path: root/common/cmd_led.c
2011-05-19Minor coding style cleanup.Wolfgang Denk
2011-04-27Add 'led' commandJason Kridner
This patch allows any board implementing the coloured LED API to control the LEDs from the console. led [green | yellow | red | all ] [ on | off ] or led [ 1 | 2 | 3 | all ] [ on | off ] Adds configuration item CONFIG_CMD_LED enabling the command. Partially based on patch from Ulf Samuelsson: http://www.mail-archive.com/u-boot@lists.denx.de/msg09593.html. Updated based on feedback: http://www.mail-archive.com/u-boot@lists.denx.de/msg41847.html https://groups.google.com/d/topic/beagleboard/8Wf1HiK_QBo/discussion * Fixed a handful of style issues. * Significantly reduced the number of #ifdefs and redundant code * Converted redundant code into loops test against a structure * Made use of cmd_usage() * Introduced a str_onoff() function, but haven't yet put it in common * Eliminated trailing newline Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
