path: root/common/cmd_mem.c
2013-06-26Fix missing return in do_mem_loop()Simon Glass
For some reason this does not normally cause a compiler warning, but the code seems to be incorrect. Add the missing return. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-24cmd_mem: fix cp commandMasahiro Yamada
The "cp" command has not worked since commit 0628ab8ec59834f98ede267edd21ddb8ba0bb57b, because of the following lines, which set the destination and the source to the same address. buf = map_sysmem(addr, bytes); src = map_sysmem(addr, bytes); Tested-by: Tom Rini <trini@ti.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-03-12cmd_mem.c: Fix warning when CONFIG_CMD_MEMTEST is not setTom Rini
mem_test_quick and mem_test_alt functions are only called by do_mem_mtest, so move them under the #ifdef Signed-off-by: Tom Rini <trini@ti.com>
2013-03-11Feature Removal: disable "mtest" command by defaultWolfgang Denk
The "mtest" command is of little practical use (if any), and experience has shown that a large number of board configurations define useless or even dangerous start and end addresses. If not even the board maintainers are able to figure out which memory range can be reliably tested, how can we expect such from the end users? As this problem comes up repeatedly, we rather do not enable this command by default, so only people who know what they are doing will be confronted with it. As this changes the user interface, we allow for a grace period before this change takes effect. For now, we make "mtest" configurable through the CONFIG_CMD_MEMTEST variable, which is defined in include/config_cmd_default.h; we also add an entry to doc/feature-removal-schedule.txt which announces the removal of this default setting in two releases from now, i. e. with v2013.07. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com>
2013-02-28sandbox: Update mtest to fix crashesSimon Glass
Use map_sysmem() in the memory tester so that it works as expected on sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Move CONFIG_SYS_MEMTEST_SCRATCH #ifdef to top of fileSimon Glass
This config effectively has a default value of 0, so add this setting at the top of the code to remove an #ifdef in the C function. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Roll crc32 into hash infrastructureSimon Glass
Add the CRC32 algorithm to the list of available hashes, and make the crc32 command use hash_command(). Add a new crc32_wd_buf() to make this possible, which puts its result in a buffer rather than returning it as a 32-bit value. Note: For some boards the hash command is not enabled, neither are sha1, sha256 or the verify option. In this case the full hash implementation adds about 500 bytes of overhead. So as a special case, we use #ifdef to select very simple bahaviour in that case. The justification for this is that it is currently a very common case (virtually all boards enable crc32 but only some enable more advanced features). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Reduce casting in mtestSimon Glass
Use a ulong for the command arguments, and only cast to an address when needed. This fixes warnings in sandbox where pointers are typically 64 bits long. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Bring mtest putc() into common codeSimon Glass
If we get a Ctrl-C abort, we always print a newline. Move this repeated code out of the functions and into a single place in the caller. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Fix mtest indentingSimon Glass
Some of the inner loops are not indented correctly. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Use common mtest iteration countingSimon Glass
The iteration code is the same for each version of the memory test, so pull it out into the common function. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Split out the memory tests into separate functionsSimon Glass
