path: root/common/cmd_mem.c
2012-06-19cmd_mem: cmp: convert while() to for() loopMike Frysinger
Simplify the code slightly by using a for() loop since this is basically what we're already doing -- incrementing "ngood" to the value in "count". Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-06-19cmd_mem: cmp: unify size code pathsMike Frysinger
Not only does the source code get simpler, but it also shrinks the compiled object code too. While we're here, tweak the summary message to avoid the plural issue. It isn't that big of a deal, and it's currently wrong anyways in the single (1 byte) case: Total of 1 byte were the same Grammar wise, that should be "was" rather than "were". The new output people should be able to easily figure out: Total of 1 byte(s) were the same Total of 10 byte(s) were the same Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-06-19cmd_mem: replace custom PRINTF() with debug()Mike Frysinger
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-22common: move extern char console_buffer[] to common.hIgor Grinberg
Extract all extern declarations for console_buffer[] out of c files into the common.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Murray Jensen <Murray.Jensen@csiro.au>
2011-11-16Revert "sandbox: Change md command to use map_physmem"Kumar Gala
This reverts commit 355a835747c6f7c5071ead295a7dfc489c73cb03. The original commit broke long standing assumption that md commands work on effective addresses. This normally isn't an issue for most systems that map 1:1, however on systems with a 36-bit address map it breaks. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-03sandbox: Change md command to use map_physmemSimon Glass
Sandbox wants to support commands which use memory. The map_physmen() call provides this feature, so should be used more consistently in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Matthias Weisser <weisserm@arcor.de>
2011-10-17sandbox: Use uintptr_t for 32/64-bit compatibilitySimon Glass
This fixes a problems when building on some 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-01GCC4.6: Squash warning in cmd_mem.cMarek Vasut
cmd_mem.c: In function ‘do_mem_loop’: cmd_mem.c:474:25: warning: variable ‘junk’ set but not used [-Wunused-but-set-variable] The assigned variable can be removed because the pointers are volatile so accesses to their addresses are always generated. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-07-26Fix: if using crc32 command watchdog timed outJens Scharsig
* Fix: if using crc32 command watchdog timed out * change function call crc32(..) to the watchdog-safe variant crc_32_wd(..) to support watchdog reset Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2011-04-13md5sum/sha1sum/unzip: split out of mondo mem fileMike Frysinger
There's no real need to keep these functions in the cmd_mem file since they do not use any of the common global mem variables. So split them out into their own dedicated cmd files. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-13crc32: make command optionalMike Frysinger
2011-02-15unzip: return uncompressed size in `filesize', and print it.Wolfgang Denk
The unzip command did not provide a way for the caller to get any information about the uncompressed size. To make it better usable in scripts, we now store the uncompressed size in the `filesize' variable, like we do when for example loading a file over the network or when reading it from a file system. Following that analogy, it is only consequent to also print the size. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-01-19Fix defines needed to enable command sha1sumAlexander Holler
Documented is CONFIG_CMD_SHA1, through confusion in the source CONFIG_CMD_SHA1 and CONFIG_CMD_SHA1SUM has to be used to enable sha1sum. Fix both, the documentation and the source, so that only CONFIG_CMD_SHA1SUM is needed to enable the command sha1sum. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2011-01-09cmd_mem: localize state variablesMike Frysinger
These "last" variables aren't used outside of this file, so add static. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-12cp/cmp: Add WATCHDOG_RESET in copy and compare loopStefan Roese
On some boards with a very short watchdog timeout, the "cp" and "cmp" commands may reset the board. This patch adds some watchdog resets inside the loops. Otherwise for example the lwmon5 board will reset while doing something like this: => cp.b fc000000 1000000 100000 Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-10-18mem_mtest: fix error reporting, allow escape with ^CPaul Gortmaker
