For emmc, it may have up to 7 partitions: two boot partitions, one
user partition, one RPMB partition and four general purpose partitions.
(Refer to JESD84-A44.pdf/page 154)
As bootloader may need to read out or reflashing images on those
different partitions, it is better to enable the partition switch with
console command support.
Also for partition would be restore to user partition(part 0) when CMD0
is used, so change mmc_init routine to perform normal initialization
only once for each slot, unless use the rescan command to force init
again.
Signed-off-by: Lei Wen <leiwen@marvell.com>
Acked-by: Andy Fleming <afleming@freescale.com>
mmc command applied device, like ide and usb...
Signed-off-by: Andy Fleming <afleming@freescale.com>
Rather than using a custom "Usage:", use the common cmd_usage() function,
and tail into it now that it returns 1 for us.
Coding style cleanup.
Remove warning for missing " at the end of line 136
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Most of the files have U_BOOT_CMD on a separate line,
but a few didn't and had the first line on the same line
as U_BOOT_CMD.
This changes these files by adding a line break and a tab
Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
removed the command name from the help message as it is already printed.
for cmd_mmc also rewrote the message a little bit
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
This patch removes the \n after the help message for mmcinfo.
This resulted in an empty line being displayed after the mmcinfo line
when the help command was given.
The curr_device variable isn't used outside of cmd_mmc, so mark it static
to avoid conflicts with other pieces of code (like sata which also exports
a curr_device). Otherwise we end up with stuff like:
common/libcommon.a(cmd_sata.o):(.data.curr_device+0x0):
multiple definition of `curr_device'
common/libcommon.a(cmd_mmc.o):(.data.curr_device+0x0): first defined here
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
find_mmc_device returns NULL if an invalid device number is specified.
Check for this to avoid dereferencing NULL pointers.
Signed-off-by: Rabin Vincent <rabin@rab.in>
Remove some repeated words and superfluous newlines in the mmc command
help entries.
This patch improves device command for selecting mmc device
Fix up a few dangling commands like in "Command usage cleanup" commit.
Don't use code of new MMC framework in cmd_mmc if CONFIG_GENERIC_MMC
isn't enabled.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Here's a new framework (based roughly off the linux one) for managing
MMC controllers. It handles all of the standard SD/MMC transactions,
leaving the host drivers to implement only what is necessary to
deal with their specific hardware.
This also hooks the infrastructure into the PowerPC board code
(similar to how the ethernet infrastructure now hooks in)
Some of this code was contributed by Dave Liu <daveliu@freescale.com>
This is to get it out of the way of incoming MMC framework
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Modify common/Makefile to conditionally compile the cmd_*.c files based
on the board config.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