Half of the code is currently hidden behind an #ifdef. Move the two memory tests into their own functions and use the compiler to eliminate the unused code. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28sandbox: Change memory commands to use map_physmemSimon Glass
Sandbox wants to support commands which use memory. The map_sysmen() call provides this feature, so use this in the memory commands. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-19cmd_mem.c: Fix some typoes, no functional changesRobert P. J. Day
2013-01-10Add option to display customised memory informationSimon Glass
Some boards want to report more than just memory size. For example, it might be useful to display the memory type (DDR2, DDR3) or manufacturer. Add a weak function to support this requirement, accessed through a new 'meminfo' command. Any example of the DRAM: output is below, just for illustration: SMDK5250 # meminfo DRAM: 2 GiB Elpida DDR3 @ 800MHz Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-04common/cmd_*.c: sparse fixesKim Phillips
cmd_boot.c:40:5: warning: symbol 'do_go' was not declared. Should it be static? cmd_bootm.c:164:6: warning: symbol '__arch_preboot_os' was not declared. Should it be static? cmd_bootm.c:477:5: warning: symbol 'do_bootm_subcommand' was not declared. Should it be static? cmd_bootm.c:1022:1: error: directive in argument list cmd_bootm.c:1028:1: error: directive in argument list cmd_bootm.c:1029:1: error: directive in argument list cmd_bootm.c:1036:1: error: directive in argument list cmd_bootm.c:1042:1: error: directive in argument list cmd_bootm.c:1044:1: error: directive in argument list cmd_bootm.c:1045:1: error: directive in argument list cmd_bootm.c:1047:1: error: directive in argument list cmd_bootm.c:1089:5: warning: symbol 'do_iminfo' was not declared. Should it be static? cmd_bootm.c:1176:5: warning: symbol 'do_imls' was not declared. Should it be static? cmd_bootm.c:1654:1: error: directive in argument list cmd_bootm.c:1660:1: error: directive in argument list cmd_console.c:32:5: warning: symbol 'do_coninfo' was not declared. Should it be s cmd_date.c:46:5: warning: symbol 'do_date' was not declared. Should it be static? cmd_echo.c:27:5: warning: symbol 'do_echo' was not declared. Should it be static? cmd_exit.c:27:5: warning: symbol 'do_exit' was not declared. Should it be static? cmd_fat.c:97:5: warning: symbol 'do_fat_ls' was not declared. Should it be static? cmd_fat.c:136:5: warning: symbol 'do_fat_fsinfo' was not declared. Should it be s cmd_fdt.c:66:5: warning: symbol 'do_fdt' was not declared. Should it be static? cmd_fdt.c:542:43: warning: incorrect type in assignment (different base types) cmd_fdt.c:542:43: expected unsigned int [unsigned] [usertype] <noident> cmd_fdt.c:542:43: got restricted __be32 [usertype] <noident> cmd_fdt.c:679:42: warning: cast to restricted __be32 cmd_fdt.c:820:1: error: directive in argument list cmd_fdt.c:822:1: error: directive in argument list cmd_flash.c:292:5: warning: symbol 'do_flinfo' was not declared. Should it be static? cmd_flash.c:324:5: warning: symbol 'do_flerase' was not declared. Should it be static? cmd_flash.c:457:5: warning: symbol 'do_protect' was not declared. Should it be st cmd_help.c:27:5: warning: symbol 'do_help' was not declared. Should it be static? cmd_i2c.c:136:6: warning: symbol '__def_i2c_init_board' was not declared. Should it be static? cmd_i2c.c:144:14: warning: symbol '__def_i2c_get_bus_speed' was not declared. Should it be static? cmd_i2c.c:151:5: warning: symbol '__def_i2c_set_bus_speed' was not declared. Should it be static? cmd_i2c.c:1322:1: error: directive in argument list cmd_i2c.c:1324:1: error: directive in argument list cmd_i2c.c:1326:1: error: directive in argument list cmd_i2c.c:1328:1: error: directive in argument list cmd_i2c.c:1337:1: error: directive in argument list cmd_i2c.c:1339:1: error: directive in argument list cmd_irq.c:27:5: warning: symbol 'do_interrupts' was not declared. Should it be static? cmd_itest.c:133:5: warning: symbol 'binary_test' was not declared. Should it be static? cmd_itest.c:158:5: warning: symbol 'do_itest' was