path: root/common/cmd_log.c
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-22Adapt log buffer code to support Linux 2.6Igor Lisitsin
A new environment variable, "logversion", selects the log buffer behaviour. If it is not set or set to a value other than 2, then the old, Linux 2.4.4, behaviour is selected. Signed-off-by: Igor Lisitsin <igor@emcraft.com> --
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-15Avoid unnecessary call to post_word_load();wdenk
make logbuf compile without POST
2003-07-15Adapt log driver to latest POST changes (POST_SLOWTEST)wdenk
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-30* Patch by Seb James, 30 Jun 2003:wdenk
Improve documentation of I2C configuration in README * Fix problems with previous log buffer "fixes" * Fix minor help text issues * "log append" did not append a newline
2003-06-28Merge from "stable branch", tag LABEL_2003_06_28_1800-stable:wdenk
- Allow to call sysmon function interactively - PIC on LWMON board needs delay after power-on - Add missing RSR definitions for MPC8xx - Improve log buffer handling: guarantee clean reset after power-on - Add support for EXBITGEN board - Add support for SL8245 board
2002-12-08* Improve log buffer code; use "loglevel" to decide which messageswdenk
to log on the console, too (like in Linux); get rid of "logstart"
2002-11-05Quick & Dirty fix for log buffer problem when environment is not setwdenk
Trigger watchdog when reading the env - this might take a while. Set debugging baud rate for KUP4K board
2002-11-05* Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735wdenk
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board
