path: root/common/cmd_md5sum.c
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-23sandbox: Use md5sum and fatwrite to enable testing of fs commandsSuriyan Ramasami
Enable md5sum to obtain the MD5 of the read and written files to check their contents for validity. Use map_sysmem() to map buffer in a sandbox environment. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19cmd_md5sum.c: remove dead code / fix warningJeroen Hofstee
commit ecd729500 "Add parameter to md5sum to save the md5 sum" adds support to build a string to be saved in the env and tries to zero end it with str_ptr = '\0'; This does actually set the pointer to the end of the buffer itself to zero. Since the string was already zero terminated by the sprintf before it, just remove the line, preventing a clang warning. cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2012-10-03Add parameter to md5sum to save the md5 sumJoe Hershberger
Add a parameter that allows you to store the md5 sum to either a memory location or a variable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-03Implement verify option for md5sum commandJoe Hershberger
Loosely based on CONFIG_CRC32_VERIFY. The sum to verify against can be in memory, in a variable, or the last parameter to the function directly. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-07-26Fix: watchdog timed out, if using md5 commandJens Scharsig
* Fix: if using md5 command watchdog timed out * change function call md5(..) to the watchdog-safe variant md5_wd(..) to support watchdog reset Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2011-04-13md5sum/sha1sum/unzip: split out of mondo mem fileMike Frysinger
There's no real need to keep these functions in the cmd_mem file since they do not use any of the common global mem variables. So split them out into their own dedicated cmd files. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