not declared. Should it be stat cmd_load.c:54:5: warning: symbol 'do_load_serial' was not declared. Should it be static? cmd_load.c:431:6: warning: symbol 'his_eol' was not declared. Should it be static? cmd_load.c:432:6: warning: symbol 'his_pad_count' was not declared. Should it be static? cmd_load.c:433:6: warning: symbol 'his_pad_char' was not declared. Should it be static? cmd_load.c:434:6: warning: symbol 'his_quote' was not declared. Should it be static? cmd_load.c:436:5: warning: symbol 'do_load_serial_bin' was not declared. Should it be static? cmd_load.c:549:6: warning: symbol 'send_pad' was not declared. Should it be static? cmd_load.c:558:6: warning: symbol 'ktrans' was not declared. Should it be static? cmd_load.c:568:5: warning: symbol 'chk1' was not declared. Should it be static? cmd_load.c:578:6: warning: symbol 's1_sendpacket' was not declared. Should it be static? cmd_load.c:587:6: warning: symbol 'send_ack' was not declared. Should it be static? cmd_load.c:600:6: warning: symbol 'send_nack' was not declared. Should it be static? cmd_load.c:614:6: warning: symbol 'os_data_init' was not declared. Should it be static? cmd_load.c:615:6: warning: symbol 'os_data_char' was not declared. Should it be static? cmd_load.c:657:6: warning: symbol 'k_data_init' was not declared. Should it be static? cmd_load.c:663:6: warning: symbol 'k_data_save' was not declared. Should it be static? cmd_load.c:669:6: warning: symbol 'k_data_restore' was not declared. Should it be static? cmd_load.c:675:6: warning: symbol 'k_data_char' was not declared. Should it be static? cmd_load.c:693:6: warning: symbol 'send_parms' was not declared. Should it be static? cmd_load.c:694:6: warning: symbol 'send_ptr' was not declared. Should it be static? cmd_load.c:698:6: warning: symbol 'handle_send_packet' was not declared. Should i cmd_mdio.c:60:5: warning: symbol 'mdio_write_ranges' was not declared. Should it be static? cmd_mdio.c:82:5: warning: symbol 'mdio_read_ranges' was not declared. Should it be static? cmd_mdio.c:115:5: warning: symbol 'extract_reg_range' was not declared. Should it be static? cmd_mdio.c:144:5: warning: symbol 'extract_phy_range' was not declared. Should it cmd_mem.c:54:5: warning: symbol 'do_mem_md' was not declared. Should it be static? cmd_mem.c:150:5: warning: symbol 'do_mem_mm' was not declared. Should it be static? cmd_mem.c:154:5: warning: symbol 'do_mem_nm' was not declared. Should it be static? cmd_mem.c:159:5: warning: symbol 'do_mem_mw' was not declared. Should it be static? cmd_mem.c:256:5: warning: symbol 'do_mem_cmp' was not declared. Should it be static? cmd_mem.c:326:5: warning: symbol 'do_mem_cp' was not declared. Should it be static? cmd_mem.c:436:5: warning: symbol 'do_mem_base' was not declared. Should it be static? cmd_mem.c:449:5: warning: symbol 'do_mem_loop' was not declared. Should it be static? cmd_mem.c:595:5: warning: symbol 'do_mem_mtest' was not declared. Should it be static? cmd_mem.c:618:26: warning: Using plain integer as NULL pointer cmd_mem.c:1057:5: warning: symbol 'do_mem_crc' was not declared. Should it be static? cmd_misc.c:30:5: warning: symbol 'do_sleep' was not declared. Should it be static cmd_mmc.c:118:5: warning: symbol 'do_mmcinfo' was not declared. Should it be static? cmd_mmc.c:272:32: warning: Using plain integer as NULL pointer cmd_mmc.c:150:5: warning: symbol 'do_mmcops' was not declared. Should it be stati cmd_mp.c:27:1: warning: symbol 'cpu_cmd' was not declared. Should it be static? cmd_mp.c:85:1: error: directive in argument list cmd_mp.c:88:1: error: directive in argument list cmd_mtdparts.c:150:18: warning: symbol 'mtdids' was not declared. Should it be static? cmd_mtdparts.c:153:18: warning: symbol 'devices' was not declared. Should it be static? cmd_mtdparts.c:713:5: warning: symbol 'mtd_device_validate' was not declared. Should it be static? cmd_mtdparts.c:1887:5: warning: symbol 'do_chpart' was not declared. Should it be static? cmd_mtdparts.c:1925:5: warning: symbol 