based roughly off the linux one) for managing MMC controllers. It handles all of the standard SD/MMC transactions, leaving the host drivers to implement only what is necessary to deal with their specific hardware. This also hooks the infrastructure into the PowerPC board code (similar to how the ethernet infrastructure now hooks in) Some of this code was contributed by Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16Convert mmc_init to mmc_legacy_initAndy Fleming
This is to get it out of the way of incoming MMC framework Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
