path: root/common/cmd_led.c
2015-04-23cmd_led: Extend led command to support blinking and more ledsStefan Roese
This patch extends the U-Boot "led" command to support automatic blinking by setting a blink frequency in milliseconds. Additionally the number of supported LEDs is increased to 6 (0...5). This will be used by the PCA9551 LED driver. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2013-03-07led: Use STATUS_LED_ON and STATUS_LED_OFF when calling __led_setOtavio Salvador
This fixes the gpio_led driver which needs to compare againt a STATUS_LED_ON to enable a led. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-12-06cmd_led.c: Standardize format of help and usage info.Robert P. J. Day
Current "led" help and usage info has redundancy and extraneous newlines, tweak it to be consistent with other commands. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-09-13led: remove camel casing of led identifiers globallyJason Kridner
Result of running the following command to address Wolfgang's comment about camel case: for file in `find . | grep '\.[chS]$'`; do perl -i -pe 's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file; done Discussion: http://patchwork.ozlabs.org/patch/84988/ Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04led: Remove state-saving of led for toggle functionality and add toggle ↵Joel A Fernandes
option to led command * Read the led output state from GPIO instead saving state in memory when it is [re]set * Added a toggle option to the led command Previous discussion: http://lists.denx.de/pipermail/u-boot/2011-May/093068.html Changes since v1: Fixed checkpatch errors Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04led: Fixed setting of STATUS_LED_BIT1 when led_name is 'all'Joel A Fernandes
Fix for only one led getting set or reset when the led_name is 'all' Previous discussion: http://lists.denx.de/pipermail/u-boot/2011-May/093068.html Changes since v1: Fixed checkpatch if statement error noticed by Sergei. Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04led: correct off/on locations in structureJason Kridner
Although the initialization should probably be done with names, the existing implementation has these structures filled in the opposite order. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04Corrected LED name match finding avoiding extraneous Usage printoutsJason Kridner
2011-05-19Minor coding style cleanup.Wolfgang Denk
2011-04-27Add 'led' commandJason Kridner
This patch allows any board implementing the coloured LED API to control the LEDs from the console. led [green | yellow | red | all ] [ on | off ] or led [ 1 | 2 | 3 | all ] [ on | off ] Adds configuration item CONFIG_CMD_LED enabling the command. Partially based on patch from Ulf Samuelsson: http://www.mail-archive.com/u-boot@lists.denx.de/msg09593.html. Updated based on feedback: http://www.mail-archive.com/u-boot@lists.denx.de/msg41847.html https://groups.google.com/d/topic/beagleboard/8Wf1HiK_QBo/discussion * Fixed a handful of style issues. * Significantly reduced the number of #ifdefs and redundant code * Converted redundant code into loops test against a structure * Made use of cmd_usage() * Introduced a str_onoff() function, but haven't yet put it in common * Eliminated trailing newline Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
