path: root/common/cmd_ide.c
2008-08-21Fix typo in spelling of ATAPI.Steven A. Falco
Correct a small spelling mistake. Signed-off-by: Steven A. Falco <sfalco@harris.com>
2008-08-21Add a hook to allow board-specific PIO mode setting.Steven A. Falco
This patch adds a hook whereby a board-specific routine can be called to configure hardware for a PIO mode. The prototype for the board-specific routine is: int inline ide_set_piomode(int pio_mode) ide_set_piomode should be prepared to configure hardware for a pio_mode between 0 and 6, inclusive. It should return 0 on success or 1 on failure. Signed-off-by: Steven A. Falco <sfalco@harris.com>
2008-08-06Fix merge problemsStefan Roese
2008-06-30Delay FIT format check on sector based devicesMarian Balakowicz
Global FIT image operations like format check cannot be performed on a first sector data, defer them to the point when whole FIT image was uploaded to a system RAM. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Partial ('cmd_nand' case) Acked-by: Grant Erickson <gerickson@nuovations.com> NAND and DOC bits Acked-by: Scott Wood <scottwood@freescale.com>
2008-05-09ide: Remove spurious second include of io.hMarcel Ziswiler
Removed the second include, with all the #ifdef around as suggested by Wolfgang. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-04-28IDE: fix compiler warningsGuennadi Liakhovetski
The IDE driver can use 32-bit addresses in LBA mode, in which case it spits multiple warnings during compilation. Fix them. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2008-04-17IDE: fix bug in reset sequenceMartin Krause
According to the ata (ata5) specification the RESET- signal shall be asserted for at least 25 us. Without this patch, the RESET- signal is asserted on some boards for only < 1 us (e. g. on the TQM5200). This patch adds a general delay of 25 us to the RESET- signal. Without this patch a Platinum 4 GiB CF card is not recognised properly on boards with a TQM5200 (STK52xx, TB5200). Signed-off-by: Martin Krause <martin.krause@tqs.de>
2008-03-12[new uImage] Use show_boot_progress() for new uImage formatMarian Balakowicz
This patch allocates a set of show_boot_progress() IDs for new uImage format and adds show_boot_progress() calls in new uImage format handling code. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Add new uImage format handling to other bootm related commandsMarian Balakowicz
Updated commands: docboot - cmd_doc.c fdcboot - cmd_fdc.c diskboot - cmd_ide.c nboot - cmd_nand.c scsiboot - cmd_scsi.c usbboot - cmd_usb.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-21[new uImage] Rename and move print_image_hdr() routineMarian Balakowicz
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-12-07Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
Conflicts: drivers/Makefile
2007-11-29Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-17Fixed mips_io_port_base build errors.Jean-Christophe PLAGNIOL-VILLARD
This patch has been sent on: - 29 Sep 2007 Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS general part, and introduce `set_io_port_base()' from Linux. This patch is triggered by multiple definition of `mips_io_port_base' build error on gth2 (and tb0229 also needs this fix.) board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-16Fix warning differ in signedness in common/cmd_ide.cJean-Christophe PLAGNIOL-VILLARD
2007-09-23sh: Add support command of ide with shNobuhiro Iwamatsu
2007-08-28IDE: - make ide_inb () and ide_outb () "weak", so boards canHeiko Schocher
define there own I/O functions. (Needed for the pcs440ep board). - The default I/O Functions are again 8 Bit accesses. - Added CONFIG_CMD_IDE for the pcs440ep Board. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-08common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-06-08Fix config problems on SC3 board; make ide_reset_timeout work.Wolfgang Denk
2007-04-13[PATCH] Fix bugs in cmd_ide.c and cmd_scsi.cDenis Peter
Fix bug introduced by "Fix get_partition_info() parameter error in all other calls" from 2005-03-04 in cmd_ide.c and cmd_scsi.c, which prevented to use diskboot or scsiboot form another device than 0. Signed-off-by: Denis Peter <d.peter@mpl.ch>
2007-04-13[PATCH] Fix use of "void *" for block dev read/write buffer pointersGreg Lopp
Signed-of-by: Greg Lopp <lopp@pobox.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2007-04-11Update for SC3 boardWolfgang Denk
* Make IDE timeout configurable through ide_reset_timeout variable. * Use Newline as "password" string * Use just a single partition in NAND flash
2007-02-20[PATCH 9_9] Use "void *" not "unsigned long *" for block dev read_write ↵Grant Likely
buffer pointers Block device read/write is anonymous data; there is no need to use a typed pointer. void * is fine. Also add a hook for block_read functions Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-06-16Add support for gth2 boardWolfgang Denk
Patch by Thomas Lange, Aug 11 2005
2005-12-01Fix U-Boot compilation for MIPS boards using ELDK 4.0Wolfgang Denk
2005-03-06Add port initialization for digital I/O on INKA4x0LABEL_2005_03_06_0225wdenk
2005-03-04* Fix get_partition_info() parameter error in all other callswdenk
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c). * Enable USB and IDE support for INKA4x0 board * Patch by Andrew Dyer, 28 February 2005: fix ext2load passing an incorrect pointer to get_partition_info() resulting in load failure for devices other than 0
2005-02-08Fix yet another recently introduced bug.LABEL_2005_02_08_1615wdenk
2005-02-03* Removed '--no-warn-mismatch' option from Makefile. This optionwdenk
makes 'ld' to overlook binary objects compatibility. * Moved $(PLATFORM_LIBS) from the library group (--start-group ... --end-group) outside of the group. This will make 'ld' to do _multiple_ search in the library group when resolving symbol references and do only a _single_ seach in libgcc.a after the group search. * Fix stability problems on CPC45 board again. * Make image detection for diskboot / usbboot / scsiboot more robust (also check header checksum)
2005-01-22Fix IDE stability problems on CPC45 board.wdenk
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-12-16remove "static" from "ide_dev_desc" to use it from external codestroese
2004-09-28Fix problems with CDROM drive as slave device on Lite5200 IDE bus.wdenk
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-04-15* Patch by Stephen Williams, 01 Apr 2004:wdenk
Add support for Picture Elements JSE board * Patch by Christian Pell, 01 Apr 2004: Add CompactFlash support for PXA systems.
2004-03-25* Patch by Klaus Heydeck, 13 Mar 2003:wdenk
Add support for KUP4X Board
2004-03-23* Patch by Stephen Williams, 19 March 2004wdenk
Increase speed of sector reads from SystemACE, shorten poll timeout and remove a useless reset * Patch by Tolunay Orkun, 19 Mar 2004: Make GigE PHY 1000Mbps Speed/Duplex detection conditional (CONFIG_PHY_GIGE) * Patch by Brad Kemp, 18 Mar 2004: prevent machine checks during a PCI scan * Patch by Pierre Aubert, 18 Mar 2004: Fix string cleaning in IDE identification
