path: root/common/cmd_mfsl.c
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-05-16Fix compile problem cause my Microblaze mergeStefano Babic
2007-05-08add: reading special purpose registersMichal Simek
2007-05-08add: FSL control read and writeMichal Simek
2007-05-07fix: read and write MSR - repair number of parametersMichal Simek
2007-05-07new: add writing to msr registerMichal Simek
2007-05-05new: FSL and MSR supportMichal Simek
