path: root/common/cmd_ide.c
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-04cmd_ide: Eliminate build warnings in atapi_inquiry()Bin Meng
Eliminate the following build warning in atapi_inquiry(): "warning: assignment from incompatible pointer type [enabled by default]" Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-22common: cmd_ide: use __weak and add prototypesJeroen Hofstee
clang chokes about the concept of having an alias to an always_inlined function. gcc likely just ignores the always inlined since binary sizes are equal before and after this patch. Convert the aliases to weak functions and provide missing prototypes. cc: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-22common: cmd_ide: remove PIO modeJeroen Hofstee
Since no board defines CONFIG_TUNE_PIO this is just dead code, so remove it. cc: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-06-26Fix block device accesses beyond 2TiBSascha Silbe
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type, which is required to represent block numbers for storage devices that exceed 2TiB (the block size usually is 512B), e.g. recent hard drives. For some obscure reason, the current U-Boot code uses lbaint_t for the number of blocks to read (a rather optimistic estimation of how RAM sizes will evolve), but not for the starting address. Trying to access blocks beyond the 2TiB boundary will simply wrap around and read a block within the 0..2TiB range. We now use lbaint_t for block start addresses, too. This required changes to all block drivers as the signature of block_read(), block_write() and block_erase() in block_dev_desc_t changed. Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
2013-05-01part/dev_desc: Add log2 of blocksize to block_dev_desc data structEgbert Eich
log2 of the device block size serves as the shift value used to calculate the block number to read in file systems when implementing avaiable block sizes. It is needed quite often in file systems thus it is pre-calculated and stored in the block device descriptor. Signed-off-by: Egbert Eich <eich@suse.com>
2012-11-02ide: Correct function signatures for ide_read/write()Simon Glass
The prototypes in the header were changed by commit 4ac8f8e0 but the functions no longer match. Correct this. It seems odd that block devices take an lbaint_t for the block count, but an unsigned long for the blknr. Surely we should promote blknr to lbaint_t also? Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2012-10-17remove unnecessary includes from cmd_ide.cPavel Herrmann
mpc8xx and mpc5xxx specific includes in cmd_ide.c are not required, remove them. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17split PCS440EP specific code from cmd_ide.cPavel Herrmann
Move specific ide_input_data and friends to board-specific file. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17split AU1X00 specific code from cmd_ide.cPavel Herrmann
move special case of ide_swap_read() for AU1X00 SoC into SoC-specific directory. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17make ide_led() a weak aliasPavel Herrmann
Make ide_led() a weak alias instead of global/local function/empty macro based on CONFIG_IDE_LED value and/or board-specific CONFIGs, to get rid of board-specific code in cmd_ide.c Define dummy values to get rid of compoler errors in case where ide_led() used to be an empty macro Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17split CPC45 board-specific IDE functions from cmd_ide.cPavel Herrmann
Move input_data() and friends to board/cpc45/ide.c, as overrides for weak aliases in cmd_ide.c note: checkpatch emits warnings about using volatile Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17change all versions of input_data() and output_data() to global weak aliasesPavel Herrmann
This changes input_data() and friends from static function to global symbols under weak alias, to enable board specific overrides (and therefore get rid of board-specific code in cmd_ide.c) Also declare ide_bus_offset in the header file, so other files can use ATA_CURR_BASE as well. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17split IVM power hooks from cmd_ide.cPavel Herrmann
Move power control code from ide_reset() into IVM-specific IDE reset code. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17split mpc8xx hooks from cmd_ide.cPavel Herrmann
move most of mpc8xx hooks from cmd_ide.c into ide_preinit() and newly created ide_init_postreset() (invoked after calling ide_reset after ide_preinit), some cleanup to make checkpatch happy, enable IDE init hooks in configs of affected boards. confusingly, these hooks are used by more than just mpc8xx-based boards, and therefore are placed in arch/ppc/lib/ note: checkpatch still emits warnings about using volatile Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-17remove CONFIG_SC3 from cmd_ide.cPavel Herrmann
There is no difference in codepath with CONFIG_SC3 enabled, so just remove it Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-15gth2: Remove this platformTom Rini
After taking with the former maintainer, delete this platform. The patch is from the former maintainer. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-25combine block device load commands into common functionRob Herring
All the raw block load commands duplicate the same code. Starting with the ide version as it has progress updates convert ide, usb, and scsi boot commands to all use a common version. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Convert IDE progress numbers to enumsSimon Glass
This changes over the IDE progress numbers to use enums from bootstage.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Use show_boot_error() for -ve progress numbersSimon Glass
Rather than the caller negating our progress numbers to indicate an error has occurred, which seems hacky, add a function to indicate this. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-03common/cmd_ide.c: fix GCC 4.6 build warningsWolfgang Denk
Fix: cmd_ide.c: In function 'ide_ident': cmd_ide.c:988:6: warning: variable 'do_retry' set but not used [-Wunused-but-set-variable] Delete the unused variable. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-03common/cmd_ide.c: CodingStyle cleanupWolfgang Denk
Make file acceptable to checkpatch. This is only a basic clean up to the extend possible without any real changes to the source code. Warnings due to line over 80 characters were accepted because these affect only printf()s with user visible strings. No attempts were made to fix warnings about volatile and externs - these need a more thorough cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27GCC4.6: Squash warning in cmd_ide.cMarek Vasut