'do_mtdparts' was not declared. Should it be static? cmd_mtdparts.c:2060:1: error: directive in argument list cmd_mtdparts.c:2063:1: error: directive in argument list cmd_mtdparts.c:2066:1: error: directive in argument list cmd_mtdparts.c:2071:1: error: directive in argument list cmd_mtdparts.c:2073:1: error: directive in argument list cmd_nand.c:377:18: error: bad constant expression cmd_nand.c:431:5: warning: symbol 'do_nand' was not declared. Should it be static? cmd_nand.c:796:1: error: directive in argument list cmd_nand.c:801:1: error: directive in argument list cmd_nand.c:802:1: error: directive in argument list cmd_nand.c:806:1: error: directive in argument list cmd_nand.c:819:1: error: directive in argument list cmd_nand.c:824:1: error: directive in argument list cmd_nand.c:825:1: error: directive in argument list cmd_nand.c:831:1: error: directive in argument list cmd_nand.c:918:5: warning: symbol 'do_nandboot' was not declared. Should it be static? cmd_net.c:33:5: warning: symbol 'do_bootp' was not declared. Should it be static? cmd_net.c:107:5: warning: symbol 'do_dhcp' was not declared. Should it be static? cmd_net.c:120:5: warning: symbol 'do_nfs' was not declared. Should it be static? cmd_nvedit.c:138:5: warning: symbol 'do_env_print' was not declared. Should it be static? cmd_nvedit.c:323:5: warning: symbol '_do_env_set' was not declared. Should it be static? cmd_nvedit.c:435:5: warning: symbol 'do_env_set' was not declared. Should it be static? cmd_nvedit.c:514:5: warning: symbol 'do_env_edit' was not declared. Should it be static? cmd_nvedit.c:620:5: warning: symbol 'do_env_save' was not declared. Should it be static? cmd_nvedit.c:1016:1: error: directive in argument list cmd_nvedit.c:1018:1: error: directive in argument list cmd_nvedit.c:1021:1: error: directive in argument list cmd_nvedit.c:1023:1: error: directive in argument list cmd_nvedit.c:1024:1: error: directive in argument list cmd_nvedit.c:1026:1: error: directive in argument list cmd_nvedit.c:1027:1: error: directive in argument list cmd_nvedit.c:1029:1: error: directive in argument list cmd_nvedit.c:1030:1: error: directive in argument list cmd_nvedit.c:1032:1: error: directive in argument list cmd_nvedit.c:1034:1: error: directive in argument list cmd_nvedit.c:1036:1: error: directive in argument list cmd_nvedit.c:1037:1: error: directive in argument list cmd_nvedit.c:1039:1: error: directive in argument list cmd_pci.c:38:17: warning: symbol 'ShortPCIListing' was not declared. Should it be static? cmd_pci.c:38:22: warning: 'ShortPCIListing' defined but not used [-Wunused-variable] cmd_pci.c:411:5: warning: symbol 'do_pci' was not declared. Should it be static? cmd_pci.c:494:1: error: directive in argument list cmd_pci.c:497:1: error: directive in argument list cmd_reginfo.c:40:5: warning: symbol 'do_reginfo' was not declared. Should it be static? cmd_sata.c:31:5: warning: symbol 'sata_curr_device' was not declared. Should it be static? note -> ata_piix.c doesn't seem to use 'sata_curr_device'; deleted. cmd_sata.c:32:18: warning: symbol 'sata_dev_desc' was not declared. Should it be static? cmd_sata.c:70:5: warning: symbol 'do_sata' was not declared. Should it be static? cmd_setexpr.c:53:5: warning: symbol 'do_setexpr' was not declared. Should it be static? cmd_source.c:186:1: error: directive in argument list cmd_source.c:190:1: error: directive in argument list cmd_test.c:27:5: warning: symbol 'do_test' was not declared. Should it be static? cmd_test.c:153:5: warning: symbol 'do_false' was not declared. Should it be static? cmd_test.c:164:5: warning: symbol 'do_true' was not declared. Should it be static cmd_usb.c:43:6: warning: symbol 'usb_get_class_desc' was not declared. Should it be static? cmd_usb.c:69:6: warning: symbol 'usb_display_class_sub' was not declared. Should it be static? cmd_usb.c:151:6: warning: symbol 'usb_display_string' was not declared. Should it be static? cmd_usb.c:161:6: warning: symbol 'usb_display_desc' was not declared. Should it be