The basic memtest function tries to watch for ^C after each pattern pass as an escape mechanism, but if things are horribly wrong, we'll be stuck in an inner loop flooding the console with error messages and never check for ^C. To make matters worse, if the user waits for all the error messages to complete, we then incorrectly report the test passed without errors. Adding a check for ^C after any error is printed will give the end user an escape mechanism from a console flood without slowing down the overall test speed on a slow processor. Also, the more extensive memtest quit after just a single error, which is inconsistent with the normal memtest, and not useful if if you are doing dynamic environmental impact testing, such as heating/cooling etc. Both tests now track the error count and report it properly at test completion. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-08-25Add md5sum and sha1 commands...Robin Getz
Now that we have sha1 and md5 in lib_generic, allow people to use them on the command line, for checking downloaded files. Signed-off-by: Robin Getz <rgetz@analog.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-16Eliminate support for using MMC as memoryAndy Fleming
MMC cards are not memory, so we stop treating them that way. Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-24common: Iteration limit for memory test.Dirk Eibach
The iteration limit is passed to mtest as a fourth parameter: [start [end [pattern [iterations]]]] If no fourth parameter is supplied, there is no iteration limit and the test will loop forever. Signed-off-by: Dirk Eibach <eibach@gdsys.de>
2008-12-14cmd_mem: Remove unused variablePeter Tyser
2008-09-10cmd_mem: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-09common/cmd_mem.c: remove nested #if defined(CONFIG_CMD_MEMORY)Markus Heidelberg
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
2008-08-26cmd_mem.c: Fix help message alignmentWolfgang Denk
Bug was introced by "Big white-space cleanup" (53677ef1) Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-18add 'unzip' command to u-boot commandlineHarald Welte
[PATCH] add new 'unzip' command to u-boot commandline common/cmd_mem.c: new command "unzip srcaddr dstaddr [dstsize]" to unzip from memory to memory, and option CONFIG_CMD_UNZIP to enable it Signed-off-by: Werner Almesberger <werner@openmoko.org> Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-04-25Merge branch 'master' of /home/wd/git/u-boot/lwmon5Wolfgang Denk
Conflicts: common/cmd_bootm.c common/cmd_log.c include/common.h post/board/lwmon5/Makefile post/board/lwmon5/dsp.c post/board/lwmon5/dspic.c post/board/lwmon5/fpga.c post/board/lwmon5/gdc.c post/board/lwmon5/sysmon.c post/board/lwmon5/watchdog.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-22Added watchdog triggering calls in the "mtest" test function.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2008-03-30Fix CFG_NO_FLASH compilation.Stelian Pop
Many Atmel boards have no "real" (NOR) flash on board, and rely only on DataFlash and NAND memories. This patch enables CFG_NO_FLASH to be present in a board configuration file, while still enabling flash commands like 'flinfo', 'protect', etc. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-03-03fix copy from ram to dataflashKim B. Heino
If I try to "cp.b <ram> <dataflash>", u-boot selects normal flash routines instead of dataflash. This is because it checks "if source address is not dataflash" instead of target address. Signed-off-by: Kim B. Heino <Kim.Heino@bluegiga.com>
2008-02-15Fix wrong memory limit calculation in memory-testGuennadi Liakhovetski
If the length of the memory address range passed to the "mtest" command is not of the form 2^x - 1, not all address lines are tested. This bug is inherited from the original software at http://www.netrino.com/Embedded-Systems/How-To/Memory-Test-Suite-C. Fix this. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14Fix return value of mtest when CFG_ALT_MEMTEST setGuennadi Liakhovetski
Fix a missing return statement from a non-void function. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2008-02-04add support for memory commands with Blackfin L1 instruction memoryMike Frysinger
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-02-20[PATCH 3_9] Move buffer print code from md command to common functionGrant Likely
Printing a buffer is a darn useful thing. Move the buffer print code into print_buffer() in lib_generic/ Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-07-21Make code better readable.Wolfgang Denk
Patch by Ladislav Michl, 14 Sep 2005
2004-12-16memory commands "mdc" and "mwc" added for cyclic read/writestroese
2004-10-10* Patch by Gridish Shlomi, 30 Aug 2004:wdenk
- Add support to revA version of PQ27 and PQ27E. - Reverted MPC8260ADS baudrate back to original 115200 * Patch by Hojin, 17 Sep 2004: Fix typo in cfi_flash.c * Patch by Mark Jonas, 09 September 2004: mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong error message * Patch by Mark Jonas, 31 August 2004: Added option CFG_XLB_PIPELINING to enable XLB pipelining. This improves FTP performance for MPC5200 systems. Enabled for IceCube by default.
