path: root/common/cmd_load.c
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-09-06loads: allow negative offsetsRicardo Ribalda Delgado
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
2008-08-27common/cmd_load.c cleanup - remove unused variablesGururaja Hebbar K R
- Remove unused global variable os_data_count. - Remove unused variable z. Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-08-11common/cmd_load.c - Minor code & Coding Style cleanupGururaja Hebbar K R
- os_data_header Variable is a carry over feature & unused. So removed all instance of this variable - Minor Code Style Update Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-03-12[new uImage] Add new uImage format support to autoscript routineMarian Balakowicz
autoscript() routine is updated to accept second argument, which is only used for FIT images and provides a FIT subimage unit name. autoscript() routine callers must now pass two arguments. For non-interactive use (like in cmd_load.c, cmd_net.c), new environment variable 'autoscript_uname' is introduced and used as a FIT subimage unit name source. autoscript command accepts extended syntax of the addr argument: addr:<subimg_uname> Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-05-02Declare load_serial_ymodem() when using CFG_CMD_LOADB.Wolfgang Denk
Patch by Jon Loeliger, 01. May 2006
2006-04-16Some code cleanupWolfgang Denk
2006-04-01* Add support for ymodem protocol downloadWolfgang Denk
Patch by Stefano Babic, 29 Mar 2006 * Memory Map Update for Delta board: U-Boot is at 0x80000000-0x84000000 Merge with /home/mk/8-benq/u-boot
2006-03-30Add support for ymodem protocol (loady command).Markus Klotzbuecher
2004-03-12Add support for Siemens SX1 mobile phone;LABEL_2004_03_12_0130wdenk
add support for USB-based console (enable with "setenv stdout usbtty; setenv stdin usbtty")
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-07* Add support for NSCU boardU-Boot-0_4_2wdenk
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules * Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML mirror bit flash on TQM8xxM modules
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