static? cmd_usb.c:195:6: warning: symbol 'usb_display_conf_desc' was not declared. Should it be static? cmd_usb.c:210:6: warning: symbol 'usb_display_if_desc' was not declared. Should it be static? cmd_usb.c:227:6: warning: symbol 'usb_display_ep_desc' was not declared. Should it be static? cmd_usb.c:252:6: warning: symbol 'usb_display_config' was not declared. Should it be static? cmd_usb.c:283:6: warning: symbol 'usb_show_tree_graph' was not declared. Should it be static? cmd_usb.c:343:6: warning: symbol 'usb_show_tree' was not declared. Should it be static? cmd_usb.c:356:5: warning: symbol 'do_usbboot' was not declared. Should it be static? cmd_usb.c:366:5: warning: symbol 'do_usb' was not declared. Should it be static? cmd_version.c:31:5: warning: symbol 'do_version' was not declared. Should it be s cmd_ximg.c:46:1: warning: symbol 'do_imgextract' was not declared. Should it be static? cmd_ximg.c:272:1: error: directive in argument list cmd_ximg.c:276:1: error: directive in argument list Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-06-19cmd_mem: cmp: convert while() to for() loopMike Frysinger
Simplify the code slightly by using a for() loop since this is basically what we're already doing -- incrementing "ngood" to the value in "count". Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-06-19cmd_mem: cmp: unify size code pathsMike Frysinger
Not only does the source code get simpler, but it also shrinks the compiled object code too. While we're here, tweak the summary message to avoid the plural issue. It isn't that big of a deal, and it's currently wrong anyways in the single (1 byte) case: Total of 1 byte were the same Grammar wise, that should be "was" rather than "were". The new output people should be able to easily figure out: Total of 1 byte(s) were the same Total of 10 byte(s) were the same Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-06-19cmd_mem: replace custom PRINTF() with debug()Mike Frysinger
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-22common: move extern char console_buffer[] to common.hIgor Grinberg
Extract all extern declarations for console_buffer[] out of c files into the common.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Murray Jensen <Murray.Jensen@csiro.au>
2011-11-16Revert "sandbox: Change md command to use map_physmem"Kumar Gala
This reverts commit 355a835747c6f7c5071ead295a7dfc489c73cb03. The original commit broke long standing assumption that md commands work on effective addresses. This normally isn't an issue for most systems that map 1:1, however on systems with a 36-bit address map it breaks. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-03sandbox: Change md command to use map_physmemSimon Glass
Sandbox wants to support commands which use memory. The map_physmen() call provides this feature, so should be used more consistently in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Matthias Weisser <weisserm@arcor.de>
2011-10-17sandbox: Use uintptr_t for 32/64-bit compatibilitySimon Glass
This fixes a problems when building on some 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-01GCC4.6: Squash warning in cmd_mem.cMarek Vasut
cmd_mem.c: In function ‘do_mem_loop’: cmd_mem.c:474:25: warning: variable ‘junk’ set but not used [-Wunused-but-set-variable] The assigned variable can be removed because the pointers are volatile so accesses to their addresses are always generated. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-07-26Fix: if using crc32 command watchdog timed outJens Scharsig
* Fix: if using crc32 command watchdog timed out * change function call crc32(..) to the watchdog-safe variant crc_32_wd(..) to support watchdog reset Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2011-04-13md5sum/sha1sum/unzip: split out of mondo mem fileMike Frysinger
There's no real need to keep these functions in the cmd_mem file since they do not use any of the common global mem variables. So split them out into their own dedicated cmd files. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-13crc32: make command optionalMike Frysinger