cmd_ide.c: In function ‘ide_read’: cmd_ide.c:1227:2: warning: format ‘%LX’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘lbaint_t’ [-Wformat] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-27ARM: orion5x: reduce dependence of including platform fileLei Wen
For files like the drivers/serial/serial.c, it must include the platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the definition in the platform definition files. Include the platform definition file in the config file, so that it would decouple the dependence for the driver files. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-10-01IDE: Fix complaints about strict aliasing in cmd_ide.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26disk/part.c: Make features optionalMatthew McClintock
If we don't want to build support for any partition types we can now add #undef CONFIG_PARTITIONS in a board config file to keep this from being compiled in. Otherwise boards assume this is compiled in by default Signed-off-by: Matthew McClintock <msm@freescale.com>
2011-07-25autostart: unify duplicated logic into the bootm codeMike Frysinger
Rather than having a bunch of random commands handle autostart behavior, unify the logic in a single place. This also fixes building of these different commands when bootm is disabled. Acked-by: Matthew McClintock <msm@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-30IDE: fix compiler warningsWolfgang Denk
The changes introduced by commit 0abddf8 ``cmd_ide: enhance new feature "CONFIG_IDE_AHB"'' caused compiler warnings like cmd_ide.c: In function 'ide_init': cmd_ide.c:716: warning: assignment from incompatible pointer type Constify the respective function arguments to fix this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-04-30cmd_ide: enhance new feature "CONFIG_IDE_AHB"Macpaul Lin
Although most IDE controller is designed to be connected to PCI bridge, there are still some IDE controller support AHB interface for SoC design. The driver implementation of these IDE-AHB controllers differ from other IDE-PCI controller, some additional registers and commands access is required during CMD/DATA I/O. Hence a configuration "CONFIG_IDE_AHB" in cmd_ide.c is required to be defined to support these kinds of SoC controllers. Such as Faraday's FTIDE020 series and Global Unichip's UINF-0301. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-02-05cmd_ide: Fix an unused CONFIG_AU1X00 symbol to work as intendedShinya Kuribayashi
commit 8bde63eb3f79d68f693201528dafc8ae7aa087de ([MIPS] Rename Alchemy processor configs into CONFIG_SOC_*) forgot to pick up this one. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-01-11Revert "boot cmds: convert to getenv_yesno() with autostart"Wolfgang Denk
This reverts commit 5a442c0addc69d0c4b58e98e5aec1cf07576debb. This commit changed the behaviour of getenv_yesno() (both the default behaviour and the documented behaviour for abbreviated arguments) which resulted in problems in several areas. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-28boot cmds: convert to getenv_yesno() with autostartMike Frysinger
Use the new helper func to clean up duplicate logic handling of the autostart env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_bootm: unify duplicate prototypesMike Frysinger
The duplication of the do_bootm prototype has gotten out of hand, and they're pretty much all outdated (wrt constness). Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-19Remove HMI10 board supportWolfgang Denk
Recent changes caused that the HMI10 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: ps2ser.c: In function 'ps2ser_init': ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function) ps2ser.c:155: error: (Each undeclared identifier is reported only once ps2ser.c:155: error: for each function it appears in.) ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function) ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function) ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function) ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function) ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function) ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function) ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_putc': ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_getc_hw': ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_interrupt': ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function) The board is orphaned, and AFAICT has reached EOL. Drop support for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-08cmd_ide: add support for KirkwoodPrafulla Wadaskar
Added MVSATAC definitions to Kirkwood. Added support for Kirkwood in cmd_ide. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-08-08cmd_ide: add support for orion5xAlbert Aribaud
Add MVSATAHC definitions to orion5x. Add support for orion5x in cmd_ide. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-08-08ide: add configurationAlbert Aribaud
CONFIG_IDE_SWAP_IO This configuration option replaces a complex conditional in cmd_ide.c with an explicit define to be added to SoC or board configs. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-07-04cmd_ide.c: fix unused variable warning for SC3 boardWolfgang Denk
2010-06-23Remove AmigaOneG3SE boardWolfgang Denk
The AmigaOneG3SE board has been orphaned or a very long time, and broken for more than 12 releases resp. more than 3 years. As nobody seems to be interested any more in this stuff we may as well ged rid of it, especially as it clutters many areas of the code so it is a continuous pain for all kinds of ongoing work. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-09-25mucmc52, uc101: delete ata@3a00 node, if no CF card is detectedHeiko Schocher
U-Boot can detect if an IDE device is present or not. If not, and this new config option is activated, U-Boot removes the ATA node from the DTS before booting Linux, so the Linux IDE driver does not probe the device and crash. This is needed for buggy hardware (uc101) where no pull down resistor is connected to the signal IDE5V_DD7. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-06-12MPC512x: remove include/mpc512x.hWolfgang Denk
Move needed definitions (register descriptions etc.) from include/mpc512x.h into include/asm-ppc/immap_512x.h. Instead of using a #define'd register offset, use a function that provides the PATA controller's base address. All the rest of include/mpc512x.h are register offset definitions which can be eliminated by proper use of C structures. There are only a few register offsets remaining that are needed in cpu/mpc512x/start.S; for these we provide cpu/mpc512x/asm-offsets.h which is intended as a temporary workaround only. In a later patch this file will be removed, too, and then auto-generated from the respective C structs. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: John Rigby <jcrigby@gmail.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
