path: root/common/cmd_misc.c
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-12Change 'repeatable' attribute of some commands to sensible values.Detlev Zundel
Most prominently this changes 'erase' to be non-repeatable. Signed-off-by: Detlev Zundel <dzu@denx.de>
2005-10-20Fix problem with sleep in NetConsole (use get_timer())Stefan Roese
Patch by Stefan Roese, 20 Oct 2005
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2002-08-27Initial revisionwdenk