2011-02-15unzip: return uncompressed size in `filesize', and print it.Wolfgang Denk
The unzip command did not provide a way for the caller to get any information about the uncompressed size. To make it better usable in scripts, we now store the uncompressed size in the `filesize' variable, like we do when for example loading a file over the network or when reading it from a file system. Following that analogy, it is only consequent to also print the size. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-01-19Fix defines needed to enable command sha1sumAlexander Holler
Documented is CONFIG_CMD_SHA1, through confusion in the source CONFIG_CMD_SHA1 and CONFIG_CMD_SHA1SUM has to be used to enable sha1sum. Fix both, the documentation and the source, so that only CONFIG_CMD_SHA1SUM is needed to enable the command sha1sum. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2011-01-09cmd_mem: localize state variablesMike Frysinger
These "last" variables aren't used outside of this file, so add static. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-12cp/cmp: Add WATCHDOG_RESET in copy and compare loopStefan Roese
On some boards with a very short watchdog timeout, the "cp" and "cmp" commands may reset the board. This patch adds some watchdog resets inside the loops. Otherwise for example the lwmon5 board will reset while doing something like this: => cp.b fc000000 1000000 100000 Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-10-18mem_mtest: fix error reporting, allow escape with ^CPaul Gortmaker
The basic memtest function tries to watch for ^C after each pattern pass as an escape mechanism, but if things are horribly wrong, we'll be stuck in an inner loop flooding the console with error messages and never check for ^C. To make matters worse, if the user waits for all the error messages to complete, we then incorrectly report the test passed without errors. Adding a check for ^C after any error is printed will give the end user an escape mechanism from a console flood without slowing down the overall test speed on a slow processor. Also, the more extensive memtest quit after just a single error, which is inconsistent with the normal memtest, and not useful if if you are doing dynamic environmental impact testing, such as heating/cooling etc. Both tests now track the error count and report it properly at test completion. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-08-25Add md5sum and sha1 commands...Robin Getz
Now that we have sha1 and md5 in lib_generic, allow people to use them on the command line, for checking downloaded files. Signed-off-by: Robin Getz <rgetz@analog.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-16Eliminate support for using MMC as memoryAndy Fleming
MMC cards are not memory, so we stop treating them that way. Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-24common: Iteration limit for memory test.Dirk Eibach
The iteration limit is passed to mtest as a fourth parameter: [start [end [pattern [iterations]]]] If no fourth parameter is supplied, there is no iteration limit and the test will loop forever. Signed-off-by: Dirk Eibach <eibach@gdsys.de>
2008-12-14cmd_mem: Remove unused variablePeter Tyser
2008-09-10cmd_mem: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-09common/cmd_mem.c: remove nested #if defined(CONFIG_CMD_MEMORY)Markus Heidelberg
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
2008-08-26cmd_mem.c: Fix help message alignmentWolfgang Denk
Bug was introced by "Big white-space cleanup" (53677ef1) Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-18add 'unzip' command to u-boot commandlineHarald Welte
[PATCH] add new 'unzip' command to u-boot commandline common/cmd_mem.c: new command "unzip srcaddr dstaddr [dstsize]" to unzip from memory to memory, and option CONFIG_CMD_UNZIP to enable it Signed-off-by: Werner Almesberger <werner@openmoko.org> Signed-off-by: Harald Welte <laforge@openmoko.org>
